hyp2exp
09-01-2022, 12:18 PM
hyp2exp
Hello, is there the "inverse" function of "hyp2exp"? That is, is there a function that does the reverse process of "hyp2exp"?
Best regards, Roberto.
09-04-2022, 08:00 PM
RE: hyp2exp
No, but it's fairly easy: subst(expression,exp,cosh+sinh)
09-05-2022, 07:21 AM
RE: hyp2exp
(09-04-2022 08:00 PM)parisse Wrote:  No, but it's fairly easy: subst(expression,exp,cosh+sinh)
Thank you very much, parisse
Another question: why are inverse hyperbolic functions (ATANH, ACOSH, etc.) automatically represented by the corresponding logarithmic form?
Sincerely, robmio
09-05-2022, 11:50 AM
RE: hyp2exp
Above exp2hyp expression might be "simplified" to sin/cos
Just keep in mind, e^(i*x) = cos(x) + i*sin(x) = cosh(i*x) + sinh(i*x)
      cos(x) = cosh(i*x)      i*sin(x) = sinh(i*x)
      cosh(x) = cos(i*x)      i*sinh(x) = sin(i*x)
CAS> subst(e^(i*x), exp, x -> cosh(x) + sinh(x))
cos(x) + i*sin(x)
Same trick can be used for a "better" exp2trig
CAS> f := e^x - e^-x                                   // = 2*sinh(x)
CAS> exp2trig(f)      → e^x - e^-x
CAS> f(exp = (x -> cos(i*x) + sin(i*x)/i))     → -2*i*sin(i*x)
Or, in steps, since sinh/cosh tends to "simplify" to sin/cos
CAS> f(exp=cosh+sinh)(x=x/i)(x=x*i)          → -2*i*sin(i*x)
09-05-2022, 12:40 PM
RE: hyp2exp
(09-05-2022 07:21 AM)robmio Wrote:  Another question: why are inverse hyperbolic functions (ATANH, ACOSH, etc.) automatically represented by the corresponding logarithmic form?
Sincerely, robmio
For a CAS, it is always simpler to work with a smaller set of functions. cosh and sinh are still used sometimes (in the French curriculum system), they are not replaced, atanh and the like are never used, hence they are replaced (same as for sec/csc etc.)
09-05-2022, 04:25 PM
RE: hyp2exp
Is this a bug?
acosh(z) should produce non-negative real part, same as acos(z)
CAS> acosh(-2.) // ???
1.31695789692+3.14159265359*i
CAS> acosh(-2+1e-15i)
CAS> acosh(-2-1e-15i)
1.31695789692-3.14159265359*i
09-09-2022, 11:46 AM
RE: hyp2exp
cos(x) + i*sin(x)
Hello, is there an algorithm that translates the logarithmic formulas of the inverse hyperbolic functions into the inverse hyperbolic functions represented with "acosh", "asinh", "atanh", etc.?
For instance:
e^x*ln(x+√(x^2+1))-ln(ln(√(x+1)*√(x-1)+x)) --instruction--> exp(x)*asinh(x)-ln(acosh(x))
Best regards, robmio.
09-13-2022, 04:00 PM
RE: hyp2exp
Sincerely, robmio
Dear professor, is there the "inverse" function of "atrig2ln"? That is, is there a function that does the reverse process of "atrig2ln"?
09-14-2022, 05:48 PM
RE: hyp2exp
evalc converts complex ln to inverse trig functions. However for Inverse hyperbolic functions, you will have to implement it yourself.
