(33S) Atmospheric Parameters
05-18-2022, 02:57 AM
Given the height (H) in meters, the following can be estimated: Temperature in Celsius (°C): T ≈ 15.04 - 0.00649 * H Pressure in kilopascals (kPa): P ≈ 101.29 * ((T + 273.15) / 288.08)^5.256 (note, the source had 273.1 but I had 27.3.15 for better accuracy) Atmospheric Density (km/m^3): D ≈ P/(0.2869 * (T + 273.15)) Program: HP 33S: Size: LN = 174, CK = 7625 Code: A0001 LBL A Example: H = 50 m Results: T ≈ 14.715580 °C (about 58.4879 °F) P ≈ 100.894225 kPa D ≈ 1.221648 kg/m^3 Source: "Engineering Formula Sheet" Project Lead The Way. https://www.madison-lake.k12.oh.us/userf...0Sheet.pdf Last Retrieved April 29, 2022 |
