[VA] SRC #010 - Pi Day 2022 Special
03-14-2022, 08:03 PM
Today it's March, 14 aka \(\pi\) Day, so Happy \(\pi\) Day to all of you !, and
Welcome to my SRC #010 - \(\pi\) Day 2022 Special, intended to once again commemorate this most famous of constants, \(\pi\).
After posting many threads over the years about \(\pi\), it would seem difficult to find new, interesting appearances of it but actually that's not the case at all, \(\pi\) is inexhaustible and to prove the point let me introduce a new appearance for your enjoyment. Here you are !:
    Note: Unlike some previous SRCs, this one is not intended as a challenge to the readers to produce results on their own. Instead, this will be article-like: Here I give outright all the details and my commented results (which were obtained by my own original research, so they've never been available anywhere on the Internet so far), and you can read and enjoy them at once without delay. Come to that, you might try to reproduce and even expand my results using your own calcs if you feel like it. But you saw them here first ! Smile
An unexpected infinite product for \(\pi\) and related questions.
Consider this infinite product P(x), for 0 ≤ x < ∞ :
    [Image: SRC10AKSD2SAJ4KLUJR.jpg]
Now let me answer the following 4 Questions 4 by first writing a little bit of RPN code for a programmable HP calc, and then using it to do some sleuthing. For speed and accuracy considerations I'll use an ancient version 2.2 (2019) of Free42 without using any of its extended instruction set, so that the code will run unmodified in a physical HP-42S (albeit at reduced speed and accuracy).
First of all, I need to write code to evaluate P(x), and as I can't use an infinite number of terms, I'll store the number of terms to use, N, in variable "N" so that I'll be able to see how it does affect the accuracy of the results obtained, which will prove useful for the sleuthing afterwards.
Thus, this 46-byte program will evaluate P(x) for a given x, assuming that the number N of terms to use has been previously stored in variable "N"
      01  LBL "PX"    10  1          19  STOx 03
      02  STO 02      11  RCL 00     20  DSE 00
      03  RCL "N"     12  X^2        21  DSE 04
      04  STO 00      13  STO 01     22  GTO 00
      05  STO 04      14  1/X        23  RCL 02
      06  1           15  -          24  SQRT
      07  STO- 04     16  RCL 01     25  RCLx 02
      08  STO 03      17  Y^X        26  RCLx 03
      09  LBL 00      18  RCLx 02    27  END
Let's try computing a few values with PX using just N = 10 terms, for speed. We get, for instance:
      FIX 6, 10, STO "N", 1, XEQ "PX" -> 0.000091 ... etc., ...
      _________________________________________________
         N        x = 1         x = 2         x = 3
        10
      0.000091      0.131395      9.279782
The Four Questions
a.  Is there a value of x for which P(x) equals \(\pi\) ?
    To answer this question I'll first create a wrapper program and then use the [SOLVER] to solve the equation:
        [Image: SRC10B7RJEKR6PMNQB.jpg]
    The wrapper program is this trivial 23-byte piece of code:
          01  LBL "PXEQ"      05  XEQ "PX"
          02  MVAR "N"        06  PI
          03  MVAR "X"        07  -
          04  RCL "X"         08  END
    and solving for increasing values of N = 10, 100, 1000, 10000 , we get:
          FIX 8, SOLVER -> Select Solve Program, [PXEQ],
          10, [N][X] -> 2.70596645, 100, [N][X] ->
    ... etc., ...
             N         x
            10
           2.70596645
            100      2.71814726
            1000     2.71828047
            10000    2.71828181
    and it's fairly obvious to any math-inclined person that the root is clearly converging to e = 2.718281828..., the base of the natural logarithms and its inverse, the exponential function, which is thus the answer to the first Question, and so we have the promised unexpected infinite product for \(\pi\) announced in the title, the awesome expression:
        [Image: SRC10CSAJVKEBF3U9FD.jpg]
    which beautifully relates \(\pi\) and e. Now, if you remember my last year's SRC #009, I gave there a "trick" expression for \(\pi\) as a function of e, namely:
          \(\pi\) = 4 * ( Arctan e - Arctan \(\frac{e   -   1}{e   +   1}\) )
    the catch being that e isn't necessary here at all, an infinity of other values will do, e.g. your age, or your phone number, or your friend's. Can't it be the same case here, that the above infinite product P(x) will evaluate to \(\pi\) for arguments x other than e ? This leads me to the second Question ...
b.  We know now that P(e) = \(\pi\). Are there any other such arguments or is e unique ?
    In order to answer this question, I'll do some sleuthing after reformulating it as two other related questions, namely:
    • What's the value of P(x < e) ?
    • What's the value of P(x > e) ?
    Well, using the PX program above for various increasing values of N = 10, 100, 1000, 10000, we get the following, in SCI 4:
          ________________________________________________________________________________​____
             N        x = 1         x = 2         x = 2.7     x = e    x = 2.8      x = 3
            10      9.0733E-5     1.3140E-1     3.0696E0    3.2950E0  4.4970E0    9.2798E0
            100     7.1239E-44    1.2771E-13    1.6024E0    3.1573E0  6.1958E1    6.3592E4
            1000    9.6769E-435   1.4664E-133   3.6744E-3   3.1432E0  2.3300E13   2.2159E43
            10000   2.1637E-4343  6.1049E-1333  1.5436E-29  3.1417E0  1.3775E129  6.1138E428
    and we can clearly see that for arguments x < e the value of P(x) goes to 0, while for arguments x > e it goes to , so the answer to the second question is:
          e  is indeed the only argument which makes this infinite product evaluate to \(\pi\).
    Just for fun, if you own some HP calc which has graphics capabilities, try plotting P(x) for x = 0 to 2*e in steps of e/10, for various values of N (say, 10, 100, 1000, ...). Post a screen capture of the plot, if possible. That said, time for third Question ...
c.  Now, fixing x as e, the question is: How many correct digits of \(\pi\) (give or take a few ulps) do we get when using N = 10, 100, 1000, ..., terms ?
