HP 82240B print graphics in right proportions?
08-14-2022, 04:55 AM
(This post was last modified: 08-14-2022 08:23 PM by Aquarius.)
Hey guys, I am printing plots and GROB's on a HP 82240B printer with the HP 48/50 calculator and it all works as expected. The only issue I am facing, is that it seems like the vertical distance between dots are larger than the horizontal distance between the dots.
To illustrate, if I print a 5x5 square it will look more like a rectangle: . . . . . . . . . . . . . . . . . . . . . . . . . This means that every graphic that is printed will be stretched along the vertical axes (square -> rectangle, circle -> ellipsoid etc.). Does anyone have a suggestion as to why this is the case and maybe some ideas to counter it - as I would really like for my printed GROB's to have the same proportions as they have when viewed on the screen or just at least be able to print a perfect circle instead of a ellipse. |
