Lambert function W0 for very big argument
01-17-2022, 02:32 PM
In exponential equations, it's not unusual to have to calculate W0(x) with a very big x, overflowing most of the calculators.
For example: Solve 2^x = 1000 - x
Solution is x = 1000 - W0(2^1000 * ln(2)) / ln(2) = approx. 9.9514, but for a calculator overflowing at 10^100, that's a problem.
So, here's the trick:
Usually, to calculate W(p) with p>0, you solve x * e^x - p = 0 for example with Newton's method, needing p as input:
Initial x = ln(p) - ln(ln(p)) for a W0 result (if p > 10)
iterate on x = (x * x + p * e^(-x)) / (x + 1) converging to x = W0(p)
But if p is very big, you can solve instead ln(x) +x - ln(p) = 0, needing ln(p) as input:
iterate on x = x * (1 - ln(x) + ln(p)) / (x + 1) converging to x = W0(p)
So, if you enter ln(p) in a way the calculator allows it, you'll get directly W0(p).
In the above example, you won't input 2^1000 * ln(2) but 1000 * ln(2) + ln(ln(2))
I made some little programs for calculating W0 et W-1 for the Casio fx-5800P and you can see them here: Eddie's Math and Calculator Blog
Thanks for reading
