Pi Approximation Day
07-22-2022, 11:47 PM
Since today is Pi Approximation Day, just another one for the collection. Not an outstanding approximation, but this might fit into the Exotic Ones category:
\(e^{\sqrt[11_{3}]{\frac{2222_{4}-\frac{1}{22_{9}^{2}+22_{16}^{2}+\frac{1}{1111_{7}}}}{99_{10}}}}\)
07-23-2022, 01:20 AM
RE: Pi Approximation Day
Hi, all,
I can't let Pi Approximation Day (22/7) pass by without my humble contribution, so here you are.
Set FIX 6 and then run on your HP-42S (physical or virtual) this little piece of mystery code I've hastily concocted and see what you get:
01 LBL "?"
02 10
03 STO ST Y
04 LBL 00
05 RCL ST Y
06 RCL× ST Z
07 RCL+ ST Z
08 RCLx ST X
09 RCL× ST L
10 1/X
11 -
12 DSE ST Y
13 GTO 00
14 SQRT
15 END
See if you can fathom how/why it works. Smile
Regards.
V.
07-23-2022, 02:20 AM
Nice.
(07-23-2022 01:20 AM)Valentin Albillo Wrote:  See if you can fathom how/why it works. Smile
It uses Ramanujan's formula:
\begin{align}
\pi^2 = 10 - \sum_{n=1}^{\infty} \frac{1}{n^3(n+1)^3}
\end{align}
07-23-2022, 07:00 AM
Can't you let others have a chance to play?
J-F
07-23-2022, 10:56 AM
(07-22-2022 11:47 PM)Gerson W. Barbosa Wrote:  \(e^{\sqrt[11_{3}]{\frac{2222_{4}-\frac{1}{22_{9}^{2}+22_{16}^{2}+\frac{1}{1111_{7}}}}{99_{10}}}}\)
What is subscript / superscript notation mean?
07-23-2022, 11:26 AM
My wife says they are the radix (for example 16 as a subscript indicates a hexadecimal number) and the good old exponent.
07-23-2022, 11:36 AM
(07-23-2022 11:26 AM)vaklaff Wrote:
(07-23-2022 10:56 AM)Albert Chan Wrote:  What is subscript / superscript notation mean?
Yes, they are base and exponent, respectively. In order to avoid confusion I should have written (22₉)² instead, for instance. That’s 20² = 400.
07-23-2022, 11:44 AM
(07-23-2022 01:20 AM)Valentin Albillo Wrote:  Set FIX 6 and then run on your HP-42S (physical or virtual) this little piece of mystery code I've hastily concocted and see what you get:
01 LBL "?"
02 10
03 STO ST Y
04 LBL 00
05 RCL ST Y
06 RCL× ST Z
07 RCL+ ST Z
08 RCLx ST X
09 RCL× ST L
10 1/X
11 -
12 DSE ST Y
13 GTO 00
14 SQRT
15 END
Wonderful little program!
It uses the specific HP-42S stack capability, running it on my trusty 32S would require a few more steps. Of course the interest is in this 42S version.
Thank you Valentin, it's a pleasure to read you again.
J-F
07-23-2022, 11:59 AM (This post was last modified: 07-23-2022 03:19 PM by Gerson W. Barbosa.)
(07-23-2022 07:00 AM)J-F Garnier Wrote:
(07-23-2022 02:20 AM)Thomas Klemm Wrote:  It uses Ramanujan's formula:
I had found the general term 1/(x^2 + x)^3 when I saw Thomas Klemm’s post. After driving almost 400 km during the day, I was glad he was that fast :-)
Not as fun, but we can still rewrite Valentin’s intentionally slightly obfuscated program:
00 { 31-Byte Prgm }
01▸LBL "?"
02 0
03▸LBL 00
04 RCL ST Y
05 RCL× ST X
06 RCL+ ST L
07 X↑2
08 RCL× ST L
09 1/X
10 -
11 DSE ST Y
12 GTO 00
13 10
14 +
15 SQRT
16 END
1E1 -> 3,141592850081697528137175603520803
1E2 -> 3,141592653592821635772340191552596
1E3 -> 3,141592653589793270134930833666846
1E6 -> 3,141592653589793238462643383279535
pi —-> 3,141592653589793238462643383279503
Edited to fix a typo
07-23-2022, 03:18 PM (This post was last modified: 07-23-2022 03:18 PM by C.Ret.)