    To help answer this question, and to speed the computation, now that x is not an argument anymore because it's fixed as e, I've written a new version of PX, a 59-byte program now called PN because it only depends on the number of terms, N, and also optimized for speed by displaying a Wait... message while the program runs (avoids the scrolling symbol) and using stack registers, not as easy to understand as PX but faster:
        01  LBL "PN"    10  E^X        19  X^2         28  X<> ST T
        02  "Wait..."   11  ENTER      20  ENTER       29  ISG ST Y
        03  AVIEW       12  SQRT       21  1/X         30  LBL 00
        04  STO 03      13  RCLx ST Y  22  RCL- 00     31  DSE 02
        05  STO 02      14  STO 01     23  +/-         32  GTO 00
        06  2           15  Rv         24  X<>Y        33  CLST
        07  1           16  LBL 00     25  Y^X         34  CLD
        08  STO 00      17  X<>Y       26  RCLx ST T   35  RCL 01
        09  STO- 02     18  ENTER      27  STOx 01     36  END
    Let's use it to obtain these data, in FIX 5 :
        FIX 5, 10, XEQ "PN" -> 3.29501
    ... etc., ...
         N             PN
        10           3.29501
        100          3.15726
        1000         3.14316
        10000        3.14175
        100000       3.14161
        1000000      3.14159
    My program benefits from using Free42 Decimal's 34-digit precision, which helps cater for any cumulative rounding errors, and as can be seen PN does indeed converge very slowly to \(\pi\) as N goes to , and its value for N = 1,000,000 comes out as:
        [SHOW] (and hold) -> 3.14159 42243 85727 33446 22511 05879 403
    computed accurately to at least 27 digits or better, but giving an estimated value of \(\pi\) accurate to only 7 correct digits, save 2 units in the last place (ulp).
    Thus, we have that this infinite product computed to N terms does indeed converge to \(\pi\) but at an excruciatingly slow speed, needing a million terms to get just about 7 digits. And this brings us to the fourth and final Question: Can we do something about it ?
d.  Finally, the sleuthing part: Can we do something about the extremely slow convergence ?
      Note: I did my own original research so don't search the Internet for any of this 'cause it's not there, this is the first time this info appears on the Internet. It's not rocket science but no one published any of this before.
    To try and speed the convergence, first of all I went on to estimate the error, using PN to compute the following values and then subtracting \(\pi\) from each to obtain the errors, which I recognized as being very close to \(\pi\)/2 = 1.57079632679... divided by a million (i.e., N):
        ________________________________________________________________________________​____________________
           N        PN(N)                                       PN(N) - \(\pi\)           Observations
        999998    3.14159 42243 88868 93182 82237 27239 246   1.57079907569 E-6   = \(\pi\)/2 * 10.00001750003 E-7
        999999    3.14159 42243 87298 13157 44454 09443 986   1.57079750489 E-6   = \(\pi\)/2 * 10.00000750001 E-7
        1000000   3.14159 42243 85727 33446 22511 05879 403   1.57079593410 E-6   = \(\pi\)/2 *  9.99999750000 E-7
        1000001   3.14159 42243 84156 54049 16628 07700 354   1.57079436330 E-6   = \(\pi\)/2 *  9.99998750002 E-7
        1000002   3.14159 42243 82585 74966 25768 41450 776   1.57079279251 E-6   = \(\pi\)/2 *  9.99997750005 E-7
    thus, all the errors seem to be very close to \(\pi\)/2 * 1E-6, with the smallest one occurring for N = 1000000, where the error is \(\pi\)/2 * 9.99999750000 E-7. Noticing this, I then used \(\pi\)/2 * 1E-6 as a correction term to be applied to the computed PN(1000000), obtaining the following:
        PN(1000000) - \(\pi\)/2 * 1E-6 = 3.14159 26535 89400 53956 56318 74557 711
    and subtracting \(\pi\), the absolute error now is ~ 3.92699 E-13, which means we've got about 14 correct digits (save 4 ulp), where previously we had just 7 correct digits (save 2 ulp). In other words, applying this extremely simple correction term, \(\pi\)/2 * 1/N, essentially duplicates the number of correct digits.
    Can we do better ?  Yes, we can. Observing the errors using just PN(N) above for N = 999998 to N = 1000002, we notice that not only are they of the form
        \(\pi\)/2 * 1E-6 ~ \(\pi\)/2 * 1/N ,
    but the actual differences with respect to that value also have a very regular form:
        ..750003, ..750001, ..750000, ..750002, ..750005,
    which suggests a *second* correction term to cater for the ..75 difference. To cut to the chase, after a few trivial arithmetic operations the second correction term is immediately found to be in absolute value equal to \(\pi\)/2 * 1/(4*N2), and the corrected evaluation is now:
        \(\pi\) ~ PN(N) - \(\pi\)/2 * ( 1/N - 1/(4*N2) )
    and as \(\pi\) appears on both the LHS and the RHS, we proceed to isolate \(\pi\) at the LHS, which gives:
        \(\pi\) ~ PN(N) / ( 1 + 1/(2*N) - 1/(8*N2) )
    which, if desired, could be easily converted to the form  \(\pi\) ~ PN(N) * ( 1 - 1/(2*N) + 3/(8*N2) + ...) by polynomial division, but the above expression will do for now, as we do not have enough additional terms to do an accurate polynomial division anyway.
    This short additional code applies both correction terms to the output of PN(N). First, change 36 END to 36 STOP and then include after it the following lines:
          37  RCL 03       41  X^2      45  -     49  END
          38  RCL+ 03      42  8        46  1
          39  1/X          43  x        47  +
          40  RCL 03       44  1/X      48  /
    This adds just 17 bytes to PN and executes instantly but as we'll see in a moment, it greatly increases the number of correct digits. To use it, simply:
          N (number of terms), XEQ "PN" -> (shows computed PN(N) and pauses), R/S -> (shows corrected value)
    When particularized for N = 1,000,000, the corrected evaluation gives:
             PN(N) = 3.14159 42243 85727 33446 22511 05879 403 ( 7 correct digits save 2 ulp )
         Corrected = 3.14159 26535 89793 23864 73305...
                 \(\pi\) = 3.14159 26535 89793 23846 26433...
