HP Prime Pro
07-12-2022, 11:43 AM
HP Prime Pro
I have running the HP Prime Pro App on my IPAD.
In the past (couple of years ago) I could load programs to it over the wifi. My IPAD is a Pro version 4e generation running software version 15.5. When I try to connect I can't see my network, to make a connection. Have done the right setting , give acces to the local network in the setup Is this evident to the newer IPAD? I have seen that there were no bug fix over the last year! Is there a work around to fix this? Cheers, Jan |
07-18-2022, 04:28 PM
RE: HP Prime Pro
HP 33C 34C 11C 41CX 12C 15C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more |
09-17-2022, 08:00 PM
(This post was last modified: 09-17-2022 08:05 PM by gastondefer.)
RE: HP Prime Pro
(07-12-2022 11:43 AM)Powersoft Wrote: I have running the HP Prime Pro App on my IPAD. I'm gonna assume you are using a Windows PC, if not, I can't help. Go to your Windows Defender/Firewall settings and simply allow the connectivity kit to operate on your network (private or public or both) under inbound/outbound. Everywhere you see the connectivity kit in Windows defender, just give it access and never worry about it again. |
