[VA] SRC #012d - Then and Now: Area
01-07-2023, 10:46 PM
Hi, all,
Welcome to the 4th part of my ongoing SRC #012 - Then and Now, where I'm showing that advanced vintage HP calcs which were great problem-solvers back THEN in the 80's are NOW still perfectly capable of solving recent, non-trivial problems intended to be tackled using modern PCs, never mind ancient calcs.
In the next weeks I'm proposing six increasingly harder such problems for you to try and solve using your vintage HP calcs while abiding by the mandatory rules summarized here:
    You must use VINTAGE HP CALCS (physical/virtual,) coding in either RPN (inc. mcode), RPL (variants existing at the time, inc. SysRPL) or HP-71B languages (inc. BASIC, FORTH, Assembler), so NO XCAS, MATHEMATICA, MAPLE, EXCEL, C/C++/C#, PYTHON, LUA, etc., NO LENGTHY MATH SESSIONS and NO CODE PANELS.
    On the plus side, you may use any official/popular modules, pacs or libraries available at the time such as the Math Pac, HP-IL and JPC ROMs for the HP-71B, the Advantage Module, PPC ROM and EM for the HP-41, and libraries for the RPL models, etc..
Once P1 (Probability), P2 (Root) and P3 (Sum) are over, now's the turn for Problem 4, which deals with area and it's ever-so-slightly harder than the previous ones. Also, lest you'd think it looks like a textbook exercise, rest assured there's some nice surprises to deal with (if you've got what it takes, that is ...)
Problem 4:  Area
    The thermodynamic efficiency of the combined cycle for a hypothetical gas turbine using ethane as fuel is related to the area of the region R of the X-Y plane defined by the expression
        [Image: SRC-12-5-1hdfdkf.jpg]
    where radians are used, M is 30.070 (ethane's Molar mass in g/mol, see Properties,) and d is 1.598 (Molar density in mol/dm3). Write a program to compute this area.
Here the focus is on computing the area of R, so you might begin by locating R via estimating (2 decimal digits at most, ±d.dd) the coordinates of some rectangle that fully encloses it, either by writing code to sweep the X-Y plane or simply by using a graphing calculator or online function plotter, your choice.
Once obtained, your program (which should take no inputs,) can refine and use them to compute and output R's area accurate to 10-12 correct digits (give or take a few ulp,) and the faster the running time the better.
If I see interest, in a week or so I'll post my own original solution for the HP-71B, which is a very short program that does the job. In the meantime, let's see your very own clever solutions AND remember the above rules. this is strictly for vintage HP calcs, Ok ?
Also, please be kind and avoid spoiling it for other interested people by immediately posting your solution and/or results. Wait instead until next Wednesday 9:00 pm GMT+1 so that other people will have a chance. In the meantime you can mull it over so that you eventually post the one (1) message featuring your fully refined solution instead of a myriad posts refining it little by little. Got it ? Wink
V.
01-10-2023, 10:33 AM
RE: [VA] SRC #012d - Then and Now: Area
I will respect the wish of Valentin to postpone any results before next Wednesday, so I will not even say if I'm working on a solution, have a result, or have no idea at all.
However, the proposed equation looks strange from a dimensional point of view:
Since y appears in sin(y), it should be dimensionless, but this is not compatible with the term y²/M that must be dimensionless too.
It could be an empirical formula coming from a fit of experimental data, still I would be curious to know its origin.
J-F
01-10-2023, 11:22 AM
Hi, J-F,
(01-10-2023 10:33 AM)J-F Garnier Wrote:  However, the proposed equation looks strange from a dimensional point of view:
All will be clear in due time, for now please ignore any and all dimensions, consider only pure dimensionless numerical values throughout.
Thanks for your interest and eagerly awaiting for your results. If you would include some of your sleuthing, so much the better ... Smile
V.
01-10-2023, 12:16 PM
You were braver than me, JF, as the scraps of remnants of a physicist in my also tripped up over „radians“ mixed with mols etc.
I will go one step further now than JF and say that I have no much of an idea at all. (And admit to being a bit sad about not able to follow and learn from the iterative approaches and discussions that have happened in past SSMCs and prior challenges in the series, given the immense delight and learning I derive from following along, feeling inspired, learning an idea, gleaning a hint. I am more of a collaborative learner than only reveling in others Feynman-like genius results, even though I do enjoy that also. But, as we are told, „rules must be obeyed, the winner takes it all“, collaboration is for wimps…)
Cheers,
PeterP
01-11-2023, 02:55 AM
Hi, Martin,
(01-10-2023 01:01 PM)Martin Hepperle Wrote:  A HP 85 probably does not qualify, even if it is a officially called "Calculator".
Nevertheless, it can produce just by its brute computing force a result with a rather long BASIC program (but, hey, with graphics output). The area of interest, I must admit, was found by trial and error, though.
The result is about 2.07662029 but needs at least N=32 samples in each:
Thanks for your interest in this Problem 4 but please try to abide by the rules I stated in my OP, namely:
    1) This is strictly intended for vintage HP calcs, the HP-85 isn't one. Post code only for the allowed models I listed.
    2) You posted your solution 1.5 days before the date and time I specified. Please comply as others did.
