HP Connectivity Kit problem
04-02-2022, 09:02 AM
I found the "HP Connectivity Kit" not working on Windows 11.
It just not responding.
System: Windows 11 Pro
System version: 21H2
OS build: 22000.556
Use the HP Connectivity Kit (64-bit) 2.1.14596 (2021-10-01).
04-02-2022, 07:40 PM
RE: HP Connectivity Kit problem
HP Connectivity Kit (64-bit) 2.1.14596 (2021-10-01) just installed here. Opens without any problem.
Windows 11 Pro version 22H2 Insider Preview (10.0.22581.200) (KB5013296)
Have you tried to uninstall and re-install? Did you get it from hpcalc.org, that's where my installation file is from.
HTH Günter
04-03-2022, 03:10 PM (This post was last modified: 04-03-2022 07:34 PM by Jozefvv.)
On my laptop HP connectivity kit works fine, but on my desktop it lags out as soon as I touch the program. Was not responding 100% of the time.
Tried to launch it now, after removing the registry entries from HKEY_CURRENT_USER\SOFTWARE and deleting the entire hewlett packard key, made it work.
04-04-2022, 04:18 AM
I had the same problem. After waiting a few minutes, it gave me an error saying my network was blocking something and then it started running smoothly again
04-04-2022, 02:38 PM
I had the same problem when I got a new Windows 11 PC in January. It would do nothing for a couple of minutes then give me a network error. After that it would be fine. It has since stopped the initial hanging when starting up and now works fine.
Note: I had some programs stop working properly in the Virtual Calc as well so I run it in compatibility mode and it resolved the issue.
04-06-2022, 07:32 PM
(04-02-2022 07:40 PM)Guenter Schink Wrote:  HP Connectivity Kit (64-bit) 2.1.14596 (2021-10-01) just installed here. Opens without any problem.
HTH Günter
Yes, I have tried reinstalling.
My installation files are from hpcalc.org.
04-06-2022, 08:55 PM
Hmm...
does your system have the Microsoft Visual C++ Redistributable(64) of any version installed? I think 2013 edition would be needed, perhaps also any later version suffices.
I vaguely remember that lacking this component gave me problems at times. I think I resolved the issue by downloading the connectivity kit .exe file (not the .msi) directly from their ftp server. And after that updated with the file from hpcalc.org
"ftp://ftp.hp.com/pub/calculators/Prime/" put this link without the quotes into the address field of your file explorer or if you have an ftp client like FileZilla put "ftp.hp.com/pub/calculators/Prime/" into its address field.
Perhaps this helps!
Günter
04-07-2022, 01:05 AM
(04-06-2022 08:55 PM)Guenter Schink Wrote:  Hmm...
Perhaps this helps!
Günter
My system already installed the Microsoft Visual C++ 2015-2022 Redistributable (x64 & x86) 14.31.31103
04-07-2022, 01:17 AM
Perhaps this helps!
Günter
Thank you,
I download the "HP_Prime_Connectivity_Kit_x64_20210609.exe" from ftp and install,
then upgrade 2021 10 01 from hpcalc.org,
now it work fine on Windows 11!
04-07-2022, 06:46 PM
(04-07-2022 01:17 AM)Yoshinosido Wrote:  Thank you,
Great! do you now have an older Visual C++ than the 2015-2022 edition also on your system?
Günter
04-19-2022, 01:15 AM
Günter
No, it's still has only one of the Visual C++ 2015-2022 Redistributable.
User(s) browsing this thread:
