Combine Export and Local variables?
03-28-2022, 09:47 AM (This post was last modified: 03-28-2022 09:48 AM by Amer7.)
I have this matrix program.
Idea:
1.) I will use default calculator matrix editor to input values into Matrix M1,M2,M3
2.) At the beginning of the program I want to use Input command to input a 2 variables. Their values are later used in the calculation in few places.
Issue:
I want to Export new Matrices ( N1,U1,Q1,D1,V1,L1, K1,K2, F1,S0,X1,K3,C1,C2,Q2,C3,Q3,Q4) so I could easily view their values in default calculator matrix editor.
In past I have used this idea that you suggested, and it worked great.
//PROGRAM START
EXPORT A1,A2;
EXPORT function1 ()
A1:=M1+M1;
A2:=M1-M1;
But now I don't know how to combine these two. Everything I've tried i get an error.
Program that I want local to be exported
EXPORT TST()
LOCAL w1,w2;
INPUT({w1,w2},"Prekobrojnost", {"Unesi prekobrojnost u","Unesi srednju vrijednost xo"});
LOCAL N1,U1,Q1,D1,V1,L1;
//N1- matica normalnih jednacina
//U1, Q1 - kofaktor matrica
//D1- vektor popravaka nepoznatih parametara
//V1-Vektor popravaka mjerenja
N1:=TRN(M1)*M2*M1;
U1:=TRN(M1)*M2*M3;
Q1:=inv(N1);
D1:=-(Q1*U1);
V1:=(M1*D1)+M3;
L1:=TRN(V1)*M2*V1;
LOCAL K1,K2;
//K1 - kontrola 1.) popravaka treba biti =0
K1:=TRN(M1)*M2*V1;
//K2 - Kontrola 2.) izjedacenja treba biti = lambdi
K2:=TRN(M3)*M2*V1;
LOCAL F1,S0,X1,K3;
F1:=(1/w1)*L1;
S0:=SQRT(F1(1,1));
X1=w2+D1;
// Popravljena mjerenja su pojedinacna l1,l2,l3...+ matrica V1;
K3:=M1*X1;
///Stohasticki dio
LOCAL C1,C2,Q2,C3;
C1:=F1*Q1;
// Deviacija mjerenja tako sto uzmemo korjen od Cx
C2:=F1*inv(M2);
//C2 - tacnost mjerenja
// srednje greske izvucem iz cl matrice korjen(dijagonalnih)
Q2:=M1*Q1*TRN(M1);
C3:=Q2*F1(1,1);
///Srednje greške popravljenih korjen dijagonale clanova C3
LOCAL Q3,Q4;
Q3:=inv(M2)-Q2;
Q4:=F1(1,1)*Q3;
PRINT("Kontrola K1 =0"+K1);
IF (K2=L1) THEN PRINT ("Kontrola 2 OK!");
And is there any way I could highlight In color this IF (K2==L1) THEN PRINT ("Kontrola 2 OK!"); If the K2 is equal to L1, and in red it it's not. ( printout in terminal) ?
03-28-2022, 10:20 AM
RE: Combine Export and Local variables?
(03-28-2022 09:47 AM)Amer7 Wrote:  Hello,
Idea:
Issue:
//PROGRAM START
EXPORT A1,A2;
EXPORT function1 ()
A1:=M1+M1;
A2:=M1-M1;
EXPORT TST()
LOCAL w1,w2;
N1:=TRN(M1)*M2*M1;
U1:=TRN(M1)*M2*M3;
Q1:=inv(N1);
D1:=-(Q1*U1);
V1:=(M1*D1)+M3;
L1:=TRN(V1)*M2*V1;
LOCAL K1,K2;
K1:=TRN(M1)*M2*V1;
K2:=TRN(M3)*M2*V1;
LOCAL F1,S0,X1,K3;
F1:=(1/w1)*L1;
S0:=SQRT(F1(1,1));
X1=w2+D1;
K3:=M1*X1;
///Stohasticki dio
LOCAL C1,C2,Q2,C3;
C1:=F1*Q1;
C2:=F1*inv(M2);
Q2:=M1*Q1*TRN(M1);
C3:=Q2*F1(1,1);
LOCAL Q3,Q4;
Q3:=inv(M2)-Q2;
Q4:=F1(1,1)*Q3;
How does it know those local variables (N1,U1, etc.) are matrices unless you reserve space for them with MAKEMAT or MAKELIST?
Tom L
Cui bono?
03-28-2022, 10:48 AM
Well I'm not sure, If the start value is Matrix, and if there are two operations with matrices it considers it automatically to be a matrix?
//PROGRAM START
EXPORT A1,A2;
EXPORT function1 ()
A1:=M1+M1;
A2:=M1-M1;
When I used this code, I didn't reserve it with MAKEMAT or MAKELIST
And the A1, and A2 matrices appeared in matrix editor with correct values
03-29-2022, 11:00 AM (This post was last modified: 03-29-2022 11:02 AM by Amer7.)
I have figured how to combine, It all works until the calculation between local and global variable.
//PROGRAM START
EXPORT N1,U1,Q1,D1,V1,V2,K1,K2;
EXPORT K3,F1,S0,X1,C1,C2,C3,Q3;
EXPORT Q2,Q4;
EXPORT function1 ()
LOCAL w1,w2;
N1:=TRN(M1)*M2*M1;
U1:=TRN(M1)*M2*M3;
Q1:=inv(N1);
D1:=-(Q1*U1);
V1:=(M1*D1)+M3;
V2:=TRN(V1)*M2*V1;
K1:=TRN(M1)*M2*V1;
K2:=TRN(M3)*M2*V1;
F1:=(V2/w1);
S0:=SQRT(F1(1,1));
--- The program WORKS UNTIl here
X1=w2+D1;
K3:=M1*X1;
///Stohasticki dio
C1:=F1*Q1;
C2:=F1*inv(M2);
Q2:=M1*Q1*TRN(M1);
C3:=Q2*F1(1,1);
Q3:=inv(M2)-Q2;
Q4:=F1(1,1)*Q3;
IF (K2=V2) THEN PRINT ("Kontrola 2 OK!");
The program returns 0, starting with Blolded part of the code- And that is not correct.
03-29-2022, 12:11 PM
This line: X1=w2+D1;
should be this: X1:=w2+D1;
-road
03-29-2022, 12:57 PM
(03-29-2022 12:11 PM)roadrunner Wrote:  This line: X1=w2+D1;
-road
Thank you road, I don't know how I didn't spot that.
Is there a way that I could label the matrix in matrix editor?
What I mean Can I somehow add text (description) Like Q3 is Matrix of average deviation of corrected measurements.
Instead of having just Q3 and number of rows and columns
03-29-2022, 01:52 PM
Did you try EDITMAT:
EDITMAT(Q3,"this is the title for Q3");
03-29-2022, 02:11 PM (This post was last modified: 03-29-2022 02:27 PM by Amer7.)
(03-29-2022 01:52 PM)roadrunner Wrote:  Did you try EDITMAT:
Yes I have, but when I run the program it displays the Matrices with their titles, one by one. ( if i write EDITMAT for Q3, EDITMAT for Q4)
(I've added the EDITMAT at the bottom of the program)
Run program:
Q3 with it's title ->OK ->Q4 with it's title ->OK-> Terminal
But when I go to Matrix editor and click to view matrix Q3 there is no tittle.
When I go Vars-User-Program Variables-Q3 It displays the matrix values in home.
Is there any way simple way I could keep the Matrix with Title and their values for later viewing?
And I have an issue when I clear the User variables, in matrix editor I still get matrices Q3, Q4... but empty (1,1)
Edit: If it's complicated I will just return to using Local variable with EDIT MAT, and re-run program to see the value of the Matrix i need.
03-29-2022, 02:36 PM
(03-29-2022 02:11 PM)Amer7 Wrote:  Is there any way simple way I could keep the Matrix with Title and their values for later viewing?
Not that i know of, at least not without writing a subroutine specifically for that; but someone else may know better.
I also noticed some of your variable names are reserved names. Generally I try to avoid using reserved names in programs because it can sometimes cause issues. To avoid issues you can add a lower case letter to each variable name; for example: Uu1 instead of U1.
-road
03-29-2022, 02:55 PM
Thank you road, you guys really helped me write simple programs for this calculator.
I will implement the suggestion.
Thank you!
04-11-2022, 09:58 AM (This post was last modified: 04-11-2022 10:56 AM by Amer7.)
