KML script does not show up when running emu48
11-19-2021, 04:52 AM
When running the most recent emu48 (version 1.64), my KML script for the HP 50g does not show up in the KML scripts I can choose from. Only the KML scripts for the HP 48SX and HP 48GX show up in the choices menu even though the KML script for the HP 50g is in the same directory as the other scripts. The other issue I am encountering is that no matter which directory I run emu48.exe, the program will only load KML scripts from the directory that emu48 was installed from. As a result, I cannot keep different device KML scripts in different directories. |
08-08-2022, 03:14 AM
RE: KML script does not show up when running emu48
You made me curious, so I set it up and tried it inside a newly installed 64 bit Windows 10 Pro running on a virtual machine.
Off-the-cuff, I am witnessing exactly the same behavior you describe. Did anyone ever respond to this question for you on any other discussion thread? |
08-08-2022, 04:31 PM
Did you try Emu48 or Emu48+?
For HP 50g emulation Emu48+ is required. |
