Easy snap Woodstock rebuilt battery packs
11-16-2021, 08:01 AM
Got the hint from the Panamatik website (Spice battery connector with spring). The current AA batteries being longer than the 1970s NiCads, Panamatik suggests to use 4/5 length AA for SPICE batteries to avoid stressing and breaking the casing.
The idea can be applied to Woodstock battery packs. See picture. I added a 3D printed spacer (black, on the right) and used 4/5 length AA NiMH batteries to make rebuilt Woodstock battery packs. They work like a charm: easy to snap in without using much force, good contact, easy to remove.
This site does not allow the upload of .OBJ files, so PM me if you would like the file for a 3D printer.
Attached File(s) Thumbnail(s)
11-16-2021, 02:01 PM
RE: Easy snap Woodstock rebuilt battery packs
Great that you could replace some 19th century chemistry by more modern one 8-)
Also Cadmium is not very environment friendly.
A bit of history :
Pb-acid: 2V, ED 30-40 Wh/kg, 1859
Ni-Cd, 1.2V 40-60Wh/kg, 1899
Ni-metal Hydride,1,2V, 60-120Wh/kg ,1967
Li-ion, 3,7V, 150-270Wh/kg, 1970’s
