Bürgi's Kunstweg to Calculate Sines
05-07-2022, 11:31 AM
Reference
From: Jost Bürgi’s Method for Calculating Sines Abstract Quote:From various sources we know that the Swiss instrument maker and mathematician Jost Bürgi (1552-1632) found a new way of calculating any sine value. Division of a right angle into nine parts Program to initialize the registers: Code: 00 { 39-Byte Prgm } Quote:The other nine cells are filled with an arbitrary series of natural numbers, for which Bürgi selects 2, 4, 6, 7, 8, 9, 10, 11, 12. Code: 00 { 42-Byte Prgm } After the initialisation we perform 4 steps to get the values of column 5: XEQ INIT XEQ STEP R/S R/S R/S RCL 04 8273441 RCL 09 12871192 ÷ 0.64278747 Compare this to the correct value: 40 SIN 0.64278761 Division of a right angle into 90 parts It's easy to adjust the program to do the same for \(n = 90\) to calculate the sines of all degrees from sin 1° to sin 90°. To initialize the registers I use an approximation of the sines similar to before: \(\text{round}(12 \sin(x))\): Code: 00 { 34-Byte Prgm } Code: 00 { 46-Byte Prgm } SIZE 91 XEQ INIT-90 XEQ STEP-90 R/S R/S RCL 47 310796277956 RCL 90 424964111250 ÷ 0.73134712 Compare this to the correct value: 47 SIN 0.73135370 Here we performed only 3 steps instead of 4. That's why the accuracy is not as good. But we can also notice that the numbers get bigger than before. |
05-08-2022, 01:19 PM
RE: Bürgi's Kunstweg to Calculate Sines
Double Difference
We can use the addition formualas to simplify the double difference: \( \sin(\alpha \pm \beta) = \sin(\alpha) \cos(\beta) \pm \cos(\alpha) \sin(\beta) \) This leads to: \( \begin{align} \Delta^2 \sin(\alpha) &:= \left[\sin(\alpha + \beta) - \sin(\alpha)\right] - \left[\sin(\alpha) - \sin(\alpha - \beta)\right] \\ &= \sin(\alpha + \beta) - 2 \sin(\alpha) + \sin(\alpha - \beta) \\ &= \sin(\alpha) \cos(\beta) + \cos(\alpha) \sin(\beta) - 2 \sin(\alpha) + \sin(\alpha) \cos(\beta) - \cos(\alpha) \sin(\beta) \\ &= 2 \sin(\alpha) \left(\cos(\beta) - 1\right) \\ \end{align} \) We notice that it is proportional to \( \sin(\alpha) \) independent of \( \alpha \). In the limit of \( \beta \to 0 \) we get: \( \lim_{\beta \to 0} \frac{\cos(\beta) - 1}{\beta^2} = - \frac{1}{2} \) This leads to the 2nd derivative of the sine function: \( \sin(\alpha){''} = \lim_{\beta \to 0} \frac{\Delta^2 \sin(\alpha)}{\beta^2} = - \sin(\alpha) \) Conclusion If we apply the double difference on a sequence \( \{a_j\} \) where \( j \in \{1, \cdots, n\} \) and the values are sines of angles in arithmetic progression, we get a sequence that is proportional to the original. The proportional factor is: \( 2 \left(\cos(\beta) - 1\right) \) Here \( \beta \) is the difference between consecutive angles. However we have to consider two cases at the boundary. Lower bound: j = 1 In this case we have: \( \alpha = \beta \) This leads to: \( \begin{align} \sin(\alpha + \beta) - 2 \sin(\alpha) + \sin(\alpha - \beta) &= \sin(2 \alpha) - 2 \sin(\alpha) + \sin(0) \\ &= 2 \sin(\alpha) \cos(\alpha) - 2 \sin(\alpha) \\ &= 2 \sin(\alpha) \left(\cos(\alpha) - 1 \right) \\ &= 2 \sin(\alpha) \left(\cos(\beta) - 1 \right) \\ \end{align} \) We end up with the same result as before. Upper bound: j = n In this case we have: \( \alpha = 90^\circ \) Here we calculate only the single difference: \( \sin(\alpha) - \sin(\alpha - \beta) = 1 - \cos(\beta) \) We notice that apart from the factor \( -2 \) we get the same result since \( \sin(\alpha) = 1 \). Matrix Notation We can therefore describe the double difference operation with the matrix \( \Delta \): \( \Delta = \left[\begin{matrix} 2 & -1 & 0 & 0 & 0 & 0 & 0 & 0 & 0\\ -1 & 2 & -1 & 0 & 0 & 0 & 0 & 0 & 0\\ 0 & -1 & 2 & -1 & 0 & 0 & 0 & 0 & 0\\ 0 & 0 & -1 & 2 & -1 & 0 & 0 & 0 & 0\\ 0 & 0 & 0 & -1 & 2 & -1 & 0 & 0 & 0\\ 0 & 0 & 0 & 0 & -1 & 2 & -1 & 