1810-0146 replacement
03-17-2022, 07:47 PM
Hello! I recently acquired an HP-55. After some cleanup and TLC, reassembly, and a new battery pack it's working pretty well now, except for one issue - no decimal points will illuminate. All other display aspects are fine; the segments & digits are all well behaved. I did some reading up (ClassicNotes.PDF) and suspect the root cause is an open coil in the 1810-0146 quad coil pack. All of the coils are low ohms to common except for the decimal point coil.
Other than taking a 1810-0146 from a 'donor' calculator, two solutions come to mind: 1) solder a small fixed 68uH inductor across the open coil in the pack, or 2) make a replacement "pack" from four small fixed inductors (1x 68uH, 3x 130uH) Has anyone else faced this issue? I'd love to hear how you solved it. -tom |
03-18-2022, 12:16 AM
(This post was last modified: 03-18-2022 01:14 AM by teenix.)
RE: 1810-0146 replacement
I'd try soldering the inductor and see if it works. If so you might decide to leave it and try to find a replacement part. I'm sure there will be plenty of these on Classic display boards lying around as parts recovery - hopefully one not too far away and cheap to post.
I updated the ClassicNotes file to include coil details and resistances. Decimal point coil should be around 3 ohm, the others 5 ohm. (out of circuit) cheers Tony |
03-18-2022, 01:40 AM
Thank you, Tony!
I have some small-ish axial inductors on order. As soon as they arrive I’ll tack one across the suspect coil unit and see if the decimal points illuminate. Hopefully that solves the problem! -tom |
03-24-2022, 06:34 PM
My axial inductors arrived, but I couldn't really find a nice way to tack in the 68uH inductor that didn't physically interfere with the innards of the HP-55. I decided to construct a replacement array from three 120uH inductors and one 68uH inductor, all "1/8W" size. I used a solderless breadboard as a jig to hold them all in place while I trimmed leads and soldered a common "rail" across the top of the four inductors. I carefully de-soldered and removed the faulty inductor array, installed my replacement, and then re-assembled everything.
At power on, instead of seeing "0 00" I was greeted with "0.00". Problem solved. -tom |
03-24-2022, 07:39 PM
You could be inductanced into the HP calculator repair hall of fame :-)
cheers Tony |
03-24-2022, 09:45 PM
Here are photos of the replacement array, in case anyone is interested.
I’m not sure if this is a very common failure mode, but it certainly would be easy to make a small PCB with right-angle “pins” and SMT inductors for a more rugged solution. -tom —— Tom LeMense https://hackaday.io/project/175815-class...ttery-pack https://hackaday.io/project/181957-hp-28s-lipo-battery |
03-25-2022, 02:34 AM
(This post was last modified: 03-25-2022 02:35 AM by teenix.)
Some of the original ones were not that different.
The DP coil is second from left. cheers Tony |
03-25-2022, 02:53 AM
Oh, funny, “what’s old is new again!”
I’m pleased that the 120uH I used vs 130uH you measured doesn’t seem to make any difference in terms of segment intensity. At least, not to my eyes. Cheers! Tom |
03-25-2022, 02:35 PM
(03-25-2022 02:53 AM)tomcircuit Wrote: Oh, funny, “what’s old is new again!” I'd be more concerned with higher inductances as there may be segment bleeding from one digit to the next. That might also put a bit more stress on the transistors inside the Cathode and Anode driver IC's. cheers Tony |
03-26-2022, 01:46 AM
I had the same concern re:bleed, Tony. I studied your excellent writeup on how the display circuitry works and decided that using 120uH was the better choice over 150uH. The HP display circuitry is genius, by the way. I work for a semiconductor company, and I marvel at this ingenious low-power solution using 1970s technology.
Thanks again for the whitepaper on how it all works - some great reverse-engineering and patent spelunking you did there! -tom |
03-26-2022, 02:18 PM
03-29-2022, 04:05 PM
Nice job using the new inductors!
