Building a HP35 scientific calculator clone
07-10-2022, 11:31 AM
It's nice to present this project - Building a HP35 scientific calculator clone with a Z80 cpu from scratch.
[Image: 1_25.jpg]
But without using emulators, HP microcode etc. I have always wanted to rewrite original algorithms, created by David S. Cochran.
As the original HP35 was built 50 years ago, this is a good time to do the same :-)
Everything (hardware, software, source code, working gerbers etc) is on my github page:
https://github.com/olekgr/HP-35_Z80
I hope this project will be interesting for someone.
07-11-2022, 07:33 AM
RE: Building a HP35 scientific calculator clone
Very nice! Thanks for sharing your code too!
07-11-2022, 08:25 AM
Great job, especially using the original algorithms !! Does your hp35 even exhibit the ln 2.02 bug ? :-)
Roland
07-11-2022, 03:42 PM
Great work !
So you programmed the whole simulator under Z80 assembly language 8-)
(8 bits)
Looking at your schematic , it is quite inspiring too.
07-11-2022, 07:58 PM
That's impressive, thanks for sharing!
My first reflex would be indeed to use an FPGA, but it's not as fun as using the real Z80 and logic ICs. I used to love this CPU assembly language!
07-14-2022, 07:43 AM
Wow. Great work.
Love the assembly - reminds me of the coding I did as young.
Thank you for sharing!
I'm Required
07-10-2023, 11:06 PM
Very nice! I also built an HP-25 replica using a Z80 but I run the HP microcode in a C emulator. Your software is much more impressive.
My project: https://github.com/eshazen/retro-25