    3) I specifically requested that CODE panels should not be used, yet you did.
    4) Your code doesn't produce the result you gave, and further you didn't include in your post any output from your program, i.e. neither the graphics nor the actual numerical results.
See if you can correct some or all of those 4 points and in the future please do your best to abide by the rules, they aren't optionsl and I stated them repeatedly and clearly enough.
Regards.
V.
01-11-2023, 12:46 PM (This post was last modified: 01-11-2023 12:47 PM by Martin Hepperle.)
.. previous post removed due to violation of the rules and because there is surely a more elegant solution.
01-11-2023, 01:59 PM
Hi, Martin,
(01-11-2023 12:46 PM)Martin Hepperle Wrote:  .. previous post removed due to violation of the rules and because there is surely a more elegant solution.
Thanks, Martin, much appreciated. You can still very easily convert your existing program to run on the HP-71B or even implement a more-"elegant", more efficient and accurate solution, perhaps along the lines of the approach used to produce the result you posted.
Regards.
V.
01-11-2023, 10:17 PM (This post was last modified: 01-11-2023 10:21 PM by Albert Chan.)
exp(-((x-d)^3-y)^2) > (R = y^2/M + exp(-sin(y)))      // Given: M=30.07, d=1.596
Let s = sqrt(-log(R)) ≥ 0
((x-d)^3-y)^2 < s^2
y-s < (x-d)^3 < y+s
x is real if s is real --> R ≤ 1 --> 0 ≤ y ≤ 2.82740261413
Height, \(\displaystyle f(y) = x_2 - x_1 = \sqrt[3]{y+s} - \sqrt[3]{y-s}\)
f slope is infinite when y = s --> R = exp(-y^2) --> y = 0 or 0.831971149978
Let a = 0.831971149978, a+b = a+B/2 = 2.82740261413
Infinite slopes at y = 0 and a, moved to z = 0
Area = \(\displaystyle \int_0^{a+b} f(y)\;dy
= \int_0^{1/2} \Big[\big(f(a\,z) + f(a- a\,z)\big)·a \;+\; f(a+B\,z)·B\Big] \,dz
Let g(z) = RHS integrand, and substitute z = x³/2, to make z=0 infinite slope, down to 0.
INTEGRAL built-in u-transform should turn curve to bell-shaped, easy to integrate.      (*)
Area = \(\displaystyle \int_0^{1/2} g(z)\;dz
= \int_0^1 g\!\left(\frac{x^3}{2}\right)·\left(\frac{3}{2}x^2\;dx \right)
10 DESTROY ALL @ M=30.07 @ A=.831971149978 @ B=2.82740261413-A @ P=1E-6
20 T=1/3 @ DEF FND(Y,S)=(Y+S)^T-SGN(Y-S)*ABS(Y-S)^T
30 DEF FNF(Y)=FND(Y,SQR(-LN(Y*Y/M+EXP(-SIN(Y)))))
40 B=B*2 @ DEF FNG(Z)=(FNF(A*Z)+FNF(A-A*Z))*A+FNF(A+B*Z)*B
50 SETTIME 0 @ DISP INTEGRAL(0,1,P,FNG(.5*IVAR^3)*IVAR^2)*1.5,TIME
>run
 2.07662636748      .49      ! @200× --> HP71B = 98 sec
>p=1e-9 @ run 50
 2.07662636775      .92      ! @200× --> HP71B = 184 sec
(*) at y = a+b, f slope is infinite too.
Above code assumed u-transform able to fix this edge.
If not, we move all edges to z=0, with this revised g(z).
>40 DEF FNG(Z)=(FNF(A*Z)+FNF(A-A*Z))*A+(FNF(A+B*Z)+FNF(A+B-B*Z))*B
>run
 2.07662636769      .6        ! @200× --> HP71B = 120 sec
>p=1e-9 @ run 50
 2.07662636775      1.2      ! @200× --> HP71B = 240 sec
01-12-2023, 12:00 AM
I’ve been working on this Problem 4 since Valentin posted this interesting challenge, but I have not yet reached a solution accurate to 10-12 correct digits as requested. Still, while not abiding to Valentín’s instruction to post only one message featuring the fully refined solution, I am going to share what I have done so far, as I have some doubts that I’ll be able to complete the work within the next few of days.
Problem 4 asks us to calculate the area in the (x,y) plane where the criteria (1) below is met:
1/e^(((x-d)^3-y)^2 ) > y^2/M+1/e^(sin⁡(y)) (1)
To simplify the equation a little bit (and also the code to follow), let’s define:
x’=x-d
Then we can represent equation (1) as:
1/e^((x'^3-y)^2 ) > y^2/M+1/e^(sin⁡(y))
Let’s then name:
1/e^((x'^3-y)^2 ) = f(x',y)
and:
y^2/M+1/e^(sin⁡(y)) = g(y)
We know that f(x’,y) will always be in the range from 0 to 1 as the denominator of the division is positive.
