Looking for survey program for HP-15C
12-11-2021, 08:03 PM
Hi all and greetings from Canada.
I'm on the hunt for a simple survey program for HP15C. I used to work in the surveying field several years ago and we used a 15C or 11C for calculations and traverse/inverse/areas for simple lot closures. I remember that the program was just over 100 program steps. also, I remember that to start the program I would do the following to set N and E to 0 . ( 0, ENT, 0, FCN, A ) which would set the N and E to zero. to run traverse, you would do the following for each leg of your traverse. enter bearing, R/S, enter quadrant , R/S, enter distance, R/S, N is displayed, R/S, E is displayed. Once you do your closed traverse, RCL, 3 would give your area in S.F. to inverse from original point: ( bearing ) RCL , 5, enter, RCL 4, divide, inv, tan, fcn, hms to inverse from original point: ( distance ) RCL 4, sq, ENT, RCL 5, sq, +, sq rt any help in finding this program again would be greatly appreciated. Ron |
12-12-2021, 01:44 AM
(This post was last modified: 12-12-2021 02:22 AM by MNH.)
RE: Looking for survey program for HP-15C
(12-11-2021 08:03 PM)scoobieshouse Wrote: I'm on the hunt for a simple survey program for HP15C. The website below might help you. https://surveyorconnect.com/community/so...alculator/ The traverse/inverse/areas programs you want sound easy to write. There's plenty of help available on this website to get you started! |