             Error ~ 1.84687 E-19 ( i.e. 20 correct digits save ~ 2 ulp )
    This means we've got essentially 20 correct digits using just two simple, inexpensive correction terms, while the original uncorrected PN(1000000) gave us only about 7 correct digits. Let's check the results for other values of N, for instance:
    • For N = 100,000:
               PN(N) = 3.14160 83615 13791 56287 28512 11516 805 ( 6 correct digits save 2 ulp )
           Corrected = 3.14159 26535 89793 52207...
                   \(\pi\) = 3.14159 26535 89793 23846...
               Error ~ 2.83612 E-16 ( 17 correct digits save 2 ulp )
    • For N = 10,000:
               PN(N) = 3.14174 97292 95765 50614 37729 49086 661 ( 5 correct digits save 2 ulp )
           Corrected = 3.14159 26535 90076 819...
                   \(\pi\) = 3.14159 26535 89793 238...
               Error ~ 2.83581 E-13 ( 14 correct digits save 3 ulp )
    And it seems that using the two correction terms we've obtained, we empirically have:
        New #correct digits = 3 * Old #correct digits - 1
    Thus, while using just one correction term duplicates the number of correct digits, using two correction terms essentially triples the precision obtained, i.e. :
        N = 10,000     (5 correct digits)  -> 3 * 5 - 1 = 14 correct digits
        N = 100,000    (6 correct digits)  -> 3 * 6 - 1 = 17 correct digits
        N = 1,000,000  (7 correct digits)  -> 3 * 7 - 1 = 20 correct digits
    and of course the number of correct digits could be increased even further by simply obtaining additional correction terms, either empirically as I've done here or better yet, analytically.
    Matter of fact, I've managed to obtain two additional terms empirically, but giving details here would make this already humongous exposition even much longer, so that's left as an exercise for the interested reader. Smile
That's all. Any and all constructive and on-topic comments are most welcome and appreciated.
V.
03-14-2022, 10:29 PM
RE: [VA] SRC #010 - Pi Day 2022 Special
Thank you Valentin, that is both unexpected and interesting. Indeed, thank you also for the reminder of that previous post.
My questions would be on the lines of
- why is this so? (It seems another unexpected connection between e and pi)
- how did you find it?
I'm also interested in this process of intuiting the correction terms. How sure can we be that what seem to be correct terms are in fact correct?
03-15-2022, 03:11 PM (This post was last modified: 03-18-2022 08:57 AM by Ángel Martin.)
Valentín, many thanks for the very interesting contribution, you've done it again !
As you guys know I'm "stuck" in the 41 world, which means can't really duplicate Valentín's results due to its "venerable"(read: severely limited) data precision/accuracy design: a 10-digit mantissa in user code definitely ain't going to cut it, and sure enough my FOCAL routines did not work at all.
I decided to give MCODE a chance to see how much of an improvement 3 additional digits would make, and interestingly enough it works, well sort of works because again, the benchmark is always up against the same barrier. The ink is still fresh, I *think* it's all correct but there may be errors...
For anyone who may care about the details, in the attached pdf you can see the MCODE listing for PPIE, based on Valentín's product formula plus adding the two correction factors. Cutting to the chase the final results show that the sweet spot appears for n=495 terms, which gives a 10-digit value of 3.141592703 , i.e. a delta of 1.55972E-08 (in percent absolute value) versus the 10-digit native pi value.
So on one hand the restrictions won't allow going much further, but at least it doesn't take an exorbitant number of terms to reach such "local optima", for the lack of a better definition (yes, I know: poor man's consolation at play...)
Here's the complete table with all logged results - note how things go south quite rapidly for N>500, which I can only attribute to the inadequate platform for this type of exercise - unless someone can spot other flaws to my reasoning?
n       result          |Delta|
10      3.157699001     0.005126809
100     3.141749935     5.00641E-05
200     3.14163147      1.23555E-05
300     3.141608481     5.03789E-06
400     3.141598986     2.01554E-06
450     3.141595562     9.25645E-07
475     3.141593955     4.14121E-07
480     3.141593627     3.09716E-07
490     3.141592941     9.13549E-08
494     3.141592753     3.15127E-08
495     3.141592703     1.55972E-08
496     3.141592601     1.68704E-08
500     3.141592352     9.61296E-08
505     3.141592156     1.58518E-07
510     3.141591874     2.48282E-07
550     3.141589274     1.07589E-06
600     3.141585534     2.26637E-06
800     3.141568893     7.56336E-06
900     3.141557011     1.13455E-05
1000    3.141540165     1.67078E-05
1010    3.141538781     1.71483E-05
1020    3.141537075     1.76913E-05
1050    3.141531634     1.94233E-05
1100    3.14152368      2.19551E-05
1200    3.14150274      2.86205E-05
1300    3.141478162     3.64439E-05
1500    3.141419233     5.52016E-05
2000    3.141179128     0.000131629
Anyway, thanks to Valentín for the opportunity to play around with this, I'm really enjoying it. It goes without saying that PPIE will make its way into the forthcoming PIE ROM, soon to be released.
Best,
ÁM
03-15-2022, 06:01 PM
Thanks, Valentín, I have found your post rather interesting and entertaining.
Perhaps many members of this forum would prefer that you give them a challenge rather than an article, but your challenges are typically way out of my reach, so I liked this article-style SRC.
I entered all your code in Free42 Decimal on my iPhone 11 and ran all the cases in your post, and a few more cases. As expected, everything worked fine and the program executions times were extremely fast, even for N=1,000,000.
Then I decided to try to run all the code in a physical HP-42S. What I found is that you can run PX and PN up to N=100 in relatively short times (seconds, not minutes). Even when using the solver with the wrapper program PXEQ, you can start with a small N value (say, N=10) to get a first estimate of X, and then gradually progress to higher N values (N=20, 50, 100), letting the resulting X value from the previous iteration be the initial guess of the next iteration. In that way, you get a relatively fast (in time) convergence, even for N=100.
All the results are still meaningful with N=100 on a physical HP-42S and the trends can be distinguished (results approaching e or Pi), even if the convergence of the infinite product function is very slow. The result of program PN with the correction terms added is surprisingly good for N=100, with an error of only 2.9e-7!