01 LBL "?"
02 10
03 STO ST Y
04 LBL 00
05 RCL ST Y
06 RCL× ST Z
07 RCL+ ST Z
08 RCLx ST X
09 RCL× ST L
10 1/X
11 -
12 DSE ST Y
13 GTO 00
14 SQRT
15 END
I'm trying to fit it to my HP-41C, but I must have missed something. Especially at step 09 RCL× ST L; where is the LAST register initialized on the first pass? Why isn't this a problem regardless of what is previously stored in the LAST register? Is this a specific HP-42S trick, does memory recall arithmetic modify the LAST register?
I'm stuck; need a little more beers to drink and any good advice to hear !
07-23-2022, 03:41 PM
(07-23-2022 03:18 PM)C.Ret Wrote:  Is this a specific HP-42S trick, does memory recall arithmetic modify the LAST register?
Yes, it does, unlike memory store arithmetic:
05 RCL ST Y (T 10 10 10)
06 RCL× ST Z (… 100)
07 RCL+ ST Z (… 110)
08 RCL× ST X (… 12100)
09 RCL× ST L (… 1331000)
07-23-2022, 05:18 PM (This post was last modified: 07-23-2022 05:30 PM by C.Ret.)
Thank you for your quick response; this is a different behavior from the HP-15C memory recall arithmetic logic. That explain why I was so lost.
001 LBL "WLP
002 10
003 ENTER^
004 LBL 00
005 RCL Y
006 X^2
007 LASTX
008 +
009 -3
010 Y^X
011 -
012 DSE Y
013 GTO 00
014 SQRT
015 END
With FIX 7 display format, this little program give a better approximation of PI than 22/07.
Surprisingly, the number of instructions is the same as Valentin Albillo's original code.
\( \sqrt{10-\frac{1}{\left ( 10^2+10 \right )^3}-\frac{1}{\left ( 9^2+9 \right )^3}-\frac{1}{\left ( 8^2+8 \right )^3}-\cdots -\frac{1}{\left ( 2^2+2 \right )^3}-\frac{1}{\left ( 1^2+1 \right )^3}} = \sqrt{ \frac{2\,780\,722\,699}{281\,746\,080} } \approx \pi \)
07-23-2022, 06:46 PM
(07-23-2022 11:59 AM)Gerson W. Barbosa Wrote:  Not as fun, but we can still rewrite Valentin’s intentionally slightly obfuscated program
Without recall-arithmetic it uses even fewer bytes:
00 { 27-Byte Prgm }
01▸LBL "?"
02 0
03▸LBL 00
04 RCL ST Y
05 ENTER
06 X↑2
07 +
08 ENTER
09 X↑2
10 ×
11 1/X
12 -
13 DSE ST Y
14 GTO 00
15 10
16 +
17 SQRT
18 END
Using a register we can translate it for other HP calculators as well.
HP-15C:
   001 {       44  0 } STO 0
   002 {       43 35 } g CLx
   003 {    42 21  0 } f LBL 0
   004 {       45  0 } RCL 0
   005 {          36 } ENTER
   006 {       43 11 } g x²
   007 {          40 } +
   008 {          36 } ENTER
   009 {       43 11 } g x²
   010 {          20 } ×
   011 {          15 } 1/x
   012 {          30 } −
   013 {    42  5  0 } f DSE 0
   014 {       22  0 } GTO 0
   015 {           1 } 1
   016 {           0 } 0
   017 {          40 } +
   018 {          11 } √x̅
HP-25:
01: 23 00    : STO 0
02: 00       : 0
03: 21       : x<->y
04: 31       : ENTER
05: 15 02    : g x^2
06: 51       : +
07: 31       : ENTER
08: 15 02    : g x^2
09: 61       : *
10: 15 22    : g 1/x
11: 41       : -
12: 24 00    : RCL 0
13: 01       : 1
14: 41       : -
15: 23 00    : STO 0
16: 15 61    : g x<>0
17: 13 04    : GTO 04
18: 22       : Rv
19: 01       : 1
20: 00       : 0
21: 51       : +
22: 14 02    : f SQRT
23: 13 00    : GTO 00
We can even do it on the HP-35 if we consider the following manual steps a program.
Initialize:
CLR
10  STO
Repeat until 0:
ENTER↑  ENTER↑  ×  +
ENTER↑  ENTER↑  ×  ×
1/x  -
RCL  1  -  STO
Finalize:
R↓
10  +
√x
While we could start subtracting the terms from an initial value of 10, it is better to start the summation from 0 to avoid cancellation.
07-23-2022, 09:09 PM
(07-23-2022 06:46 PM)Thomas Klemm Wrote:  We can even do it on the HP-35 if we consider the following manual steps a program.
For this, back in the days, you would have used an HP-35 Key Sequence Form.
