(33s): OEIS A1614, Connell sequence, & A122793, A171152, A118011
07-28-2022, 11:34 AM
Takes a real integer from the stack & returns A118011(N)
https://oeis.org/A118011 , A171152(N) https://oeis.org/A171152 ,A122793(N) https://oeis.org/A122793 & A1614(N) https://oeis.org/A001614 to stack. Nth member of complement of Connell sequence & partial sum, Nth of Connell sequence & partial sum of series. eg For input 2022 The programme returns T: 4,108 Complement of Connell sequence, 2022nd number not in Connell sequence Z: 4,176,234 Sum of first 2022 members of Complement sequence Y: 3,980 2022nd member of Connell sequence X: 4,004,778 Sum of first 2022 members of Connell sequence Code: 1. LBL M |
07-28-2022, 07:52 PM
RE: (33s): OEIS A1614, Connell sequence, & A122793, A171152, A118011
That is an impressively small program, especially considering that it returns all 4 values. But then I noticed your name on the formulas on the OEIS pages.
Here is a program for the HP 49 and 50 using ListExt 1.3 which works in a completely different way. Given a number n on the stack, the program returns a list of the first n*(n+1)/2 terms of the Connell sequence A001614. With an input of 50, the program returns a list of 1275 numbers in about 2.1 seconds on my 50g. Code:
For the partial sums A122793, follow the program with { + } LSCAN. |