Now, I wonder if you would have been able to derive this function and the corrections terms, and to write a similar article back in 1988, using no computer and just a physical HP-42. Or do you absolutely need the speed and increased accuracy of Free42?
My guess is that you would have managed to make the same discovery in 1988 with a physical HP-42S, intuition, and a lot of patience. What do you think?
03-15-2022, 10:04 PM
(03-14-2022 08:03 PM)Valentin Albillo Wrote:  the awesome expression:
Below confirmed expression numerically, by turning sum to integral.
ln(pi)
= 3/2 + sum(1 + n^2 * ln(1 - 1/n^2), n = 2 .. inf)
= 3/2 + sum(1 - n^2 * ((1/n)^2 + (1/n)^4/2 + (1/n)^6/3 + (1/n)^8/4 + ...), n=2 .. inf)
= (1-ζ(0)) + (1-ζ(2))/2 + (1-ζ(4))/3 + (1-ζ(6))/4 + ...             // note: ζ(0) = -1/2
Zeta even integer generating function:
[Image: 299515039add35d008819931732e368c53c2f5d4]
Replacing x by √x, and integrate from 0 to 1, we matched zeta terms.
We also need to add a function, to match fraction terms.
1/(1-x) = 1 + x + x^2 + ...
∫(1/(1-x), x=0..1) = 1 + 1/2 + 1/3 + ...
\(\displaystyle \ln(\pi) =
\int_0^1 \left(\frac{1}{1-x} + \frac{\pi\sqrt{x}}{2\;\tan(\pi\sqrt{x})}\right) dx\)
Note that integrand is inaccurate when x approach 1. P cannot be set too small.
10 P=.000001
20 DEF FNF(X,Y)=1/(1-X)+.5*Y/TAN(Y)
30 DISP INTEGRAL(0,1,P,FNF(IVAR,PI*SQRT(IVAR))), EXP(RES)
>RUN
1.14472988295       3.14159264448
03-16-2022, 08:50 AM
Thanks Valentin for this interesting reading. Relations between pi and e always intrigued me.
(03-15-2022 03:11 PM)Ángel Martin Wrote:  As you guys know I'm "stuck" in the 41 world [...] and sure enough my FOCAL routines did not work at all.
Really? HP-41 user code can't do it?
Let's see:
Maybe it's better to transform Valentin's expression with log and then compute the exponential at the end.
Using pseudo algebraic language (I'm not comfortable with graphic equation editors), with ln as the natural log:
PN = exp(3/2) * Prod(n=2,N,e*(1-1/n²)^n²) / (1+1/(2*N)-1/(8*N²))
becomes
ln(PN) = 3/2 + Sum(n=2,N,1+n²*ln(1-1/n²)) - ln(1+1/(2*N)-1/(8*N²))
e doesn't appear explicitly any more, but of course it does at the end when computing exp(ln(PN)).
Here is the corresponding HP-41/42 program, using the here highly useful LN1+X function that preserves the accuracy for small 1/n² quantities to some extend:
01*LBL "PN2"
02 "RUNNING"
03 AVIEW
04 STO 00 ; N
05 1
06 -
07 STO 01 ; control loop 1..N-1
08 0
09*LBL 00 ; sum loop <---
10 RCL 01
11 1
12 + ; n=2..N
13 X^2
14 ENTER^
15 1/X
16 CHS
17 LN1+X
18 *
19 1
20 +
21 +
22 DSE 01
23 GTO 00 ; sum endloop --^
24 RCL 00
25 2
26 *
27 1/X
28 RCL 00
29 X^2
30 8
31 *
32 1/X
33 -
34 LN1+X ; correction factor
35 -
36*LBL 01 ; final result
37 1.5
38 +
39 E^X
40 CLD
41 END
and results for the HP-41:
10.00000000 RUN
RUNNING
3.141844397 ***
100.0000000 RUN
RUNNING
3.141592946 ***
200.0000000 RUN
RUNNING
3.141592701 ***
300.0000000 RUN
RUNNING
3.141592670 ***
400.0000000 RUN
RUNNING
3.141592651 *** best result
500.0000000 RUN
RUNNING
3.141592685 ***
Not bad for this ancient 10-digit machine, isn't it?
So thanks again Valentin for this contribution to the fascinating pi, and Ángel for giving me the opportunity to write a HP-41 code, something I'm rarely doing - I'm a HP-71B man - but the HP-41 language is so deeply buried in my mind since 40 years that it was very natural.
J-F
03-16-2022, 10:30 AM (This post was last modified: 03-16-2022 10:37 AM by Ángel Martin.)
(03-16-2022 08:50 AM)J-F Garnier Wrote:  Thanks Valentin for this interesting reading. Relations between pi and e always intrigued me.
Well, that's not quite what I said - I stated that "my" routines didn't work, as I was slavishly porting Valentín's HP-42 code directly - a big booooo to me ;-)
So many thanks for your new routine, very clever and good example of the platform capabilities when you know what you're doing with it.
I'm however curious: how does it respond for higher number of terms, say 10,000 or even 100,000? That's where the rubber meets the road, methinks.
Honestly I've come to the point that it's easier for me to go straight into MCODE than sleuthing around the FOCAL dustbin in search for better games, I confess.
Best,
ÁM
03-16-2022, 11:49 AM (This post was last modified: 03-16-2022 11:53 AM by J-F Garnier.)
(03-16-2022 10:30 AM)Ángel Martin Wrote:  I'm however curious: how does it respond for higher number of terms, say 10,000 or even 100,000? That's where the rubber meets the road, methinks.
With the HP41, the best results are obtained with N around 400. The accuracy starts to decline after 500, as you noted too.
I guess the reason is the accuracy of the ln(1-1/n²) quantity even with the LN1+X function.
ln(1+x) is about x-x²/2+... and with 10 digits the term (1/n²)² starts to get inaccurate (relative to 1/n²) when n is in range of 1000 or so.
When switching to the Free42 platform, I got similar (and not identical) results to Valentin's program, however without improving the accuracy of the corrected value.
