Python graphic module: observations, assumptions, suggestions
11-30-2021, 08:50 PM
(This post was last modified: 12-01-2021 07:19 PM by Guenter Schink.)
I've downloaded the last (inofficial?) update to see if something significant has changed in the Python environment. Well the <draw_filled_polygon()> function no longer lets the G2 reboot
![]() I had a closer look at the various entries of the "graphic module"
To get around the wrong implementation of draw_rectangle() and draw_arc() I've written a small workaround. The objective is to code as if the functions worked properly, so once they are rectified there's only minimum change to the code. Only the alias import and the two definitions would have to be deleted. Code: from graphic import * Hope this is of use for someone. Perhaps you have a different insight. Comments, corrections are very welcome of course. Günter edit: added some missing arguments |
11-30-2021, 11:11 PM
RE: Python graphic module: observations, assumptions, suggestions
(11-30-2021 08:50 PM)Guenter Schink Wrote: I've downloaded the last (inofficial?) update to see if something significant has changed in the Python environment. Well the <draw_filled_polygon()> function no longer lets the G2 reboot Do you know if there's a command in the graphic module to let the user set screen coordinates and use those rather than pixel coordinates? I also notice the parameters are pickier than those in the hpprime module. There, you can use real parameters. In graphics you have to manually convert to int first. Tom L Cui bono? |
12-01-2021, 07:55 PM
(11-30-2021 11:11 PM)toml_12953 Wrote: Do you know if there's a command in the graphic module to let the user set screen coordinates and use those rather than pixel coordinates? I also notice the parameters are pickier than those in the hpprime module. There, you can use real parameters. In graphics you have to manually convert to int first.a) screen coordinates? I don't think so, haven't seen anything that points at such possibilities b) Integers? Yes that's the way it is. Annoying but manageable. I believe the entire Python implementation was published prematurely. It's a really nice approach, what a pity that it's so buggy. When I play with Python, there is a steady flow of new bugs and oddities. So sad ![]() Having the hpprime module I think the graphic module is superfluous, the functions should be included in the hpprime module, with a streamlined structure of the function names and a help that clearly and correctly describes syntax and arguments. Günter |
12-02-2021, 05:46 PM
The graphic module is the same as in KhiCAS for the TI Nspire CX/CX2, Numworks and Xcas MicroPython. It uses the drawing routines from the CAS, that were implemented because they were not available on other calculators. Some command names are synonyms of Numworks kandinsky module commands (this explains some redundancy). Some commands are not available or will not work on the Prime because I lacked time to do that properly with Cyrille. Some commands will not do anything, they are here so that you can run the same Python program on the HP Prime, TI Nspire CX/CX2 or Numworks and Xcas, something you won't be able to do with commands of the hpprime module.
A few comments: 1/ draw_rectangle is a synonym of fill_rectangle for some reasons explained above, you can use draw_polygon for an unfilled rectangle. 2/ if fill_arc has a 8th argument, then it is assumed you want to fill a segment of circle instead of an arc. The source code of the graphic module of Xcas is available in the giac source code (giac-1.7.0/micropython-1.12/xcas/graphic.c and numworks, nspire, ports/javascript for the Numworks and emscripten JS ports), feel free to propose enhancements! |
12-02-2021, 09:14 PM
Merci Bernhard for these explanations.
That leaves just two real bugs in the graphics module. Firstly complete lack of documentation and secondly the draw_arc() function where the values of the angles are doubled. Interesting concept to provide a programming language with functions that are supposed to either work or not without telling ... How much time I could have saved if something like your explanations was available beforehand. But I assume that's not your responsibility. There was a Beta-testing period after Python was introduced, and I sincerely intended to thoroughly report my findings. But after a short while I gave up. As mentioned above "A steady flow of new bugs and oddities " and let's add: reboot, reboot, reboot ... How comes that almost no programs for the Prime using Python are published yet ![]() Again, most probably not your business. Günter |
12-02-2021, 09:31 PM
(This post was last modified: 12-02-2021 09:32 PM by parisse.)
draw_arc seems to work correctly on the nspire, it seems therefore that it is a Prime-specific problem, that should make it easier to fix.
12-04-2021, 07:35 PM
Can you confirm that this fails on the Prime:
Xcas session |
12-04-2021, 09:43 PM
(This post was last modified: 12-04-2021 09:47 PM by Guenter Schink.)
As previously described, the filled arc draws o.k. filled black. The unfilled arc draws from 60° (2*30) to 180° (2*90)
to ensure we are talking about the same, I cite the proposed code: Code: from graphic import * Günter Edit: added the proposed code snipped |
12-05-2021, 09:13 AM
Then both draw_arc and draw_filled_arc are wrong, cf. the Xcas session (or test the same code on the Nspire CX/CX2 and Numworks). Angles should be mesured in degrees counterclockwise (and 0 degree is oriented to the right). Moreover only the arc should be drawn.
There is something wrong in the C code that calls the Prime corresponding commands from the graphic MicroPython module : I guess Cyrille did call his own functions, unlike on Xcas/Nspire/Numworks where I call CAS graphic functions. |
12-05-2021, 10:41 AM
I've found where the bugs are. As I guessed, it is in the Prime-specific implementation: c_draw_arc and c_draw_filled_arc both calls a method FillArc, draw_arc with angles theta1*4096/M_PI, theta2*4096/M_PI and c_draw_filled_arc with theta1_deg*4096/360, theta2_deg*4096/360.
Arguments for the first FillArc should be -theta1*2048/M_PI and -theta2*2048/M_PI and for the second one arguments should be negated. And the angles should probably be exchanged, FillArc seems to work with some specific angle unit (4096=2*pi radians) and clockwise. |
12-05-2021, 10:44 PM
I really appreciate you spending your time on this issue. Because I believe to know how much Cyrille and Tim are constrained in their work , I can't rant as I usually would about that ppp of HP.
Günter |
