DM41X rom loaded in AM, but cannot 'run' program
05-04-2022, 04:56 PM
I loaded up the Survey ROM after receiving this calculator 2 days ago, it shows in Active Modules, figured out how to get it to show up in CAT 2, but pressing R/S and Enter does not activate the program. The manual does not really help.
Any ideas on what I've missed?
Thx,
Dan
05-04-2022, 10:51 PM
RE: DM41X rom loaded in AM, but cannot 'run' program
To run program MYPROG, you need to either assign it to a key or execute it via [XEQ]
To run it driectly:
[XEQ] [Alpha] MYROG [Alpha]
To Assign it to the [LOG] key:
[shift] [ASN] [Alpha] MYPROG [Alpha] [LOG]
Then, after making sure user is ON (press USER toggle until you see USER annunciator), just press the [LOG] key and MYPROG will run.
Running directly from the CAT-2 listing is not supported by the native 41 OS, but it is possible via some of the more exotic modules.
hth
05-05-2022, 02:18 AM
Thanks, Bob.... that was the answer I was looking for.
Dan