For instance:
N=1E5, w/o correction:
VA : 3.14160 83615 13791 56287 28512 11516 805
JFG: 3.14160 83615 13791 56287 28668 95754 789
N=1E5, w/ correction:
VA : 3.14159 26535 89793 52207..
JFG: 3.14159 26535 89793 52207..
I guess that at N=1E5, we are still far from the limits of Free42 accuracy.
J-F
03-16-2022, 08:49 PM (This post was last modified: 03-17-2022 12:58 PM by Albert Chan.)
(03-15-2022 10:04 PM)Albert Chan Wrote:  \(\displaystyle \ln(\pi) =
To improve accuracy, lets remove square roots, x = y^2, dx = 2y dy
g(y) = (1/(1-y^2) + pi*y/2/tan(pi*y)) * 2y
       = -1/(y+1) - 1/(y-1) + pi*y^2/tan(pi*y)
Since tan(pi*(1-y)) = -tan(pi*y), we might as well fold the area.
∫(g(y), y=0..1) = ∫(g(y) + g(1-y), y=0..1/2)
\(\displaystyle \ln(\pi) = \int_0^{1/2} \left(
\frac{-1}{y+1} + \frac{1}{y-2}
+ \frac{-1}{y-1} + \frac{1}{y}
+ \frac{\pi (2y-1)}{\tan(\pi y)}
\right) dy\)
H(y) = ∫(-1/(y+1) + 1/(y-2) - 1/(y-1) dy = -ln|y+1| + ln|y-2| - ln|y-1|
H(1/2) = -ln(3/2) + ln(3/2) - ln(1/2) = ln(2)
H(0) = -ln(1) + ln(2) - ln(1) = ln(2)
With H(1/2) - H(0) = 0, we can remove integrand first 3 terms. Smile
\frac{1}{y} + \frac{\pi (2y-1)}{\tan(\pi y)}
\right) dy\)
Let's compare the 2 versions.
10 P=1E-6
30 DISP INTEGRAL(0,1,P,FNF(IVAR,PI*SQRT(IVAR))),EXP(RES)
40 DEF FNG(Y)=1/Y+PI*(2*Y-1)/TAN(PI*Y)
50 DISP INTEGRAL(0,.5,P,FNG(IVAR)),EXP(RES)
>RUN
1.14472988584       3.14159265356
>LOG(PI), PI
1.14472988585       3.14159265359
03-17-2022, 02:54 PM (This post was last modified: 03-17-2022 03:24 PM by Albert Chan.)
(03-16-2022 08:49 PM)Albert Chan Wrote:  \(\displaystyle \ln(\pi) = \int_0^{1/2} \left(
\right) dy\)
Wolfram Alpha proved this, with closed-form anti-derivative !
def G(y):
    k = pi*j
    z = exp(2*k*y)
    return ln(y) - ln(sin(pi*y)) + y*(2*log1p(-z)-k*y) + polylog(2,z)/k
>>> from mpmath import *
>>> limit(G,1/2) - limit(G,0)
mpc(real='1.1447298858494002', imag='0.0')
>>> exp(_)
mpc(real='3.1415926535897931', imag='0.0')
OP product form, which integral was derived from, is thus proved.
03-17-2022, 06:22 PM (This post was last modified: 03-17-2022 09:24 PM by Albert Chan.)
(03-14-2022 10:29 PM)EdS2 Wrote:  I'm also interested in this process of intuiting the correction terms.
We can get correction term symbolically, to be "sure"
Correction term = product(e*(1-1/k^2)^(k^2), k=n+1 .. inf)
Instead of doing products, we sum the log's instead.
We estimate the size of correction using Euler-Maclaurin formula
XCAS> f := 1 + ln(1-1/x^2)*x^2
XCAS> c := int(f) - f/2 + f'/12 - f'''/720 :;
f = -x^-2/2 - x^-4/3 - x^-6/4 + ... ⇒ c(x = inf) = 0. No need to eval upper limit.
XCAS> C := exp(c)(x=n+1) :;       // PN/C ≈ pi
XCAS> series(C, n=inf, 7)
\(\displaystyle
1 + {1/2 \over n} - {1/8 \over n^2}
+ {13/144 \over n^3} - {77/1152 \over n^4}
+ {547/11520 \over n^5} - {13529/414720 \over n^6} + O\left({1\over n^7}\right)
Continued fraction with taylor series (n=inf) that matches C coefs: (N = 2n+1)
\(\Large C =
1 + \frac{1}{(N - {1 \over 2}) \;
- \frac{1}{{36 \over 17}N \;
+ \frac{1}{{1445 \over 419}N \;+\;...}}}\)
Or, based from continued fraction approximation of little c: (again, N = 2n+1)
\(\Large \ln(C) =
\frac{1}{N \;
- \frac{1}{{9 \over 5}N \;
+ \frac{1}{{125 \over 8}N \;+\;...}}}\)
03-17-2022, 08:10 PM (This post was last modified: 03-17-2022 08:11 PM by Gerson W. Barbosa.)
(03-17-2022 06:22 PM)Albert Chan Wrote:  Continued fraction with taylor series (n=inf) that matches above coefs:
\(\Large
1 + \frac{1}{(2n + {1 \over 2}) \;
- \frac{1}{{36 \over 17}*(2n+1) \;
+ \frac{1}{{1445 \over 419}*(2n+1)}}}\)
The following corrects the result to 3.1415926535 for n=500:
1+1/(2n+1/(2+1/(n+17/(18n+1/2))))
Too few terms to deduce a pattern if any, though.
03-18-2022, 12:25 AM
Hi, all,
Thanks to EdS2, Ángel Martín, Fernando del Rey, Albert Chan, J-F Garnier and Gerson W. Barbosa for your interest in my SRC #10. Here I'll address some of your questions, plus assorted additional comments:
EdS2 Wrote:I'm also interested in this process of intuiting the correction terms. How sure can we be that what seem to be correct terms are in fact correct ?
Using an empirical approach to find them, as I did here, you can never be completely sure that what you found is 100% correct because that would require a theoretical approach. It's the same with Pi itself: no matter how many digits you compute, you can never be 100% sure that Pi is a normal number, that requires theory to stablish.
However, after analyzing the first 16 trillion bits of Pi, the result is that the decision "Pi is not normal" has credibility 4.3497.10-3064, which makes it all but impossible, so Pi is all but certainly normal. Same here, after computing these correction factors using high enough precisión they're highly certain to be correct.
Ángel Martín Wrote:I decided to give MCODE a chance to see how much of an improvement 3 additional digits would make, and interestingly enough it works, well sort of works because again, the benchmark is always up against the same barrier.
It's quite brave of you to attempt the feat with the limited precision allowed by the HP-41 platform (10 digits to the user, 13 digits internally), but I see you pretty much succeeded within the unavoidable constraints of precision and speed.
Also, experimenting first with RPN versions (I refuse to call it the "F"-word, i.e. FOCAL) and then implementing it as an MCODE routine in such a short time span (a few hours from my OP), plus additionally creating high-quality documentation for the MCODE source code, is utterly unbelievable, you're incredible ! ... Wish you had "sticked" (archaic, I know Smile ) with the HP-71B platform instead ... Smile
As I said at the end of my OP, I self-quote:
    "Matter of fact, I've managed to obtain two additional terms empirically, but giving details here would make this already humongous exposition even much longer, so that's left as an exercise for the interested reader."
and for your benefit and anyone interested's, the additional two correction factors I found were:
    c3 = 13/(144 * N3) and c4 = - 77/(1152 * N4)
and the resulting Pi approximation becomes:
    Pi ~ PN(N) / ( 1 + 1/(2 * N) - 1/(8 * N2) + 13/(144 * N3) - 77/(1152 * N4) )
which, when updating my PN program to include them and running it on Free42 Decimal, gets me the following assorted results:
                   with 3 factors      with 4 factors
      N terms   :            100                 100
      PN(N)     :  3.15726162848       3.15726162848
      Corrected :  3.14159265152       3.14159265360
      Error     : -2.07468621147E-9    1.47418338373E-11
      Digits    :           ~ 10                12
      N terms   :          1,000               1,000
      PN(N)     :  3.14316305750         3.143163058
      Corrected :  3.14159265359         3.141592654
      Error     : -2.09731017621E-13     1.489942199E-16
      Digits    :           ~ 14                17
      N terms   :         10,000               10,000
      PN(N)     :  3.14174972930        3.14174972930
      Corrected :  3.14159265359        3.14159265359
      Error     : -2.09959513255E-17    1.49139164910E-21
      Digits    :           ~ 18                 22      (vs ~ 14 digits w/ 2 c.f.)
      N terms   :         -                    20,000
      PN(N)     :         -             3.14167119242
      Corrected :         -             3.14159265359
      Error     :         -             4.46023309170E-23
      Digits    :         -                      24
      N terms   :         -                    30,000
      PN(N)     :         -             3.14164501303
      Error     :         -             1.70263469640E-23
      Digits    :         -                      ~ 24
      N terms   :        100,000              100,000
      PN(N)     :  3.14160836151        3.14160836151
      Error     : -2.11550799992E-21   -1.56692427780E-23
      Digits    :           ~ 22                 24      ( vs ~ 17 digits w/ 2 c.f.)
      N terms   :        200,000               -
      PN(N)     :  3.14160050756               -
      Corrected :  3.14159265359               -
      Error     -2.58729643320E-23           -
      Digits    :           ~ 24               -
      N terms   :      1,000,000               -
      PN(N)     :  3.14159422439               -
      Error     : -9.89287385519E-20           -
      Digits    :           ~ 20               -
where we see the improvement afforded by using 3 and 4 correction factors, and we also see that the limits of the 34-digit accuracy provided by Free42 Decimal begin to take its toll. For instance, with N = 1,000,000, which gave us 20 decimal digits using just 2 factors, we would expect here to get improved accuracy when using all 4 c.f., yet we still get only 20 decimal digits and matter of fact the result obtained for N=200,000, i.e. five times less terms, is much better, obtaining ~ 24 digits instead of 20.
This is due to several limitations: (a) when using 1,000,000 terms in the product, we might lose some 6 or 7 digits just to rounding or truncation, so we aren't getting 34 correct digits for the product, more like 27 or 28 at best. (2) using 1,000,000 terms means that we're computing expressions like (1-10-12)^(1012), (1-10-18)^(1018) and (1-10-24)^(1024), for 2, 3 and 4 factors, respectively, and those are likely to exceed the accuracy achievable by using only 34 digits in their computation.
Note also the improvement afforded by using 4 c.f. instead of 3: the result using N = 20,000 terms with 4 c.f. has about the same precision (~ 24 correct digits) as using N = 200,000 terms with 3 c.f., a 10x speed improvement.
In short, Ángel, try to use these two additional correction factors but, if you don't get the desired expected, significant improvements, it might be the case that you're running against the limits of the HP-41 accuracy, as happened with Free42 Decimal above, and then it's just a case of finding the sweet spot and see if the additional terms do any good to achieve the sweetest one possible.
Fernando del Rey Wrote:Then I decided to try to run all the code in a physical HP-42S. What I found is that you can run PX and PN up to N=100 in relatively short times (seconds, not minutes). Even when using the solver with the wrapper program PXEQ, you can start with a small N value (say, N=10) to get a first estimate of X, and then gradually progress to higher N values (N=20, 50, 100), letting the resulting X value from the previous iteration be the initial guess of the next iteration. In that way, you get a relatively fast (in time) convergence, even for N=100.
Thanks for your interest, Fernando, and I like a lot that, apart from trying my code on Free42, you also ran it on a physical HP-42S, despite its precision and speed limitations. Your idea of using the result of the previous iteration as the initial guess of the next is rather clever, even if doing it in Free42, because the Solver gets rather slow for high N, as it's an iterative process which evaluates the product a sizable number of times. Well done ! Smile
Fernando del Rey Wrote:Now, I wonder if you would have been able to derive this function and the corrections terms, and to write a similar article back in 1988, using no computer and just a physical HP-42. [...] My guess is that you would have managed to make the same discovery in 1988 with a physical HP-42S, intuition, and a lot of patience. What do you think?