0<f(x',y)≤1
We also know that g(y) will be in the range from y2/M+e^-1 to ∞, therefore in the range from e^-1 to ∞.
e^(-1)<g(y)<∞
In the (f,g) plane, we can represent the area that meets the three criteria:
0<f≤1
g>e^(-1)
f>g
I wish I knew how to include an image I have drawn inside this post, but I don't know how to do it. The area in the (f,g) plane meeting the three criteria listed above is a triangle defined by the points A=(1,1), B=(e^-1,e^-1) and C=(1,e^-1).
From point A we can now derive:
1>g(y)
1>y^2/M+1/e
M(1-1/e)>y^2
|y|<√(M(1-1/e))=4.3598
-4.3598 < y < 4.3598
And from point B we can derive:
f(x’,y)>e-1
1/e^((x'^3-y)^2 ) >1/e → (x'^3-y)^2<1
|x'^3-y|<1
And taking the extremes of y calculated earlier, we get:
-1-4.3598<x'^3<1+4,3598
∛(-5.3598)<x'<∛5.3598
-1.75 < x’ < 1.75
To allow for some margin, we will use the following rectangle area where the original Problem 4 criteria is met:
-1.76 < x’ < 1.76
-4.36 < y < 4.36
Now, to obtain an approximate value of the area where the criteria defined by equation (1) is met, we can use the following program for the HP-71B:
10 X1=-1.76 @ X2=1.76 @ Y1=-4.36 @ Y2=4.36 @ INPUT "N? ";N
20 D1=(X2-X1)/N @ D2=(Y2-Y1)/N @ D=D1*D2 @ S=0 @ T0=TIME
30 FOR Y=Y1+D2/2 TO Y2-D2/2 STEP D2
40 G=Y*Y/30.07+EXP(-SIN(Y))
50 FOR X=X1+D1/2 TO X2-D1/2 STEP D1
60 IF EXP(-(X*X*X-Y)*(X*X*X-Y))>G THEN S=S+D
70 NEXT X
80 NEXT Y
90 DISP "Area=";S;TIME-T0
This program divides the rectangle bounded by the limits of x’ and y as defined above into NxN small rectangles and scans all small rectangles progressing row by row. If the criteria of equation (1) is met at the middle point of a given rectangle, its area is added to the summation S. If the criteria is not met, nothing is added to S.
At the end, the value S gives a rough approximation of the area where criteria (1) is met. Trying with different values of N, I get the followings times are for Emu71/Win running on my PC (which is about 970 times faster than the real 71B):
Grid size; Area; Time (s)
10x10; 2.455552; .02
20X20; 2.148608; .04
50x50; 2.11177472; .24
100x100; 2.09028864; .94
200x200; 2.07647616; 3.72
500x500; 2.0788703232; 23.61
1000x1000; 2.0765989376; 97.96
2000X2000; 2.07705168; 378.71
So, we seem to be converging to a value of around 2.077, but the convergence is too slow to make this brute-force method practical. We need to apply a smarter method, which could take advantage of the INTEGRAL function provided by the 71B Math ROM. But I need to work on it, and I’m sure others will post correct solutions before I have time to do so.
By adding DISP X;Y at the end of line 60 you can get a rough idea of the shape and position of the area meeting criteria (1), by looking at the pairs of values being displayed as the program runs.
60 IF EXP(-(X*X*X-Y)*(X*X*X-Y))>G THEN S=S+D @ DISP X;Y
If you make the grid accurate enough, say 500x500, you can see a small area at the upper left side of the rectangle where criteria (1) is met, and then a much larger area in the middle to lower half of the rectangle.
f you make the grid 2000x2000, the small area at the upper left corner can be seen with better definition.
With a grid of 100x100 you don’t get to see the small area in the upper left part, you will only see the large area starting towards the middle of the rectangle. It would be interesting to plot these areas, but I can't do it with a bare-bones 71B or with Emu71/Win.
It’s very possible that there be more than 2 different areas where the criteria (1) is met, but I have been able to “see” only those two so far.
My proposed way forward would be to express the equation bounding the area where criteria (1) is met:
1/e^((x'^3-y)^2 ) = y^2/M+1/e^(sin⁡(y))
Transforming it to isolate x’ as a function of y, and then using the INTEGRAL function of the Math ROM to do the calculation. But I sill need to figure out what the boundary values for the integration would be, and how to cater for the fact that there seems to be separate areas (at least two) where criteria (1) is met. So still some work to do!
01-12-2023, 07:31 AM
All calculators used (42S, DM42 and Free42) have
  • 30.07 in variable "M"
  • 1.598 in variable "d"
  • RAD mode.
1. define the rectangle
Let's first determine the y-values of the rectangle.
It's clear that EXP(-((x-d)^3-y)^2) <= 1, and it is equal to 1 for all y=(x-d)^3
so y^2/M + EXP(-SIN(y)) = 1 is a border: anything < 1 may belong to the area, > 1 does not.
that turns out to be the case for y=0 and y=2.8274.., found with the 42S solver program.
So our area is between these two y values.
00 { 27-Byte Prgm }
01▸LBL "VA4Y"
02 MVAR "Y"
03 RCL "Y"
04 ENTER
05 X^2
06 RCL÷ "M"
07 X<>Y
08 SIN
09 +/-
10 E^X
11 +
12 1
13 -
14 END
Incidentally (and accidentally) I also found a tiny region -4.0851.. <= y <= -4.0492.. where the original inequality will hold (eg. y=-4.05 and x=0.004). There are no other regions since
EXP(-SIN(y)) >= 1/e, abs(y) < SQRT((1 - 1/e)*M) = 4.3598.
