HP Prime: Isolate a variable in an equation
12-20-2013, 10:34 PM
Hello friends:
How to isolate a variable in an equation on HP Prime? Can anyone guide us? Searched the Guide and not found. Thank You David |
12-20-2013, 10:58 PM
RE: HP Prime: Isolate a variable in an equation
I'm not an expert but I tend to use the solve() command in CAS mode. For example
Solve(x+y=4,y) should return 4-x. Good luck. |
12-20-2013, 11:00 PM
In CAS view, solve() should be of help.
E.g., solve(x^2-4*y*x=3,y) returns {(-x^2+3)/(4*x)} Or solve(x^2-4*y*x=3,x) returns {2*y+-sqrt(4*y^2+3)} Is that what you are after? |
12-21-2013, 01:26 AM
(12-20-2013 10:58 PM)CR Haeger Wrote: I'm not an expert but I tend to use the solve() command in CAS mode. For example Thanks friends: That's what I need. But, using this command with different variables X and Y, appears a recommendation that doesn't work either. Another observation is that the result is not symbolic when the variables are different from X and Y. Grateful David |
12-21-2013, 02:01 AM
You need to type in lower case variables.
