matplotlib.pyplot library in FX-CG50 Vs Graph 90+E
12-06-2021, 03:34 AM
I have the FX-CG50 model with the latest OS version 03.60.0202, but the matplotlib.pyplot library is not available in python:
But in the "Graph 90 + E" version, if it is available.
Why the difference, I understand that both models are identical.?
Catalog FX-CG50
[Image: catalog.png]
Catalog "Graph 90+E"
[Image: catalogo-Graph90-E.png]
The TURTLE library is not available either
12-06-2021, 03:44 AM (This post was last modified: 12-06-2021 04:04 AM by toml_12953.)
RE: matplotlib.pyplot library in FX-CG50 Vs Graph 90+E
(12-06-2021 03:34 AM)Mariox Wrote:  I have the FX-CG50 model with the latest OS version 03.60.0202, but the matplotlib.pyplot library is not available in python:
The latest OS update (3.60) for the French versions of the FX-CG50 does have both libraries.
https://edu.casio.com/download_service/e...index.html
For other markets, you can download both libraries from tiplanet.org
turtle.py: https://tiplanet.org/forum/archives_voir.php?id=2648501
matplotlib.pyplot: https://tiplanet.org/forum/archives_voir.php?id=2648498
Tom L
Cui bono?
12-06-2021, 05:08 AM
Thanks for the info.
And as I do to download the French update, in the country I select France, but I always download the file that I already use and it does not bring those libraries.
12-09-2021, 06:06 PM
The updating software does detect your calculator model and then installs different firmware images based upon what has been detected :
  • the one with matplotlib and turtle if it's a Graph 90+E
  • the one without matplotlib and turtle if it's an fx-CG50
The only way so far for the fx-CG50 is to download matplotlib and turtle separately and install them manually.
User(s) browsing this thread: 5 Guest(s)