If we rewrite the orginal formula as an equality, we can isolate x for a given y:
(1) x = d + CBRT(y +/- SQRT(-LN(y^2/M + EXP(-SIN(y)))))
When the result of LN is positive, we're outside of the area and there are no real solutions for x.
Within the area, there are two results for x (that coincide at the edges), describing the shape.
A bit of trial and error gives the following rectangle boundaries, just for the purpose of graphing the area (I used Y=-0.1 to have the shape come clear off the bottom edge).
Main Tiny
X0: 0.97 -0.001
X1: 3.05 0.0045
Y0: -0.1 -4.049
Y1: 2.85 -4.086
2. graph the shape
I graphed the main shape on my DM42 with the following drawing routine, with GrMod=2
(I enlarged the X range to X0=0.58 and X1=3.44 to have the X and Y scale be the same)
Set the values with VARMENU "VA4D", EXIT the menu and do XEQ "VA4D".
(the program can be made a lot more efficient, but that was not the scope here).
.bmp  VA4.bmp (Size: 12.31 KB / Downloads: 20)
00 { 167-Byte Prgm }
01▸LBL "VA4D"
02 MVAR "X0"
03 MVAR "X1"
04 MVAR "Y0"
05 MVAR "Y1"
06 MVAR "GrMod"
07 CLLCD
08 RCL "X1"
09 RCL- "X0"
10 RCL "ResX"
11 LSTO "X"
12 DSE ST X
13 ÷
14 LSTO "Sx"
15 RCL "Y0"
16 RCL- "Y1"
17 RCL "ResY"
18 DSE ST X
19 ÷
20 LSTO "Sy"
21▸LBL 10
22 RCL "Sx"
23 RCL× "X"
24 LASTX
25 -
26 RCL+ "X0"
27 LSTO "Xc"
28 RCL "ResY"
29 LSTO "Y"
30▸LBL 11
31 RCL "Sy"
32 RCL× "Y"
33 LASTX
34 -
35 RCL+ "Y1"
36 ENTER
37 ENTER
38 X^2
39 RCL÷ "M"
40 X<>Y
41 SIN
42 +/-
43 E^X
44 +
45 RCL "Xc"
46 RCL- "d"
47 3
48 Y^X
49 R^
50 -
51 X^2
52 +/-
53 E^X
54 X≤Y?
55 GTO 00
56 RCL "Y"
57 RCL "X"
58 PIXEL
59▸LBL 00
60 DSE "Y"
61 GTO 11
62 DSE "X"
63 GTO 10
64 END
3. calculate area
Well then. All that is needed is to integrate the shape over the Y-range. That can be done with a standard 42S integration routine, integrating dx = x2-x1, with x2 the positive root of (1):
c := SQRT(-LN(y^2/M + EXP(-SIN(y))));
dx := CBRT(y + c) - CBRT(y - c);
Area := integral(y=0 to 2.8274,dx);
Here I use LLIM=0 and ULIM=2.82740261413 for Main area
LLIM=-4.08514674764 and ULIM=-4.092122644 for Tiny area
the accurate limits are calculated with the solver program VA4Y above
The integration is done in Free42.
00 { 55-Byte Prgm }
01▸LBL "VA4"
02 MVAR "Y"
03 RCL "Y"
04 ENTER
05 X^2
06 RCL÷ "M"
07 X<>Y
08 SIN
09 +/-
10 E^X
11 +
12 LN
13 X>0?
14 CLX
15 X=0?
16 RTN
17 +/-
18 SQRT
19 ENTER
20 RCL+ "Y"
21 XEQ 13
22 X<>Y
23 RCL- "Y"
24 XEQ 13
25 +
26 RTN
27▸LBL 13 @ Cube Root
28 SIGN
29 LASTX
30 ABS
31 3
32 1/X
33 Y^X
34 ×
35 END
with ACC=1E-5 we get
2.07663 for the Main area
7.19762E-5 for the Tiny area
This accuracy needs 16383 function evaluations (for the Main area). That would take quite some time on a real 42S. The DM42 on USB takes about 94s.
Since the constant M is only given to 4 sig. digits, probably the Tiny area can be considered negligible. If not, I took the calculation of the integral a bit further, only on Free42 this time:
ACC #evals Main Tiny
1E-5 16383 2.07662797558 7.19761929874-5
1E-7 131071 2.07662603505 7.19761930422E-5
1E-9 524287 2.07662630959 =
1E-11 = =
1E-15 = =
So the sum of both areas is 2.07669828578
And now I'm going to try and understand Albert's contribution ;-)
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
01-12-2023, 09:34 AM
(written before reading other's contributions)
So here is my solution.
First, my initial observations (LHS is Left-Hand Side, RHS is Right-Hand Side of the equation):
LHS and RHS are >0
LHS is <=1
RHS must be <=1 for a corresponding x value to exist in the LHS
Then, I noticed that the d value is irrelevant, it just translates the whole graph in the X-Y plane without changing its area, so I ignored d and replace (x-d) by x.