0 & 0\\ 0 & 0 & 0 & 0 & 0 & -1 & 2 & -1 & 0\\ 0 & 0 & 0 & 0 & 0 & 0 & -1 & 2 & -1\\ 0 & 0 & 0 & 0 & 0 & 0 & 0 & -2 & 2 \end{matrix}\right] \) Bürgi seems to have noticed that the result was less precise than before. So he reversed the process. \( \Sigma = \Delta^{-1} = \left[\begin{matrix} 1 & 1 & 1 & 1 & 1 & 1 & 1 & 1 & \frac{1}{2}\\ 1 & 2 & 2 & 2 & 2 & 2 & 2 & 2 & 1\\ 1 & 2 & 3 & 3 & 3 & 3 & 3 & 3 & \frac{3}{2}\\ 1 & 2 & 3 & 4 & 4 & 4 & 4 & 4 & 2\\ 1 & 2 & 3 & 4 & 5 & 5 & 5 & 5 & \frac{5}{2}\\ 1 & 2 & 3 & 4 & 5 & 6 & 6 & 6 & 3\\ 1 & 2 & 3 & 4 & 5 & 6 & 7 & 7 & \frac{7}{2}\\ 1 & 2 & 3 & 4 & 5 & 6 & 7 & 8 & 4\\ 1 & 2 & 3 & 4 & 5 & 6 & 7 & 8 & \frac{9}{2} \end{matrix}\right] \) Calculating the Sines We can simply copy and paste the following matrices into Free42: 1 1 1 1 1 1 1 1 0.5 1 2 2 2 2 2 2 2 1 1 2 3 3 3 3 3 3 1.5 1 2 3 4 4 4 4 4 2 1 2 3 4 5 5 5 5 2.5 1 2 3 4 5 6 6 6 3 1 2 3 4 5 6 7 7 3.5 1 2 3 4 5 6 7 8 4 1 2 3 4 5 6 7 8 4.5 ENTER ENTER ENTER 2 4 6 7 8 9 10 11 12 × 63 124 181 232 276 312 339 356 362 × 2064 4065 5942 7638 9102 10290 11166 11703 11884 × 67912 133760 195543 251384 299587 338688 367499 385144 391086 × 2235060 4402208 6435596 8273441 9859902 11146776 12094962 12675649 12871192 Note: What appeared to be simple turned out to be a problem. The separator in the matrix has to be a tabulator. But I couldn't figure out how to do that when you copy it from this page. It is always replaced by a blank. Thus my recommendation for now is to copy the matrix into a text-editor, replace the blanks by tabs and copy the result into Free42. References |
05-09-2022, 01:48 AM
(05-08-2022 01:19 PM)Thomas Klemm Wrote: We can therefore describe the double difference operation with the matrix \( \Delta \): Asymmetry of matrix, [2,-1] top, [-2,2] bottom , we should match edge cases coefficients. Lower bound, α = β, sin(α-β) = sin(0°) = 0 Δ² = sin(α+β) - 2 sin(α) + sin(α-β) = -dot([sin(α), sin(α+β)], [2, -1]) Upper bound, α = 90°, sin(α+β) = sin(α-β) = cos(β) Δ² = sin(α+β) - 2 sin(α) + sin(α-β) = -dot([sin(α-β), sin(α)], [-2,2]) Quote:Note: What appeared to be simple turned out to be a problem. Another way is to click QUOTE, copy raw matrix data (with tabs), then paste to Free42 |
05-09-2022, 04:55 PM
(05-09-2022 01:48 AM)Albert Chan Wrote: Asymmetry of matrix, [2,-1] top, [-2,2] bottom , we should match edge cases coefficients. Another way is to split central difference to 2 steps, forward diff, then backward diff. Below, 1 ≡ 10°, (0-1) ≡ sin(0°) - sin(10°) = -sin(10°) ≡ -1 Code: 0 F B F >>> from numpy import * >>> F = [[-1,0,0,0,0,0,0,0,0], ... [1,-1,0,0,0,0,0,0,0], ... [0,1,-1,0,0,0,0,0,0], ... [0,0,1,-1,0,0,0,0,0], ... [0,0,0,1,-1,0,0,0,0], ... [0,0,0,0,1,-1,0,0,0], ... [0,0,0,0,0,1,-1,0,0], ... [0,0,0,0,0,0,1,-1,0], ... [0,0,0,0,0,0,0,1,-1]] >>> >>> B = [[1,-1,0,0,0,0,0,0,0], ... [0,1,-1,0,0,0,0,0,0], ... [0,0,1,-1,0,0,0,0,0], ... [0,0,0,1,-1,0,0,0,0], ... [0,0,0,0,1,-1,0,0,0], ... [0,0,0,0,0,1,-1,0,0], ... [0,0,0,0,0,0,1,-1,0], ... [0,0,0,0,0,0,0,1,-1], ... [0,0,0,0,0,0,0,0, 2]] >>> >>> M = -matrix(B) * matrix(F) >>> print M [[ 2 -1 0 0 0 0 0 0 0] [-1 2 -1 0 0 0 0 0 0] [ 0 -1 2 -1 0 0 0 0 0] [ 0 0 -1 2 -1 0 0 0 0] [ 0 0 0 -1 2 -1 0 0 0] [ 0 0 0 0 -1 2 -1 0 0] [ 0 0 0 0 0 -1 2 -1 0] [ 0 0 0 0 0 0 -1 2 -1] [ 0 0 0 0 0 0 0 -2 2]] If we apply this M operator, it generated massive cancellation errors. Applying its inverse turn all entries non-negative, without cancellation errors. >>> print linalg.inv(M) [[ 1. 1. 1. 1. 1. 1. 1. 1. 0.5] [ 1. 2. 2. 2. 2. 2. 2. 2. 1. ] [ 1. 2. 3. 3. 3. 3. 3. 3. 1.5] [ 1. 2. 3. 4. 4. 4. 4. 4. 2. ] [ 1. 2. 3. 4. 5. 5. 5. 5. 2.5] [ 1. 2. 3. 4. 5. 6. 6. 6. 3. ] [ 1. 2. 3. 4. 5. 6. 7. 7. 3.5] [ 1. 2. 3. 4. 5. 6. 7. 8. 4. ] [ 1. 2. 3. 4. 5. 6. 7. 8. 4.5]] We can also think of inv(M) as "going back in time", turning divergence into convergence. |