07-23-2022, 10:08 PM
(07-23-2022 06:46 PM)Thomas Klemm Wrote:  Without recall-arithmetic it uses even fewer bytes:
00 { 27-Byte Prgm }
01▸LBL "?"
02 0
03▸LBL 00
04 RCL ST Y
05 ENTER
06 X↑2
07 +
08 ENTER
09 X↑2
10 ×
11 1/X
12 -
13 DSE ST Y
14 GTO 00
15 10
16 +
17 SQRT
18 END
Thanks. I tend to value least number of steps over least number of bytes on the HP-42S where memory is not a concern, but I’ve just noticed there’s no reason at all to use recall arithmetic in my step 05 above when a simple X↑2 instruction suffices.
07-23-2022, 11:31 PM
Hi, Jean-François,
Thank you very much for your appreciation. Smile
Quote:It uses the specific HP-42S stack capability, running it on my trusty 32S would require a few more steps. Of course the interest is in this 42S version.
The little code I gave was intentionally obfuscated and particularized to add just 10 terms, to try and hide the "10" as if it were only the loop counter. My general non-obfuscated version which will add N terms is this 14-step, 26-byte HP-42S program:
01 LBL "?"
02 10
03 LBL 00
04 RCL ST Y
05 X↑2
06 RCL+ ST L
07 X↑2
08 RCL× ST L
09 1/X
10 -
11 DSE ST Y
12 GTO 00
13 SQRT
14 END
Key in N and XEQ "?". Running it on Free42 Decimal produces the following results for N=100, 1000, 10000 and 100000 terms:
      PI      3.14159 26535 89793 23846 26433 83279 502
      100     3.14159 26535 92821 63577 23401 91552 596      (13 digits save 3 ulp)
      1000    3.14159 26535 89793 27013 49308 33666 846      (18 digits save 4 ulp)
      10000   3.14159 26535 89793 23846 29615 34056 207      (23 digits save 3 ulp)
      100000  3.14159 26535 89793 23846 26433 86462 443      (28 digits save 3 ulp)
I like this series for Pi very much: it converges very fast (order 6), the general term is extremely simple to program needing just 6 steps, and this makes for speedy looping and very short running times, e.g. using as little as 100 terms gets you better than 12-digit accuracy and on Free42 it runs instantly.
Quote:Thank you Valentin, it's a pleasure to read you again.
Thank you, J-F, your feedback is most appreciated and if more people would do likewise that would surely motivate me to post again.
Best regards.
V.
07-24-2022, 07:03 AM
(07-23-2022 11:31 PM)Valentin Albillo Wrote:  Running it on Free42 Decimal produces the following results for N=100, 1000, 10000 and 100000 terms:
This is the table I got using Valentin's program with the additional value for 1000000:
      1000    3.14159 26535 89793 27013 49308 33666 845      (18 digits save 4 ulp)
      100000  3.14159 26535 89793 23846 26433 86462 453      (28 digits save 3 ulp)
      1000000 3.14159 26535 89793 23846 26433 83283 745      (31 digits save 4 ulp)
Please note the slight differences for 1000 and 100000.
This is the table I got using Gerson's program that adds 10 at the end:
      1000000 3.14159 26535 89793 23846 26433 83279 535      (33 digits save 3 ulp)
Interestingly it agrees exactly with Valentin's table.
For 1000000 it shows the effect of cancellation when starting with 10.
Somewhat related: Programming Exercise (HP-15C, 15C LE - and others)
07-24-2022, 09:37 AM
I'm curious about the PI number...
How many decimals in the PI are needed to get acceptable results in practical everyday
calculations? Is 3.14 enough ? Or do you have to use more? ( i think you have, but how many?)
07-24-2022, 10:58 AM
(07-24-2022 09:37 AM)Dan C Wrote:  How many decimals in the PI are needed to get acceptable results in practical everyday calculations? Is 3.14 enough ? Or do you have to use more? ( i think you have, but how many?)
For my own personal everyday applications involving Pi (like tinkering around the house and garden) 3.0 is a good enough approximation :-)
At work, many years ago, we were doing microvave imaging measurements and calculations. These involved propagation models with many e^i*Pi terms. Even using (then) state-of-the art measuring equipment (mostly from Hp of course, Agilent had not been sourced out then) no more then 4 (or maybe 5 for theoretical calculations) decimal places were required. Everything else would have been drowned in the noise anyway.
Max
07-24-2022, 11:29 AM
(07-24-2022 10:58 AM)Maximilian Hohmann Wrote:  Hello!
Max
Thanks for your input! So in real life calculations you are fine with PI at 3.1415, and that will do in most situations.
User(s) browsing this thread: 12 Guest(s)