Does anyone has an idea why the program crasher mid way with error
Invalid input INPUT({ff7,gg7},"Input test", {"Prekobrojnost","Sredina"});
//PROGRAM START
LOCAL Nn1,Uu1,Qq1,Dd1,Vv1,Vv2,Kk1,Kk2;
LOCAL Kk3,Ff1,Ss0,Xx1,Cc1,Cc2,Cc3,Qq3;
LOCAL Qq2,Qq4,Pm1,Sx1;
EXPORT function1 ()
LOCAL ff7,gg7;
Nn1:=TRN(M1)*M2*M1;
Uu1:=TRN(M1)*M2*M3;
Qq1:=inv(Nn1);
Dd1:=-(Qq1*Uu1);
Vv1:=(M1*Dd1)+M3;
Vv2:=TRN(Vv1)*M2*Vv1;
Kk1:=TRN(M1)*M2*Vv1;
Kk2:=TRN(M3)*M2*Vv1;
Ff1:=Vv2/(ff7);
Ss0:=SQRT(Ff1(1,1));
Xx1:=gg7+Dd1(1,1);
Kk3:=M1*Xx1;
Pm1:=M4+Vv1;
///Stohasticki dio
Cc1:=Ff1(1,1)*Qq1;
Sx1:=SQRT(Cc1(1,1));
Cc2:=Ff1(1,1)*inv(M2);
Qq2:=M1*Qq1*TRN(M1);
Cc3:=Qq2*Ff1(1,1);
Qq3:=inv(M2)-Qq2;
Qq4:=Ff1(1,1)*Qq3;
/// ISPISI MATRICA
EDITMAT(Nn1,"Matrica Normalnih jednacina");
EDITMAT(Uu1,"u=trn(A)*P*w");
EDITMAT(Qq1,"Kofaktorna matrica");
EDITMAT(Dd1,"vektor popravaka nepoznatih");
EDITMAT(Vv1,"vektor popravaka mjerenja");
EDITMAT(Vv2,"omega=VT*P*V" );
EDITMAT(Ff1,"s0^2=omega/prekobrojnost");
EDITMAT(Ss0,"s0");
EDITMAT(Xx1,"xdef poravljene nepoznate (x0+delta");
EDITMAT(Pm1,"Popravljena mjerenja ldef");
EDITMAT(Kk1,"1.Kontrola treba=~0");
EDITMAT(Kk2,"2.Kontrola treba= omega");
EDITMAT(Kk3,"3.Kontrola treba= popravljenim mjerenjima");
EDITMAT(Cc1,"Cx");
EDITMAT(Sx1,"Sx -srednja greska izracunata");
EDITMAT(Cc2,"Cl - tacnost mjerenja");
EDITMAT(Qq2,"Ql_kapa ");
EDITMAT(Qq3,"Qv");
EDITMAT(Cc3,"Cv-Srednje greske popravak sqrt diag");
PRINT("Kontrola K1 =0"+Kk1);
PRINT("Kontrola K2"+Kk2);
PRINT("------------------------------");
PRINT("Kontrola K3"+Kk3);
Program crashes at Ss0, when viewing matrix via EDITMAT
ff77=5
gg77=8.6667
EDIT- Some values wern't matrices
//PROGRAM START
EXPORT function1 ()
LOCAL ff7,gg7;
Nn1:=TRN(M1)*M2*M1;
Uu1:=TRN(M1)*M2*M3;
Qq1:=inv(Nn1);
Dd1:=-(Qq1*Uu1);
Vv1:=(M1*Dd1)+M3;
Ff1:=Vv2/(ff7);
Xx1:=gg7+Dd1;
Kk3:=M1*Xx1;
Pm1:=M4+Vv1;
///Stohasticki dio
Cc1:=Ff1(1,1)*Qq1;
Cc3:=Qq2*Ff1(1,1);
Qq3:=inv(M2)-Qq2;
Qq4:=Ff1(1,1)*Qq3;
/// ISPISI MATRICA
//EDITMAT(Ss0,"s0");
//EDITMAT(Xx1,"xdef poravljene nepoznate (x0+delta");
EDITMAT(Cc1,"Cx");
///EDITMAT(Sx1,"Sx -srednja greska izracunata");
EDITMAT(Qq3,"Qv");
PRINT("S0="+Ss0);
PRINT("Xdef. popravljene nepoznate (x0+delta)"+Xx1);
PRINT("Sx-srednja greska izracunata"+Sx1);
Now it works
04-12-2022, 07:09 AM (This post was last modified: 04-12-2022 07:16 AM by Amer7.)