I (unmodestly) think that I would have managed back then. I wrote a number of multiprecision programs for both my HP-67 first and HP-41C afterwards, and it's pretty likely that I would have tried to compute the product and the first two correction terms when using N = 1,000 or more on the new, faster, much more capable (matrix operations, much larger RAM) HP-42S, it's just a matter of leaving the program running for as long as the batteries last. So, yes, I think it was doable in 1988.
Albert Chan Wrote:Below confirmed expression numerically, by turning sum to integral.
Very clever, to think of that, Albert Chan !
And without using XCAS no less, as you know that I don't like people using such tools in my challenges or articles because I want people to use their vintage HP calculators, as this is the Museum of HP calculators, not MathOverflow or Stack Overflow, so thanks for respecting my wishes, though I'm sure you were itching to use XCAS or Wolfram Alpha or something like that. Congratulations !
Jean-François Garnier Wrote:Thanks Valentin for this interesting reading. Relations between pi and e always intrigued me. [...] Maybe it's better to transform Valentin's expression with log and then compute the exponential at the end.
You're welcome and yes, I know that you're fond of Pi-e relationships, me too ! And your idea of taking logs and then taking advantage of the built-in LN1+X function in order to enhance accuracy is brilliant, congratulations ! ... Perhaps Ángel might use it to achieve better results with its HP-41C MCODE version.
V.
03-18-2022, 08:48 AM (This post was last modified: 03-19-2022 08:31 AM by Ángel Martin.)
(03-18-2022 12:25 AM)Valentin Albillo Wrote:  In short, Ángel, try to use these two additional correction factors but, if you don't get the desired expected, significant improvements, it might be the case that you're running against the limits of the HP-41 accuracy, as happened with Free42 Decimal above, and then it's just a case of finding the sweet spot and see if the additional terms do any good to achieve the sweetest one possible.
Indeed the two additional correction factors make a huge difference: once added to the code the sweet spot for 10-digit pi now occurs with N=35 terms, giving the "exact" same value returned by the native "PI" function, i.e. 3.141592654.
Here's the new table for your reference: (also includes the execution time using a default settings on V41, definitely not TURBO mode)
n       result          |Delta%|        Time
5       3.141630979    1.21992E-05    0.000174
10      3.141593984    4.23352E-07    0.000297
15      3.141592834    5.72958E-08    0.000438
20      3.141592696    1.3369E-08    0.000568
25      3.141592666    3.81972E-09    0.000698
30      3.141592658    1.27324E-09    0.000829
35      3.141592654    0               0.00096
40      3.141592652    6.3662E-10      0.001088
45      3.141592651    9.5493E-10      0.001219
50      3.14159265      1.27324E-09     0.001337
55      3.141592648     1.90986E-09     0.001468
60      3.141592644     3.1831E-09      0.001606
What a difference!
BTW the previous version had a glitch that shifted the number of terms by one, now duly corrected. This is now old history but it skewed the results in about 50-60 terms due to cumulative errors, but that's immaterial now with the new version posted here.
(03-18-2022 12:25 AM)Valentin Albillo Wrote:  ... And J-F Garnier's idea of taking logs and then taking advantage of the built-in LN1+X function in order to enhance accuracy is brilliant, congratulations ! ... Perhaps Ángel might use it to achieve better results with its HP-41C MCODE version.
Yes, I've changed the approach to using a summation instead of a product - even if in the MCODE realm there's not much of a difference at the end of the day: you may gain some accuracy in the sums (instead of multiplications) but you lose some in the final Log/Exp conversions. BTW, on the LN1+X, well such function exists for 10-digit accuracy but does not have a 13-digit counterpart - simply because it's not needed in MCODE, where we have access to the "real" things with calls to [LN13] and [ADDONE] of course.
Lovely end-game even on the 41, thanks again!
ÁM
"It's not the size of the wand but the skill of the wizard what counts"
Attached File(s)
.pdf  PPIE MCODE.pdf (Size: 872.04 KB / Downloads: 9)
03-18-2022, 04:22 PM
(03-18-2022 08:48 AM)Ángel Martin Wrote:  Yes, I've changed the approach to using a summation instead of a product - even if in the MCODE realm there's not much of a difference at the end of the day: you may gain some accuracy in the sums (instead of multiplications) but you lose some in the final Log/Exp conversions.
We don't notice the difference because correction is not strong enough.
Summing smallest term first, we would keep almost all good digits.
(03-16-2022 11:49 AM)J-F Garnier Wrote:  N=1E5, w/o correction:
Lets recover true PN, and compare errors of products vs exp(sum of logs)
PN = C*PI = exp(ln(C))*PI = expm1(ln(C))*PI + PI
(03-17-2022 06:22 PM)Albert Chan Wrote:  Or, based from continued fraction approximation of little c: (again, N = 2n+1)
\(\Large \ln(C) =
\frac{1}{N \;
Note that ln(C) is odd function. Rewrite ln(C) as polynomial of 1/N, we have:
\(\displaystyle
\ln(C) = \frac{1}{N}
+ \frac{5/9}{N^3}
+ \frac{13/45}{N^5}
+ \frac{127/315}{N^7}
- \frac{89/135}{N^9}
n = 1E5       // note: my n is JFG N
N = 2n+1 ⇒ N^7 ≈ 128E35 > 1E37
Free42: ln(C), summing to N^5 only (slight errors doesn't matter)
ln(C)       → 4.99997500019444277779222209722329e-6
E↑X-1      → 4.999987500090277109379748231267083e-6
PI * PI + → 3.141608361513791562872866895754895      // true PN
VA (products for PN) errors = 15,684,238,090 ULP             // O(n^2) error ?
