Python help
05-16-2022, 08:15 PM
Python help
I'm going to have a look at programming in Python on the Prime, just some questions:
1. Should I expect to get the ability to use arbitrarily large integers? 2. How do I use libraries or modules that would be called in python e.g. "import matplotlib.pyplot as plt" how can I get that matplotlib mentione to work with my program? 3. Or am I limited to the commands I can find on the Prime itself, in the Python app Cmds menu? 4. Is there a set of documentation on programming the Prime using Python, so that I do not have to bother with common questions? 5. Is there even a starter guide that may help starting out? |
05-17-2022, 05:33 AM
(This post was last modified: 05-17-2022 05:43 AM by Thomas_Sch.)
RE: Python help
how about a search?
e.g. https://www.hpmuseum.org/forum/search.ph...order=desc hint: it's micropython, not full python. this means: only the libraries are available, which are provided with micropython on the HP-Prime. edit: link for search modified |
05-19-2022, 07:02 PM
RE: Python help
An invalid search was specified. Please go back and try again.
