HP41CX Function
01-21-2022, 02:06 PM
HP41CX Function
Hallo together,
I´m a new user of a DM41X . Now I have a problem : I miss some function, for example :MVAR How can I found this function ? |
01-21-2022, 05:52 PM
(This post was last modified: 01-21-2022 05:53 PM by Massimo Gnerucci.)
RE: HP41CX Function
(01-21-2022 02:06 PM)TEas08 Wrote: Hallo together, There's no MVAR on the HP/DM41, that's a 42S instruction. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-21-2022, 09:34 PM
RE: HP41CX Function
Ups, Sorry !!
You are right ! My failure...... |
01-23-2022, 05:08 PM
RE: HP41CX Function
Well, if you're adventurous enough you may want to check the Equation Solver Module, which indeed contains a couple of MVARS functions...
http://www.systemyde.com/hp41/documents.html specifically: http://www.systemyde.com/pdf/Equation_Solver_3AB.pdf "To live or die by your own sword one must first learn to wield it aptly." |
