(15C)(DM15) - Convert Number from one Base to Another
11-22-2021, 10:45 AM
Hi!
As owner of a new DM15 I proudly present my first program, which converts one number from one base to another. This could give the DM15 a little bit of the HP-16C features. Unfortunately the calculator doesn't support figures >9 (ie. letters A ... F). So involving number bases >10 (ie HEX) doesn't work properly.
Example:
To convert 1101 from base 2 to base 8 simple enter 1101, 2 and 8 to the stack and start the program. The outputs on the stack are the original number (Z: 1101), the number converted to decimal (Y: 13) and the number converted to octal (X: 15).
The program source code - as output of Thorsten Manz' great HP15C-Simulator - is:
# HEWLETT·PACKARD 15C Simulator program
# Created with version 4.3.00
#T:Base Conversion
#D:Converts a number from one base to another.
#D:
#D:INPUT:
#D: Z: Number
#D: Y: FromBase
#D: X: ToBase
#D:
#D:OUTPUT:
#D: Z: Number
#D: Y: NumberInDecimal
#D: X: NumberConverted
#D:
#D:Example: [1101 2 8] -> [1101 13 15]
#D:
#D:Uses STO 1...9 and LBL 6...9
#D:
#L6:Convert
#L9:Modulo
#R1:Number
#R2:ToBase
   000 {             }
   001 {    42 21 12 } f LBL B
   002 {       44  2 } STO 2
   003 {          33 } R⬇
   004 {          33 } R⬇
   005 {       44  1 } STO 1
   006 {       43 33 } g R⬆
   007 {           1 } 1
   008 {           0 } 0
   009 {       32  6 } GSB 6
   010 {          33 } R⬇
   011 {       45  2 } RCL 2
   012 {          36 } ENTER
   013 {       32  6 } GSB 6
   014 {       45  1 } RCL 1
   015 {          36 } ENTER
   016 {          33 } R⬇
   017 {          33 } R⬇
   018 {       43 32 } g RTN
   019 {    42 21  6 } f LBL 6
   020 {       44  5 } STO 5
   021 {          33 } R⬇
   022 {       44  4 } STO 4
   023 {          33 } R⬇
   024 {       44  3 } STO 3
   025 {           0 } 0
   026 {       44  9 } STO 9
   027 {       44  8 } STO 8
   028 {       44  7 } STO 7
   029 {           1 } 1
   030 {       44  6 } STO 6
   031 {       45  3 } RCL 3
   032 {       45  5 } RCL 5
   033 {    42 21  8 } f LBL 8
   034 {       32  9 } GSB 9
   035 {    44 40  8 } STO + 8
   036 {           1 } 1
   037 {           0 } 0
   038 {    44 10  8 } STO ÷ 8
   039 {          33 } R⬇
   040 {           1 } 1
   041 {    44 40  7 } STO + 7
   042 {          33 } R⬇
   043 {       45  6 } RCL 6
   044 {          20 } ×
   045 {    44 40  9 } STO + 9
   046 {       45  4 } RCL 4
   047 {    44 20  6 } STO × 6
   048 {          33 } R⬇
   049 {          33 } R⬇
   050 {       45  5 } RCL 5
   051 {          34 } x↔y
   052 {       43 20 } g x=0
   053 {       22  7 } GTO 7
   054 {          34 } x↔y
   055 {       22  8 } GTO 8
   056 {    42 21  7 } f LBL 7
   057 {          34 } x↔y
   058 {           1 } 1
   059 {           0 } 0
   060 {       45  7 } RCL 7
   061 {          14 } yˣ
   062 {    44 20  8 } STO × 8
   063 {       45  3 } RCL 3
   064 {       45  9 } RCL 9
   065 {       45  8 } RCL 8
   066 {       43 32 } g RTN
   067 {    42 21  9 } f LBL 9
   068 {          36 } ENTER
   069 {          36 } ENTER
   070 {       43 33 } g R⬆
   071 {          36 } ENTER
   072 {          33 } R⬇
   073 {          34 } x↔y
   074 {          10 } ÷
   075 {       43 44 } g INT
   076 {          36 } ENTER
   077 {          33 } R⬇
   078 {          20 } ×
   079 {          30 } −
   080 {       43 32 } g RTN
Probably the code can be optimized - but so far I'm happy that it works.