Then I used the HP-71B to find out the limits of y:
ymin is 0, it gives RHS=1, and any y<0 gives RHS>1 with no solution in the LHS.
y>sqrt(m) gives RHS>1 for sure, but is not the limit for RHS>1.
ymax can be obtained by solving RHS=1 for y>2, and is about 2.8.
Then, I noticed that x can be quite easily expressed as a function of y, since x occurs only once in the equation.
So I can calculate the area by integrating the length of the segment between the 2 points solutions of x for a given y, i.e. the two points where a horizontal line crosses the area contour, between y=0 and y=ymax.
Here is where the practical issues start. This integral takes *a lot of time* to compute, even with moderate accuracy.
Relating this aspect to the places where the curve enclosing the area is horizontal, I tried the split the calculation in different zones. With this approach I succeeded to compute the integral in a reasonable time, at least on the 71B, even if not particularly fast.
Below is the program and results for the HP-71B and HP-75C:
10 ! SRC12D
20 ! HP-71B version
30 ! For HP-75 version, change IVAR by dummy Y var
40 OPTION ANGLE RADIANS
50 M=30.07
60 !
70 DEF FNR(Y)=Y*Y/M+EXP(-SIN(Y)) ! RHS
80 DEF FNR1(Y)=Y*Y/M+EXP(-SIN(Y))-1 ! RHS-1
90 DEF FNL(X3,Y)=EXP(-(X3-Y)^2) ! LHS
100 DEF FNE(Y)=FNL(0,Y)-FNR(Y) ! LHS-RHS for X=0
110 !
120 A=FNROOT(2,3,FNR1(FVAR))
130 DISP "RHS=1 for Ymax=";A
150 C=FNROOT(.5,2,FNE(FVAR))
160 DISP "LHS=RHS for X= 0 and Y=";C
170 !
180 E=10^(-12) @ B=.01
190 DISP "Ix IBOUND"
200 T1=TIME
210 I0=INTEGRAL(0,.001,E*1000,FNF(IVAR)) @ DISP I0;IBOUND
220 I1=INTEGRAL(.001,C-B,E,FNF(IVAR)) @ DISP I1;IBOUND
230 I2=INTEGRAL(C-B,C+B,E*10,FNF(IVAR)) @ DISP I2;IBOUND
240 I3=INTEGRAL(C+B,A,E,FNF(IVAR)) @ DISP I3;IBOUND
250 S=I0+I2+I1+I3
260 T1=TIME-T1 @ DISP "AREA=";S;"in";T1
270 !
280 DEF FNF(Y)
290 X=SQR(-LOG(FNR(Y)))
300 X1=ABS(Y-X)^(1/3) @ IF Y<X THEN X1=-X1
310 X2=(Y+X)^(1/3)
320 FNF=X2-X1
330 END DEF
HP-71B results (real machine):
>RUN
RHS=1 for Ymax= 2.82740261413
LHS=RHS for X= 0 and Y= .831971149978
Ix IBOUND
5.42070674749E-4 5.42070677958E-13
1.23815989579 1.23815999491E-12
.023696731798 2.36967317996E-13
.814227669493 8.14227500886E-13
AREA= 2.07662636775 in 5558 s (about 1h32min)
HP-75 results (real machine):
Ix IBOUND
5.4207067472E-4 9.99986161748E-14
1.23815989579 8.0765563033E-13
.023696731798 1.9746071305E-13
.814227669488 -1.89760803456E-13
AREA= 2.07662636775 in 33225 s (about 9h13min)
It is interesting to note how inefficient the HP-75 is for this problem, despite its faster speed. Especially, the last negative IBOUND value indicates that convergence was not detected with the maximum 32768 samples.
The HP-75 Math ROM integration code is based on the same Romberg algorithm than the 71B, but differs in the way the error is estimated (IBOUND) and the convergence is detected (see here for details), and it makes a huge difference for this problem.
However, it confirms the result obtained on the 71B. Good.
What about the accuracy?
I have no reference to compare with, I can only trust the HP integral algorithm and the IBOUND estimations for each zone.
I would expect 10 correct digits, maybe 11.
J-F
01-12-2023, 10:26 AM (This post was last modified: 01-12-2023 10:40 AM by J-F Garnier.)
(01-12-2023 12:00 AM)Fernando del Rey Wrote:  If you make the grid accurate enough, say 500x500, you can see a small area at the upper left side of the rectangle where criteria (1) is met, and then a much larger area in the middle to lower half of the rectangle.
(01-12-2023 07:31 AM)Werner Wrote:  Incidentally (and accidentally) I also found a tiny region -4.0851.. <= y <= -4.0492.. where the original inequality will hold (eg. y=-4.05 and x=0.004).
Congratulations, Fernando and Werner, I missed it!
This was the "nice surprise" Valentin alluded to.
I vaguely suspected something like that, but I missed it although it would have been easy for me to see it by scanning the RHS from -sqr(m) to sqr(m):
>FOR Y=-5.5 to 5.5 STEP 0.5 @ FIX 1 @ DISP Y; @ STD @ DISP FNR(Y) @ NEXT Y
-5.5 1.49982769946
-5.0 1.21469841054
-4.5 1.04966788525
-4.0 1.00125597171 so close to 1 !!!