JFG (log sum for PN) errors = 106 ULP
03-22-2022, 12:14 AM
Hi, all,
(03-18-2022 04:22 PM)Albert Chan Wrote:  Lets recover true PN, and compare errors of products vs exp(sum of logs) [...] Note that ln(C) is odd function. Rewrite ln(C) as polynomial of 1/N, we have:
\(\displaystyle
+ \frac{5/9}{N^3}
+ \frac{13/45}{N^5}
I must point out that this formal series of correction factors is asymptotic and divergent, i.e., its coefficients might be small and even decreasing for a while but eventually they grow bigger and bigger, both numerators and denominators, and thus can't be used to obtain arbitrary precision, as I explained in another case in post #27 of my Short & Sweet Math Challenge #24. Quoting myself from that post:
    The coefficients of the formal series for cin(x) and tin(x) can be obtained in a number of ways [...] but it's important to be aware that both formal series do not converge. In fact, their radius of convergence is 0 and thus they behave like asymptotic series, so you can't get arbitrarily accurate results by taking more and more terms, you must instead truncate the series after a certain number of terms to get the most accurate results. Using further terms only worsens the accuracy.
    Although at first sight the coefficients of the formal series for cin(x) and tin(x) seem to (slowly) get smaller and smaller, matter of fact they tend to grow ever bigger after a while, tending to infinity. For instance, for tin(x) we find that the smallest coefficient in absolute value is:
      Coeff37 = -0.000000000594338574503
    but afterwards we have, e.g.:
      Coeff101 = 0.0833756228055
      Coeff151 = 388536047335.239
      Coeff201 = 6555423874651256623811186991.51
      Coeff251 = -35365220492708296140377087748804440170254492009.57
The same happens in the present case: you can use a certain number of coefficients to improve accuracy up to the "sweet point" of maximum accuracy, but after that the accuracy quickly degrades and thus using more coefficients is useless and to be avoided.
Quote:PI * PI + → 3.141608361513791562872866895754895      // true PN
Regrettably, presently I have no software available to compute the product for n = 2 to n = 100,000 with high accuracy (say, to 100 digits) so I can't check for sure, but I find it somewhat hard to believe that my computation using the 34 digits afforded by Free42 Decimal would lose 11 digits in the process, I'd rather expect 6-7 digits lost at most.
Likewise, Jean-François Garnier computation of said product using logarithms performs about 100,000 multiplications, divisions (1/x) and logarithms (LN1+X) but only loses 3 digits ? Really ?
To settle down the question, if someone with access to Mathematica or some other arbitrary-precision software can compute the product for N=100,000 using 100 digits, say, or as many as necessary to ensure full 34 correct digits or more, and post here the resulting value I'd appreciate it. Thanks in advance.
V.
03-22-2022, 01:01 AM
\(\displaystyle
+ \frac{5/9}{N^3}
+ \frac{13/45}{N^5}
>>> mp.dps = 100
>>> pn = lambda n: exp(nsum(lambda x: 1+log1p(-1/(x*x))*x*x,[2,n]) + 1.5)
>>> n = mpf(100000)
>>> N = 2*n+1
>>> x = pn(n)
>>> print x
3.141608361513791562872866895754895278060325823725833279147116393910631517290786764227775828378244404
It does matched my 34-digits "true" PN.
ln(C) correction (terms upto 1/N^9) seems safe to use.
>>> err = lambda c: float(pi - x * exp(-c))
>>> err(13/(45*N**5) + 5/(9*N**3) + 1/N)
-9.8950471946808673e-38
>>> err(127/(315*N**7) + 13/(45*N**5) + 5/(9*N**3) + 1/N)
4.0449821226917704e-48
>>> err(-89/(135*N**9) + 127/(315*N**7) + 13/(45*N**5) + 5/(9*N**3) + 1/N)
-1.229817502771026e-57
03-22-2022, 10:47 AM
Honestly, I'm surprised by this result too, confirmed then by Albert.
I looked further and it may be an accuracy flaw in Free42. I will open an other thread to discuss it.
J-F
03-22-2022, 12:29 PM
It is not hard to see why for log sums, we have error O(√(n)
1 + log1p(-1/k^2) * k^2
= 1 - (k^-2 + k^-4/3 + k^-6/4 + ...) * k^2
= 1 - (1 + k^-2/3 + k^-4/4 + ...)
= -(k^-2/3 + k^-4/4 + ...)
Because of 1 in front, term errors are in orders of machine epsilon.
Worst case, we have errors of O(n).
But, because errors spread-out somewhat randomly, we have O(√n)
You might try sum terms from index of 2 to n, instead of in reverse.
I would guess you would produce similar sized error for PN
For products of factors, (1-1/k^2)^(k^2):
We expected base have errors, also in order of machine epsilon.
However, errors are not random, but clustered when k is huge.
Example, for 10-digits calculator, this is the rounded base.
b(k) = 1-1/k^2
b(99999) = 0.99999 99998 99998, rounded up
b(99998) = 0.99999 99998 99996, rounded up
b(82000) = 0.99999 99998 51279, *still* rounded up
(1+ε)^(n^2) = 1 + n^2 ε
Product of n-1 terms, we expected worst case errors of O(n^3)
Of course, errors are not totally skewed, we expected O(n^2+)
From previous post:
PN(n=1e5) errors = 15,684,238,090 ULP ≈ 1e5 ^ 2.04
Using ln(C) correction, "true" PN = 3.14159 42243 85727 33456 11796 83910 689
PN(n=1e6) errors = 98,928,578,031,286 ULP ≈ 1e6 ^ 2.33
03-22-2022, 06:59 PM (This post was last modified: 03-22-2022 07:20 PM by Valentin Albillo.)
(03-22-2022 12:29 PM)Albert Chan Wrote:  It is not hard to see why for log sums, we have error O(√(n) [...] You might try sum terms from index of 2 to n, instead of in reverse. I would guess you would produce similar sized error for PN
Thanks, Albert Chan, that explains a lot, and it also explains why I found it difficult to believe such big errors were possible while doing pretty basic arithmetic with 34-digit precision.
I reckoned that I would lose about 6-7 digits due to rounding/truncation but in the end, I was losing as much as 11 digits for N=100,000 (let alone for N=1,000,000) because the internal code used in Free42 for large integer exponents is seriously flawed. Serves me right for blindly trusting it ! Smile
And if it were only that ... there are other incredibly newbie-style, face palm errors in some Free42 math operations but I'll leave that for J-F Garnier's thread.
Regards.
V.
Edited to include a link to J-F's thread.
