Free42: Random Word Picker
09-09-2022, 12:26 PM
I’d like to write a program which randomly, or I suppose pseudorandomly, selects one word each from two large word lists, and hyphenates them, printing the result.
As an example, given these word lists: 1. fig, frog, cardboard, gelatin 2. soft, angry, instant, canned The program, when run, might output the following: canned-fig canned-cardboard instant-frog The question: How do I store the word lists? Is there such a thing as calling a file in free42? I figure someone has a more optimal way than simple listing them all in the code! Thanks! |
09-09-2022, 01:38 PM
RE: Free42: Random Word Picker
There are no files, but matrices will do the job nicely, considering the six-character string length limit of the HP-42S no longer applies in Free42.
You can just put each word list in a text file, one word per line. Copy the text and paste it into Free42, and presto, you have a Nx1 matrix, with one row for each line in the text. With a list stored under the name LIST, you can select a random element from it as follows: 01 INDEX "LIST" 02 RCL "LIST" 03 DIM? 04 × 05 RAN 06 × 07 IP 08 1 09 + 10 LASTX 11 STOIJ 12 RCLEL |
09-09-2022, 02:00 PM
alternatively:
01 INDEX "LIST" 02 I- 03 RCLIJ 04 x 03 RAN 06 x 07 1 08 STO+ ST Y 09 STOIJ 10 RCLEL or, if you have the size of LIST in "N": 01 INDEX "LIST" 02 RAN 03 RCLx "N" 04 1 05 STO+ ST Y 06 STOIJ 07 RCLEL Cheers, Werner I originally tried it with lists, but getting the N-th item out of a list is a nightmare, or I'm missing something. 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
09-09-2022, 04:10 PM
Thanks guys! This works great, and I got the matrix in via copy-paste:
https://thomasokken.com/free42/#copy-paste https://forum.swissmicros.com/viewtopic.php?f=15&t=3186 Regards, David |
09-09-2022, 07:33 PM
(09-09-2022 02:00 PM)Werner Wrote: I originally tried it with lists, but getting the N-th item out of a list is a nightmare, or I'm missing something. Well, you could cobble something together using LIST→ and PICK, but it wouldn't be pretty and it would require NSTK mode. And in Plus42, you could use GETITEM, but not in Free42. (GETITEM is an undocumented function which is used to implement matrix and list element access in code generated by PARSE, but there's nothing magical about those functions used by the code generator, you can use them in your own code as well.) |
09-10-2022, 10:10 AM
Here's one way to extract a random element from a list:
00 { 23-Byte Prgm } 01▸LBL "RANITEM" 02 ENTER 03 LENGTH 04 RAN 05 × 06 SUBSTR 07 HEAD ST X 08 END |
09-10-2022, 10:45 AM
(This post was last modified: 09-10-2022 10:46 AM by rprosperi.)
(09-09-2022 07:33 PM)Thomas Okken Wrote: [snip] Well, not undocumented any more... ![]() --Bob Prosperi |
09-10-2022, 10:46 AM
More generally, to make lists a bit easier to work with in programs, I guess it would be better to extend GETITEM and PUTITEM, so the first parameter doesn't have to be a name but can also be a matrix or list, and then back-port them to Free42.
09-10-2022, 01:28 PM
(This post was last modified: 09-11-2022 09:28 PM by Thomas Okken.)
(09-10-2022 10:45 AM)rprosperi Wrote: Well, not undocumented any more... Technically, all I have done so far, in this and one other thread and on my web site, is to mention the existence of GETITEM. ![]() Quote:Generated Code: |
09-11-2022, 12:34 PM
(This post was last modified: 09-13-2022 08:16 AM by Thomas Okken.)
RE: Free42: Random Word Picker | |||