-3.5 1.11151914811
-3.0 1.45086446604
-2.5 2.02718534492
-2.0 2.61560067448
-1.5 2.78630642506
-1.0 2.35303256133
-0.5 1.62346023059
0.0 1
0.5 .627452895252
1.0 .464331687261
1.5 .443627546686
2.0 .535830072581
2.5 .757499135913
3.0 1.16768672176
3.5 1.8275622105
4.0 2.66354177734
4.5 3.3313121353
5.0 3.44028193128
5.5 3.03092654911
I will correct my calculation, but it's too late, I failed the test :-(
J-F
01-12-2023, 03:06 PM
Most likely, the region was fitted with inequality expression, not the other way around.
I would not worry about this, especially since OP suggested locate region by eye.
If we plot this, say, y = -5 .. 5, above "dot" area does not even show.
(01-12-2023 09:34 AM)J-F Garnier Wrote:  What about the accuracy?
If integrand behave like a polynomial, IBOUND likely over-estimates true error.
IBOUND was based from relative error of current result vs previous, not true result vs current.
For polynomial-like integrand, we can get by with bigger eps (= less function evaluations)
That's the reason my code, with eps=10^-6, results in area of 10+ accuracy.
(01-11-2023 10:17 PM)Albert Chan Wrote:  Area = \(\displaystyle \int_0^{1/2} g(z)\;dz
I expected at z ≈ 0, g(z) behaves like c1 + c2*cbrt(z)
To simplify, say g(z) = z^(1/3), and we substitute with z=x^3
∫(z^(1/3) dz) = ∫((x^3)^(1/3) * (3*x^2 dx)) = 3*∫(x^3 dx)
RHS turned to plain polynomial, easy to integrate with Romberg.
01-12-2023, 08:37 PM (This post was last modified: 01-12-2023 08:38 PM by J-F Garnier.)
Update of my initial solution to include the "tiny" area at y= -4.05 .. -4.08 :
Program line changes or additions:
241 ! RHS<1 FOR Y=-4.05 !
242 F=FNROOT(-4,-4.05,FNR1(FVAR))
243 G=FNROOT(-4.05,-4.1,FNR1(FVAR))
244 I4=INTEGRAL(G,F,E*10000,FNF(IVAR)) @ DISP I4;IBOUND
250 S=I0+I2+I1+I3
260 T1=TIME-T1 @ DISP "AREA=";S+I4;"in";T1
265 DISP "(MAIN=";S;" TINY=";I4;")"
310 X2=ABS(Y+X)^(1/3) @ IF Y<-X THEN X2=-X2
New result (HP-71B):
Ix IBOUND
7.1976193049E-5 7.19937671652E-13
AREA= 2.07669834394 in 5594 s (about 1h33min)
(MAIN= 2.07662636775 TINY= 7.1976193049E-5 )
J-F
01-12-2023, 11:45 PM (This post was last modified: 01-13-2023 06:42 PM by Albert Chan.)
(01-12-2023 08:37 PM)J-F Garnier Wrote:  (MAIN= 2.07662636775 TINY= 7.1976193049E-5 )
I still think the tiny area is not OP were asking ...
Anyway, we can confirm TINY area, assuming the dot look like an ellipse.
Or, we think of half ellipse area, with minor axis = FNF(center)
>f, g                                            ! (ymax, ymin), from JFG code
 -4.04921226445      -4.08514674762
>c = (f+g)/2 @ a = (f-g)/2 @ b = fnf(c)
>s = pi/2 * a * b                          ! half ellipse area
>s
 7.19760843094E-5
Almost 6 digits accuracy. Not bad for 1 function evaluation!
2 more function evaluations, we gain another digit accuracy.
Simpson's weight, for 5 points = [1, 4, 2, 4, 1] / 12
There is no need to evaluate odd points. FNF(y) matched ellipse numbers.
S1=0, we might as well go for Boole's rule : S2 + (S2-S1)/(16-1) = 16/15 * S2
>h = sqrt(0.75) * b
>s + ((fnf(c-a/2)-h) + (fnf(c+a/2)-h)) * 4/12 * 16/15 * (2*a)
7.19761691227E-5
01-13-2023, 06:45 AM
(01-12-2023 11:45 PM)Albert Chan Wrote:  I still think the tiny area is not OP were asking ...
For once, Albert, I dare to disagree.
We were asked to calculate the area defined by the inequality.
If the tiny speck was to be omitted, the problem should have had an extra condition, like y>=0 or so, especially since 10-12 digits of accuracy were requested.
For the physical problem of the engine's efficiency, the tiny area does not matter, indeed.
Cheers, Werner
01-19-2023, 05:08 PM
Hi, all,
Well, almost two weeks have elapsed since I posted my OP, which has already passed the ~1,400 views mark (alas, once again when the difficulty increases the number of posts and/or views decreases,) and we've got a number of solutions and comments (though no RPL ones, I wonder why ...), namely by PeterP, Martin Hepperle, Werner, J-F Garnier, Fernando del Rey, and Albert Chan. Thank you very much to all of you for your interest and valuable contributions.
Now, this is my detailed sleuthing process and resulting original solution, plus additional comments:
    Note: though a number of graphics are featured in this solution, as suggested in the problem's statement, rest assured that none of them are needed, all intermediate and final results can be automatically computed without relying on graphics at all. The ultimate reason behind using them is that I feel they greatly help interested readers to better understand the steps to the solution, and they make for a more enjoyable presentation as compared to a wall of dry, terse math expressions alone.
My sleuthing process
First of all, we rearrange the equation into this equivalent, simpler form:
      [Image: SRC-12-5-1-bewmh.jpg]
Now, as suggested in my OP, we use a simple function plotter to get a visual idea of the region's shape and determine a rough (d.dd) approximate value for its ymin and ymax limits:
    Note: There's no need to get now the xmin and xmax limits because we'll compute them as a function of the y values, as will be seen below.
[Image: SRC-12-5-2-oipecp.jpg]
and at first sight it seems that the region is a single island between ymin = 0 and ymax ~ 2.83, but there's the nagging question: How can we be sure that there's only just one island ? Perhaps it might be the case that the region consists of several disconnected subregions. How can we know for sure ?
One obvious way would be to obtain surefire limits for the valid ranges for x and y and carefully zoom and pan over the corresponding enclosing rectangle or else write scanning code to try and detect additional subregions, but this would be extremely time-consuming if the hypothetical subregions ("islands") happen to be very small (or worse, nonexistent,) which might well be the case as we can't see them outright.
At any rate, even if our zooming and/or scanning did detect some small islands, we still wouldn't be sure that other even smaller ones didn't exist, so a more analytical approach is required and as the variable x appears just once, we isolate it, obtaining:
      [Image: SRC-12-5-6b-foqmgu.jpg]
and it's clear that x will be real only if the expression under the square root is ≥ 0. Two cases:
    ● If > 0, we'll have two distinct values, x1 and x2, and their difference will be the width of the island for a given value of y.
    ● If = 0, then x1 = x2 and the width of the island will be 0 (i.e. the extreme top and bottom of the shape), so the corresponding values of y are the limits ymin and ymax for each existing island and we'll compute them by simply finding all the roots of the equation:
          [Image: SRC-12-5-6c-ldeiio.jpg]
Graphing the expression will give us the number of islands and a little zooming will provide initial approximations (d.dd) to the roots, i.e. the ymin, ymax limits for each island:
[Image: SRC-12-5-3-fsmnew.jpg]
so we see that there's definitely one big island with ymin = 0 and ymax ~ 2.83, and possibly a much smaller island near y ~ -4. Zooming a little more we have:
[Image: SRC-12-5-4-kjhjhe.jpg]
and indeed there's a very small island with ymin ~ -4.08 and ymax ~ -4.05 and no more islands are possible as the expression goes increasingly negative for y > ~ 2.83 and y < ~ -4.08. Now that we know the small island's location (the x can be obtained from the y using the formula above), we can visualize it:
[Image: SRC-12-5-15-reiwjh.jpg]
It's worth noting that the formulas above for x1 and x2, if plotted independently, allows us to see how the perimeter of each island is composed of two separate "branches" which are joined seamlessly at their extremes:
[Image: SRC-12-5-9-aiereg.jpg]
Now, knowing the y-range [ymin, ymax] for an island, its area is given by the expression:
      [Image: SRC-12-5-11-oouytx.jpg]
and the total area is the sum of the areas of both islands. The small island's integral is quite amenable to numerical integration save for the fact that it might lose 2-3 digits to cancellation, but as the resulting area is then added to the much larger one corresponding to the big island, those digits don't affect the sum to 12-digit accuracy.
The integral for the big island, however, has two singularities, one at y = 0 (which doesn't cause any problems as this is the ymin extreme and the Width function being integrated is never evaluated there by INTEGRAL,) and another inside the range [ymin, ymax], which causes INTEGRAL to be at least 400% slower and even so it can only produce a value accurate to at most 7-8 digits, not 12.
The singularities can be recognized as the y values where the graph's tangent is horizontal, i.e., the graph goes parallel to the X axis. The y value of the inside singularity can be obtained by solving the equation SQR(-LN(Y*Y/30.07+EXP(-SIN(Y)))) = Y (which gives ysng ~ 0.83, as can be seen in the zoomed graphic below:
[Image: SRC-12-5-10-zjodyu.jpg]
and we can then split the single problematic integral into two parts, the singularities being now at the extremes of the ranges of integration where they do no harm, like this:
      [Image: SRC-12-5-17-ehllav.jpg]
My original solution
My original solution is this little 5-line, 12-statement, 244-byte HP-71B program (it can be made faster by using an additional line of code, but I like it this way):
    1  DESTROY ALL @ DIM U @ H=1/3 @ D=FNROOT(1,1,SQR(FNG(FVAR))-FVAR)
    2  DISP "Area:";FNI(0,D)+FNI(D,FNY(2.83))+FNI(FNY(-4.08),FNY(-4.05))
    3  DEF FNG(Y)=-LN(Y*Y/30.07+EXP(-SIN(Y))) @ DEF FNY(Y)=FNROOT(Y,Y,FNG(FVAR))
    4  DEF FNI(A,B)=INTEGRAL(A,B,1/10^10,FNW(IVAR)) @ DEF FNR(X)=SGN(X)*ABS(X)^H
    5  DEF FNW(Y) @ U=SQR(FNG(Y)) @ FNW=FNR(Y+U)-FNR(Y-U)
        Note: Notice that the parameter d = 1.598 does not appear in the solution's code, as the way it's featured in the inequality means that varying it only translates the whole region R along the X axis, which obviously doesn't alter R's area at all. Also, FNROOT/FVAR and INTEGRAL/IVAR are keywords from the Math ROM).
