Charging HP Prime
12-06-2021, 12:02 PM
Charging HP Prime
I had my HP Prime plugged in during a 2 hour train journey, plugged in a USB power outlet on the train, which charged my modern smart phone in 20 mins. The screen on the HP Prime stayed lit throughout the journey with the lightning symbol over the battery.
I got home a day later and turned on the calculator, and it was giving me warnings about needing to charge as the battery was at a critically low level.
I assume something caused it not to charge correctly on the train.
I then had to charge my calculator at bed time last night, but I have found that it does not charge unless the device is turned on, and therefore the screen is on. Obviously charging overnight, I would rather that I could charge with the screen off.
Should I have to charge with the screen on, or should this HP Prime G2 charge from a 2.1A mains adapter when plugged in, and not turned on?
Thanks for any help.
12-08-2021, 01:55 AM
RE: Charging HP Prime
The calc has to power on and boot up, which should happen when you connect the USB.
But perhaps it only does that when there's a data connection, and not just from a dumb charger?
See these posts:
http://www.hpmuseum.org/forum/thread-116...#pid106529
https://www.hpmuseum.org/forum/thread-13...#pid123256
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 71B 17B/BII/bII+ 28S 42S/DM42 32SII 48GX 50g 35s 30b/WP34S Prime G2
& Casios, Rockwell 18R :)
