HP 49G Evanescent Flash Memory
07-02-2014, 03:56 PM
Has anyone had some part of the operating system or stored programmes evaporate from memory?
What is a reasonable expectation of the half-life of flash memory in simply retaining data without being repeatedly re-flashed, particularly that used in the 49G? |
07-02-2014, 08:13 PM
RE: HP 49G Evanescent Flash Memory
The industry standard for Flash memory data retention is over 100 years at 25C. That is a conservative figure so it is unlikely that is the cause of your issue. You could, of course, have a bad Flash memory device but I suspect it is more likely something bad occured in software.
User(s) browsing this thread:
