Connecting Prime to USB 3 port on Windows 10 PC.
12-17-2021, 11:26 AM
(This post was last modified: 12-17-2021 11:33 AM by matalog.)
I was using my work computer today, to see if the new December Firmware had made it to the connectivity Kit yet, so I connected the Prime G2, and started the Con Kit, and the calc didn't make the USB connection sound, and the CK didn't see it either. It didn't appear in USBDeview.
Does the Prime not connect correctly through a USB 3.0 port? I then went to another older Windows 10 PC and connected it to the USB 2 port and installed connectivity kit and it recognised the same G2 without problem. |
12-17-2021, 01:11 PM
RE: Connecting Prime to USB 3 port on Windows 10 PC.
Alternatively, a usb2 hub plugged into the usb3 should work.
Stephen Lewkowicz (G1CMZ) |
