HP 82166A/C
06-06-2022, 07:28 PM
HP 82166A/C
Volks!
Today I got a HP 82166C HP-IL Kit and wanted to check its content.
I have some of the HP 82166A HP-IL Converter Prototyping Kits and some of the HP 82166C HP-IL Interface Kits but they all have different contents. Does someone has a full sett of these two boxes or is there a list, what belongs to which box?
Matthias
06-07-2022, 12:17 AM (This post was last modified: 06-07-2022 05:24 PM by Sylvain Cote.)
RE: HP 82166A/C
(06-06-2022 07:28 PM)HP-Collection Wrote:  Volks!
Matthias
82166A Kit
 2x 82166A      HP-IL Converters
 2x 82167A      HP-IL 0.5m Cables
 2x             GPIO connectors
 1x 82166-60013 HP-IL Interfacing Board
 1x 82166-90002 HP-IL Converter Technical Manual
 1x 82165-90012 HP-IL Converter Manual Supplement
82166B Kit
10x 82166A      HP-IL Converters
82166C Kit
Manuals & Softwares
 1x 82166-90020 The HP-IL Interface Kit, Technical Guide
 1x 82166-90016 The HP-IL Integrated Circuit, User's Manual
 1x 82166-90017 The HP-IL Interface Specification
 1x 82166-90013 Caution Card
 1x  5955-9425  The HP-IL System, Book, ISBN: 0-931988-77-2
 1x 82166-90002 HP-IL Converter, Technical Manual
 1x 82165-90012 HP-IL Converter, Manual Supplement
 2x  5061-5271  HP-41 HP-IL Development Module
 1x 00041-90449 HP-41 HP-IL Development Module, Owner's Manual
 1x 00075-90122 HP-75 I/O Utilities, Manual
 1x 00075-12022 HP-75 I/O Utilities, Magnetic Cards
 1x 00075-90144 HP-75 RIOWIO, Instruction Card
 1x 00075-12025 HP-75 RIOWIO, Magnetic Cards
Electronic Parts Early Kits (before mid 1983)
 8x  0683-1535  Resistor       15 kilohms     5%    25 watt
 8x  0698-3446  Resistor      383 ohms        1%  .125 watt
 8x  0160-4292  Capacitor     330 picofarad   5%
 8x  1902-0953  Xener Diode   6.2 volt        1N753A
 8x  1902-0970  Xener Diode    33 volt        1N973B
Electronic Parts Later Kits (after mid 1983)
 4x  1810-0651  HP-IL Hybrid Network
Common Parts (Early+Later kits)
 4x  0160-0576  Capacitor     0.1 microfarad
 4x  0180-3135  Capacitor      10 microfarad
 4x  0160-4800  Capacitor     120 picofarad   5%
 4x  9100-1631  Inductor       56 microhenry  5%
 2x  0410-1305  Crystal         4 megahertz
 8x  0624-0626  Screw        2-28 self-tapping
 8x  3050-0626  Washer            flat
 4x  0950-0852  HP-IL Panel Receptacle
 4x  9100-4226  HP-IL Pulse Transformer
 4x  ILB3-0003  HP-IL integrated circuit
 2x  1820-2810  Microprocessor IC
 1x  9311-4320  82166C HP-IL Interface Kit Box
Click on View a Printable Version to get a printable listing
PS: it took me several edit/version to get the correct list
Edit: removed 82166-90024 Firmware Design for HP-IL Devices, Application Note from kit listing.
06-07-2022, 07:27 AM (This post was last modified: 06-07-2022 07:31 AM by J-F Garnier.)
RE: HP 82166A/C
(06-07-2022 12:17 AM)Sylvain Cote Wrote:  1x 82166-90024 Firmware Design for HP-IL Devices, Application Note
Are you sure this application note was included in the 82166C kit? I don't remember it was.
I still have all the 82166C kit original documentation, but the application note only as a photocopy, that I probably got later.
J-F
06-07-2022, 08:54 AM
RE: HP 82166A/C
Hi Matthias,
I found a leaflet from back then, hopefully this helps.
DropBox has blocked my abilities to "Share Link" (not sure why) - so I dropped a note on your Museum with the list.
BTW, J-F is correct, the 90024 is not on the list
06-07-2022, 12:22 PM (This post was last modified: 06-07-2022 12:37 PM by J-F Garnier.)
RE: HP 82166A/C
(06-07-2022 07:27 AM)J-F Garnier Wrote:  Are you sure this application note was included in the 82166C kit? I don't remember it was.
(06-07-2022 08:54 AM)KimH Wrote:  BTW, J-F is correct, the 90024 is not on the list
Yes, this is consistent with publish date (March 1984), more than one year after the kit.
BTW, when I started designing my first HP-IL device firmware (mid. 1984), I wasn't aware of this document, so wrote the software based on my own functional analysis. It was not as structured as the HP reference design, but was working well and my code of the time (with some later improvements) is still the base of the ILPer devices :-)
J-F
06-08-2022, 02:19 PM
RE: HP 82166A/C
Thanks! I have removed the document from the kit list. (the HP 82166C kit I have is an early one)
