Ehrenfest's urn
12-29-2021, 10:16 PM
Ehrenfest's urn
Ehrenfest's urn
Hi Everyone (from France )
I'm trying this algorythm on my prime without success , of course i've tried to debug .
EXPORT EHRENFEST1()
LOCAL n,p,K;
INPUT(p);
L1:={1,2};
L2:={};
FOR K FROM 1 TO p DO
n:=RANDINT(1,2);
IF L1(1)==n OR L1(2)==n THEN
L1:=SUPPRESS(L1,n);
L2:=INSERT(L2,1,n);
ELSE
L2:=SUPPRESS(L2,n);
L1:=INSERT(L1,1,n);
PRINT(L1);
PRINT(L2);
Could you help me ?
It seems that the problem occurs when i write " n:=RANDINT(1,2); " .
Thank you .
12-29-2021, 11:11 PM
RE: Ehrenfest's urn
(12-29-2021 10:16 PM)zahi48g Wrote:  Ehrenfest's urn
EXPORT EHRENFEST1()
LOCAL n,p,K;
INPUT(p);
L1:={1,2};
L2:={};
n:=RANDINT(1,2);
L1:=SUPPRESS(L1,n);
L2:=INSERT(L2,1,n);
ELSE
L2:=SUPPRESS(L2,n);
L1:=INSERT(L1,1,n);
PRINT(L1);
PRINT(L2);
Could you help me ?
Thank you .
L2 only has one element. If n=2 you get an error when you try to SUPPRESS L2(n) since L2(2) doesn't exist.
Tom L
Cui bono?
12-29-2021, 11:53 PM
RE: Ehrenfest's urn
Hi
Thank you for replying.
First , the algorithme is from a book, I've just translated it into the prime language .
Second , it does not try to remove L2(2) from L2 but n from L2 . According to the Ehrenfest'urns model an urn can be empty (this is anticipated in the IF...THEN...ELSE),
so L2(2) may not exist . I should have the following outcomes :
{1,2}
or
{1}
{2}
or
{1,2}
or
{2}
{1}
If you get these results , could copy and paste you code ?
Thank you .
12-30-2021, 05:28 AM
RE: Ehrenfest's urn
(12-29-2021 11:53 PM)zahi48g Wrote:  it does not try to remove L2(2) from L2 but n from L2 .
With SUPPRESS(L2,n) you are removing from L2 the element at the nth position, so if L2={2} then SUPRESS(L2,2) will fail because there is only one element in the list. The correct instruction to remove 2 from the list is SUPPRESS(L2,POS(L2,2))) which will remove 2 from the list whatever it’s position in the list.
(12-29-2021 11:53 PM)zahi48g Wrote:  If you get these results , could copy and paste you code ?
Here is a working code, I’ve added the number of elements in the urns as a parameter of the program so you can test with more than two:
EXPORT EHRENFEST1(N)
 LOCAL n,p,K;
 INPUT(p);
 L1:=MAKELIST(I,I,1,N);
 L2:={};
  n:=RANDINT(1,N);
  IF POS(L1,n) THEN
   L1:=SUPPRESS(L1,POS(L1,n));
   L2(0):=n;
  ELSE
   L2:=SUPPRESS(L2,POS(L2,n));
   L1(0):=n;
 PRINT(SORT(L1));
 PRINT(SORT(L2));
12-30-2021, 10:30 PM
RE: Ehrenfest's urn
Thanks for the interesting post, this problem is new to me.
Section 2.1 of this article suggests an alternate representation of the urns that may lead to a simpler program. Instead of two lists, one initially empty, one has a single list of (initially) all zeros. At each iteration, the state of a randomly selected element is flipped using NOT. The number of balls in urn "A" is the number of zeros in the list; the number of balls in urn "B" is similarly the number of ones.
My PPL is a bit rusty but it should be fairly simple.
01-03-2022, 11:10 PM (This post was last modified: 01-03-2022 11:17 PM by zahi48g.)
RE: Ehrenfest's urn
Thank you D Lachieze and John Keith.
I've learned two things : How to remove properly an object from a list
and that L1(0) refers to the last element of list L1 (am I right ?) .
But i've got one question for D Lachieze . In order to know if n belongs to L1, shouldn't you write
" IF POS(L1,n)>0 THEN ..." instead of " IF POS(L1,n) THEN ..." ?
Thank you
01-04-2022, 02:09 AM
RE: Ehrenfest's urn
(01-03-2022 11:10 PM)zahi48g Wrote:  Thank you D Lachieze and John Keith.
Thank you
Since false is 0 and the true condition is anything other than 0, either test works.
Tom L
Cui bono?
