my first program for hp48
10-31-2021, 06:02 AM
here it is
Attached File(s)
.zip  ball.zip (Size: 34.6 KB / Downloads: 52)
10-31-2021, 08:40 AM
RE: my first program for hp48
It would be helpful if you would include in the thread more information what your program does. Even the downloaded files are not easy to read because of their format.
10-31-2021, 10:18 AM
it runs on Emu48
11-21-2021, 02:22 PM
nice work please keep up posting about your updates
11-23-2021, 07:05 PM
(10-31-2021 06:02 AM)dwesti Wrote:  here it is
Doesn't work on my HP48GX. Just locks up and requires an ON-C warmstart ( fortunately no TTRM ).
Jonathan
Aeternitas modo est. Longa non est, paene nil.
12-19-2021, 02:23 PM
I used emu48 with 48g configuration
12-19-2021, 05:54 PM
(12-19-2021 02:23 PM)dwesti Wrote:  I used emu48 with 48g configuration
You should test it an an actual 48G/GX as I've written some assembly language code that runs in EMU48 but not on the actual calculator.
As I've said, for me at least, on my 48GXs your code just locks up and requires an ON-C warmstart.
Jonathan
12-20-2021, 06:58 AM
link?7
12-20-2021, 06:05 PM
(12-20-2021 06:58 AM)dwesti Wrote:  link?7
Eh? Smile Don't quite understand your question. What link? If you mean the code that runs in the emulator but not on the actual calc one example would be my COMA mode code for the 49G ( Yorke based ). The 48 version is here -- I don't know where the 49 version is; it's been years since I've touched it. The only real differences between the 48 and 49 versions are the addresses of the unsupported entry points.
Jonathan
12-22-2021, 07:49 AM
maybe reason in your calculator?
12-22-2021, 06:15 PM
(12-22-2021 07:49 AM)dwesti Wrote:  maybe reason in your calculator?
There is nothing wrong with my HP48GXs. I've tested your program on two different calculators with the same results : it locks up requiring an ON-C warmstart.
Have you tested it on your actual 48G/GX?
Jonathan
12-22-2021, 09:39 PM
Smart money says he doesn't have a real machine...
12-23-2021, 05:13 PM
(12-22-2021 09:39 PM)rprosperi Wrote:  Smart money says he doesn't have a real machine...
as if it's something bad
12-23-2021, 06:26 PM
Not answering about your results on a real 48GX was the hint... And it's not bad at all, it just helps to understand the problem, and give you the assistance you want, if your usage and platform are clear. Of course there should be no difference between eum48 and a real device, and that may not even be the case here, but it can make a difference, so eliminating unknowns/differences helps to isolate the true problem.
12-24-2021, 05:04 AM
Why all sorts of offensive hints that run counter to the declared rules?
12-24-2021, 02:04 PM
You're misunderstanding; there is no offense here, at least none intended. I was trying to clarify why you were having different results from Jonathan's results. Since this is a calculator forum, most members assume other members are posting about the actual devices; in some cases, emulators produce different results than those real devices. And when there are differences between them, most folks presume the device is correct, since that is the reference which the emulator is striving to copy.
So, sorry if you took offense, none was intended.
