Emu48 help
08-10-2022, 12:59 AM (This post was last modified: 08-10-2022 11:39 PM by Gil.)
Emu48 help
1) Just changed my phone for a Samsung A53.
2) Installed the EMU48 application on it.
3) Chose the cropped version hp50g in the "New..." Menu.
4) Loaded all the previous programs.
5) Everything works fine.
6) But when I close all the applications on the phone and want to open again emu48, the access is denied.
7) Then I have to procede again from step 3 to 5, which was not the case on my previous phone, a Samsung galaxy S6
Could somebody help me, when closing the application, that emu48 could be "normally" opened with the initially calculator choice HP50G, including the previously given programd, avoiding the step 7?
Gil Campart
08-10-2022, 11:48 PM (This post was last modified: 08-10-2022 11:50 PM by Gil.)
RE: Emu48 help
I thought that the problem was because emu48 was initially installed on my old phone Samsung S6.
I deleted then the EMU48 application from my Samsung S6.
And tried to close all the app on my new phone A53.
Unfortunately, when trying to use the EMU48 on my new phone, the access is again denied —> and everything is lost.
I tried to install back emu48 on my old phone, but now the same problem appears when closing all the app.
It should be an option in the settings, but I can't see it.
Thanks for your help.
Gil
08-15-2022, 11:12 PM
RE: Emu48 help
Gil,
Try reposting under Not quite HP Calculators - but related under Not HP Calculators. You'll have a better chance of getting a response.
Mark
08-16-2022, 12:04 AM
RE: Emu48 help
Thanks for the suggestion.
I solved the problem by using the SAVE command into a new directory/file on the phone.
Gil
