Display at DM42
12-12-2021, 04:16 PM
Display at DM42
Hi togehter,
first please do not be afraid for my English. It is really bad! Not one question: How can I control the display of the DM42 is the Order tp show for example only the Result of my calculation ? I have Write a little Program for calculation the Power, Vortage, Current, cos phi and Resident for a 3 angle circuit. You gut in the known values and the Program calculate the unknown value. So in this case I want to show all values at the same time. Is this possible ?? greatings from Germany |
12-13-2021, 10:35 AM
(This post was last modified: 12-13-2021 10:35 AM by OlidaBel.)
RE: Display at DM42
Hi.
I did not understand anything. :-( I'm french speaking. Maybe you can find some help on translate.google.de page. It gives a good basis translation if necessary. --- HP 48GX, Prime G2, 50G, 28S, 15c CE. SwissMicros DM42, DM15L A long time ago : 11C, 15C, 28C. |
12-13-2021, 01:46 PM
RE: Display at DM42
Hi, here a Translation :
Hello everyone I have a question: Is it possible to use the display of the DM42 completely for messages etc? I have written a program with which you can perform three-phase calculations. I want to display all the values on the display after the calculations: Eg: P = 1200W ; I = 2A U = 400V ; cos phi = 0.987 |
12-13-2021, 03:19 PM
RE: Display at DM42
So, you want the results to be presented using the 4-row display.
May I suggest that you calculate each value, and place then in 4 different memories. When the calculation are done, recall the 4 values. They will be stacked in the display in the recall order. You wanted to calculate 5 values, then you must use the "Stack layout" or the "Dynamic stack extension" function, and scroll the results. See DM42 manual, chapter 5.5.7 and 5.5.8. The manuals can be found here: https://technical.swissmicros.com/dm42/d...anual.html Do you want a text to preced the value. Then it is trickier. I am not aware if you can recall both a text string AND a value to the display. Hopefully the 42-gurus will give you a simple answer! Please VOA, please BBC, please Deutche Welle.... Don't surrender the shortwave bands to China Radio International. |
12-13-2021, 03:24 PM
(This post was last modified: 12-13-2021 03:25 PM by dxaren.)
RE: Display at DM42
Yepp. You can display both text and values like "Power W = 1500".
Check page 68 in the manual: https://literature.hpcalc.org/community/...rog-en.pdf Please VOA, please BBC, please Deutche Welle.... Don't surrender the shortwave bands to China Radio International. |
12-13-2021, 03:52 PM
RE: Display at DM42
Hi Together:
Thanks first for Info . Yes, I can display two line with the Result, but I want to display four lines !!! e.g. P=1200W U=400V cos phi = 0.987 I=2A R=240Ohm |
12-13-2021, 04:10 PM
RE: Display at DM42 | |||
12-13-2021, 04:51 PM
RE: Display at DM42
WOW !!!!
That´s it !!!! Thank you very much !!!!! Stay health and greetings from Germany !! |
12-13-2021, 09:18 PM
RE: Display at DM42
And of course,
Shorts waves belongs to evervbody ! |
12-20-2021, 05:54 PM
RE: Display at DM42
This are the result for my little project .
If program need, please contact me |