I'm again having issues with this variation of program
EXPORT function1 ()
LOCAL ff7,gg7;
INPUT({ff7,gg7},"Prekobrojnost", {"Unesi prekobrojnost u","Unesi srednju vrijednost xo"});
LOCAL Nn1,Uu1,Qx1,Dd1,Vv1;
Nn1:=TRN(M1)*M2*M1;
Uu1:=TRN(M1)*M2*M3;
Qx1:=inv(Nn1);
Dd1:=-(Qx1*Uu1);
Vv1:=(M1*Dd1)+M3;
LOCAL Om1,Vf1,Ss0,Xx1,Ll1;
Om1:=TRN(Vv1)*M2*Vv1;
Vf1:=Om1/ff7;
Ss0:=CAS("sqrt(Vf1)");
Xx1:=gg7+Dd1;
Ll1:=M4+Vv1;
LOCAL Kk1,Kk2,Kk3;
Kk3:=M1*Xx1;
////////STOHASTICKI DIO
LOCAL Cx1,Cl1,Ql1,Clk1,Qvk1,Cv1,SCx1;
Cx1:=Vf1(1,1)*Qx1;
SCx1:=CAS("sqrt(Cx1)");
//////Q= CL
Local Cl1d,Cld2;
Cl1:=Vf1(1,1)*(inv(M2));
Cl1d:=diag(Cl1);
Cld2:=CAS("sqrt(Cld1)");
//Cl=CL kappa
LOCAL Cll1,Cll2;
Cl1:=Ql1*Vf1(1,1);
Cll1:=diag(Cl1);
Cll2:=CAS("Sqrt(Cll1)");
//////QL kappa
Ql1:=M1*Qx1*TRN(M1);
//QV
Qvk1:=inv(M2)-Ql1;
///CV
LOCAL Ccv1,Ccv2;
Cv1:=Qvk1*Vf1(1,1);
Ccv1:=diag(Cv1);
Ccv2:=CAS("sqrt(Ccv1)");
EDITMAT(Nn1,"N");
EDITMAT(Uu1,"u");
EDITMAT(Qx1,"Qx");
EDITMAT(Dd1,"Delta");
EDITMAT(M5,"v");
EDITMAT(Om1,"Omega");
EDITMAT(Vf1,"vf");
EDITMAT(Ss0,"So");
EDITMAT(Xx1,"X-Popravljene nepoznate");
EDITMAT(Ll1,"Popravljena mjerenja");
EDITMAT(Kk1,"Kontrola 1");
EDITMAT(Kk2,"Kontrola 2");
EDITMAT(Kk3,"Kontrola 3");
//// Stohasticki
EDITMAT(Cx1,"Cx");
EDITMAT(SCx1,"Sx - Std.");
EDITMAT(Cl1,"Cl");
EDITMAT(Cld2,"Srednje greske iz CL");
EDITMAT(Ql1,"Ql_kapa");
EDITMAT(Cll2,"Srednje greske popravljenih");
EDITMAT(Clk1,"Cl_Kapa");
EDITMAT(Qvk1,"Qv_kapa");
EDITMAT(Cv1,"Cv");
EDITMAT(Ccv2,"Srednje greske popravaka");
PRINT("Vf="+Vf1);
Issue is on line 38
When ever I try to compute Vf1 with an Matrix it starts crashing with (input) problem
Vf1= is Vf1:=Om1/ff7;
ff7- is user input on start of the program
I have tried making sure it's a matrix by
M8:=Vf1(1,1);
Again it crashes Cl1:=Vf1(1,1)*(inv(M2));
I've tried putting it in CAS("(Om1/ff7Wink"); -Still doesnt work
In my Edit mat Vf1 ( has only one element)
And M2 is diagonal Matrix (4x4)
Is there a way I assign the value of Vf1(1,1) to be a regular number so I could multiply the Matrix M2 without getting an issue?
When I try to do I manually like in home:
M2(1,1)*inv(M3) - I get correct numbers
04-12-2022, 05:18 PM
A couple things i noticed:
First,
I think this line: Cld2:=CAS("sqrt(Cld1)");
Should be this: Cld2:=CAS("sqrt(Cl1d)");
Second,
In this line: LOCAL Cx1,Cl1,Ql1,Clk1,Qvk1,Cv1,SCx1;
you declare variable Ql1 but I didn't see anywhere that is was assigned a value. It looks like you started to with this: //////Q= CL, but remed it out. When you declare a variable they start out at zero so at this line:
Cl1:=Ql1*Vf1(1,1);
Cl1 = 0*Vf1(1,1) which is zero. That causes this line:
EDITMAT(Cl1,"Cl");
to flag an error. EDITMAT only works on matrix variables.
04-12-2022, 06:34 PM
(04-12-2022 05:18 PM)roadrunner Wrote:  A couple things i noticed:
First,
Second,
Cl1:=Ql1*Vf1(1,1);
EDITMAT(Cl1,"Cl");
Wow,
I really appreciate for spotting that mistake. Now it works. I really have to find some other program to write in, and I should start more like using names to be easier to spot the mistake.
Thank you for your time to spot the mistake!
