Python clear console screen
07-30-2022, 01:19 PM
Hi all,
I have just started to learn python on the HP Prime. One thing I could not figure out is to clear the console screen when a program first run.
So say I am running this code that ask for an input, it is nicer if i can clear the screen before i input the variable.
How could I do this?
Thanks
06-30-2023, 03:36 PM
RE: Python clear console screen
I don't see a command that clears the console screen. The only option is the Clear soft button in Num view and that doesn't always appear.
07-01-2023, 02:57 AM
You can try this, it seems to work
from hpprime import *
eval("PRINT()")
I only tried on one program and the program.text started at the top line so seems to work
