hp35s Vector input bug SOLVED!
10-09-2021, 06:01 AM
After struggling with the vector input bug for some time, I finally found a solution that fixes it.
1. Clear RPN stack 2. Clear VARS 3. Clear StatVars 4. GTO .. The next step might be the only one required: 5. Go to EQN LIST TOP in the equation list (key EQN, press up/down until EQN LIST TOP displays on the bottom line) 6. Finally, turn off the calculator and back on. Please leave a message if it also works for you. |