deetee
07-05-2022, 05:49 PM
RE: (15C)(DM15) - Convert Number from one Base to Another
This is a verbatim translation of this (HP-67) Base Conversion program for the HP-15C:
   001 {    42 21 11 } f LBL A
   002 {       44  3 } STO 3
   003 {          33 } R⬇
   004 {       44  1 } STO 1
   005 {          36 } ENTER
   006 {       32  3 } GSB 3
   007 {       32  0 } GSB 0
   008 {       45  3 } RCL 3
   009 {       32  3 } GSB 3
   010 {       44  1 } STO 1
   011 {       45  3 } RCL 3
   012 {    42 21  0 } f LBL 0
   013 {       44  2 } STO 2
   014 {          30 } −
   015 {          34 } x↔y
   016 {       44  0 } STO 0
   017 {    42 21  1 } f LBL 1
   018 {       45  1 } RCL 1
   019 {          34 } x↔y
   020 {       45  2 } RCL 2
   021 {          10 } ÷
   022 {       43 44 } g INT
   023 {       43 20 } g x=0
   024 {       22  2 } GTO 2
   025 {          33 } R⬇
   026 {          20 } ×
   027 {          33 } R⬇
   028 {          20 } ×
   029 {    44 40  0 } STO + 0
   030 {          33 } R⬇
   031 {       22  1 } GTO 1
   032 {    42 21  2 } f LBL 2
   033 {       45  0 } RCL 0
   034 {       43 32 } g RTN
   035 {    42 21  3 } f LBL 3
   036 {           1 } 1
   037 {          30 } −
   038 {       43 13 } g LOG
   039 {       43 44 } g INT
   040 {           1 } 1
   041 {          40 } +
   042 {          13 } 10ˣ
   043 {       43 32 } g RTN
Examples
3258 to base 3
325 ENTER
8 ENTER
3 A
21220.
11012 to base 8
1101 ENTER
2 ENTER
8 A
15.
Compared to your output, the original number and its conversion to decimal are missing.
But I am sure that you can modify this program according to your needs.
This is a mostly verbatim translation for the HP-41C:
01 LBL "BC"
02 STO 03
03 RDN
04 STO 01
05 ENTER^
06 XEQ 03
07 XEQ 00
08 RCL 03
09 XEQ 03
10 STO 01
11 RCL 03
12 LBL 00
13 STO 02
14 -
15 X<>Y
16 STO 00
17 LBL 01
18 RCL 01
19 X<>Y
20 RCL 02
21 /
22 INT
23 X=0?
24 GTO 02
25 RDN
26 *
27 RDN
28 *
29 ST+ 00
30 RDN
31 GTO 01
32 LBL 02
33 RCL 00
34 RTN
35 LBL 03
36 1
37 -
38 LOG
39 INT
40 1
41 +
42 10^X
43 END
And here's the same for the HP-42S:
00 { 58-Byte Prgm }
01▸LBL "BC"
02 STO 03
03 R↓
04 STO 01
05 ENTER
06 XEQ 03
07 XEQ 00
08 RCL 03
09 XEQ 03
10 STO 01
11 RCL 03
12▸LBL 00
13 STO 02
14 -
15 X<>Y
16 STO 00
17▸LBL 01
18 RCL 01
19 X<>Y
20 RCL 02
21 ÷
22 IP
23 X=0?
24 GTO 02
25 R↓
26 ×
27 R↓
28 ×
29 STO+ 00
30 R↓
31 GTO 01
32▸LBL 02
33 RCL 00
34 RTN
35▸LBL 03
36 1
37 -
38 LOG
39 IP
40 1
41 +
42 10↑X
43 END
