HP97 Card reader. won't read but will write
08-10-2022, 09:03 PM
The card reader is rebuilt mechanically (o rings, shaft coupler) and electrically (tantalum caps all around). Card sense switches adjusted. All reads give "ERROR". However, I can write OK and the written cards read fine in other machines. The original machine will not read cards that it has written itself.
Any ideas? Help appreciated!
08-11-2022, 12:47 AM (This post was last modified: 08-11-2022 12:48 AM by teenix.)
RE: HP97 Card reader. won't read but will write
(08-10-2022 09:03 PM)Dreato Wrote:  The card reader is rebuilt mechanically (o rings, shaft coupler) and electrically (tantalum caps all around). Card sense switches adjusted. All reads give "ERROR". However, I can write OK and the written cards read fine in other machines. The original machine will not read cards that it has written itself.
From a HP microcode point of view, the "Error" will be displayed from an invalid checksum or a timeout (eg.slow or stalled card reader)
Other errors will be hardware related.
Two simple things to try:
if you have another CPU board, swap it and try again.
I think you have an oscilloscope, check the signals coming from the sense IC all the way to the CRC IC. The 97 service manual can help with pins outs.
cheers
Tony
08-11-2022, 02:09 AM
Out of curiosity are the batteries good?
Does it do the same thing when operating off of the charger (with a good battery pack)?
08-12-2022, 06:56 PM
Hi all,
Not a solution, but you may want to have a look at this old thread.
Here.
I also remember a service note at the end of the 97 Service Manual (available elsewhere) related to this issue.
Seems not an uncommon failure after all.
Best from the Caribbean.
Diego.
"Do not suppose, check it twice."