      Line 1 performs some initialization and also computes ysng (DIM U is necessary to create variable U here and not inside DEF FNW, where we would fall prey to a well-known system bug).
      Line 2 computes and displays the total area by evaluating and adding together the two integrals for the big island and the integral for the small island, while refining to full accuracy on the fly the d.dd approximations we got for the various ymin, ymax.
      Line 3 defines FNG for the expression under the square root as a function of y, as well as FNY, which refines to full accuracy the passed d.dd y approximation.
      Line 4 defines FNI, which returns the integral of the Width function between specified limits to full accuracy, as well as FNR, which returns the real cubic root (with the correct sign) of the real argument passed to it.
      Line 5 defines FNW, which returns the Width of an island at a given y value.
Let's run it:
    >STD @ RADIANS @ RUN
                Area: 2.07669834394
    The 20-digit value is 2.07669834394 76059651..., so we've got a full 12 correct digits.
      Note:  all 20-digit results given here were obtained using my original solution converted to RPN and run on Free42 Decimal. See Additional comments below.
We can obtain additional results if immediately after running the unmodified program above we execute these statements directly from the command prompt:
    >RES-IVALUE ►  2.07662636775     (big island's area   :   2.07662636775 45636287...)
    >IVALUE     ►  7.19761930517E-5  (little island's area:   7.19761930423 36384588...E-5)
    >D          ►   .831971149978    (big island's ysng   :   0.831971149979 07679799...)
    >FNY(2.83)  ►  2.82740261413     (big island's ymax   :   2.82740261412 95600918...)
    >FNY(-4.08) ► -4.08514674778     (little island's ymin:  -4.08514674763 83097474...)
    >FNY(-4.05) ► -4.04921226429     (little island's ymax:  -4.04921226439 69504765...)
For timing, execute instead:
    >SETTIME 0 @ CALL @ TIME
Additional comments
● It's quite trivial to convert my original BASIC solution for the HP-71B to HP-42S/Free42/DM42's RPN code, matter of fact it can be done on the fly while typing the RPN instructions on the calculator/simulator, without ever needing to previously write down the RPN code on paper or a notepad file. I did it precisely that way, thanks to the utmost simplicity of classic 4-level RPN code.
This allows for greatly enhanced accuracy if using Free42 Decimal/DM42, as seen in this image, where the total Area has been computed and displayed to 25 correct digits. A bit of the resulting RPN code is shown as well but I'm not including the complete conversion to RPN here, that's left as an easy exercise for the reader. Smile
[Image: SRC-12-5-16-ffsddi.jpg]
● As some of you may have guessed (some did not), the problem's statement (gas turbine's efficiency, ethane fuel, etc.) makes absolutely no sense from a "dimensional point of view" and it's but a made up story I concocted in the spirit of those the great late Martin Gardner used to create as a pleasant wrapper around many of his puzzles and mathematical recreations, to make them all the more interesting (e.g., see "The Magic Numbers of Dr [I.J.] Matrix").
For this particular problem, I first carefully selected the two parameters (d = 1.598 and M = 30.07) to achieve the desired effect, and only afterwards did I look for real-life subject matters which would include those values. I quickly found that some ethane properties actually did, and the problem was thus stated in terms of ethane, further deciding on its use as fuel for some hypothetical gas turbine. Should I have found first that certain properties of herrings featured those numbers, the problem's description would've been built around herrings instead, possibly red ones.
And what's the "desired effect" ? Well, to make the little island as inconspicuous as possible without overdoing it. To that effect, each parameter controls a particular aspect of the inconspicuousness, namely:
    ○  The parameter M controls the size of the region R, including the area of the main island and the number and areas of any existing additional islands, if any. Small variations of M result in a very noticeable effect, see for instance the very large increase in the size of the small island when changing from the problem's M = 30.07 to M = 30.5:
    [Image: SRC-12-5-13-sasppl.jpg]
    You may want to verify that by decreasing M the area of the small island tends to 0, and for M < ~30.06480779965 it disappears altogether so there's only the main island left. On the other hand, if we keep increasing M the small "microscopic" island grows to "macroscopic" size, becoming quite conspicuous, and as M tends to infinity further islands of various sizes do appear.
    ○  The parameter d controls the position of the region R along the X axis, and the problem's value d = 1.598 places the small island just under the Y axis, which will tend to greatly obscure and hide it if the user plots the Y axis as usual, even if it would be otherwise quite visible, as seen in this image where d = 1.818 clearly shows the small island while the problem's d = 1.598 almost completely hides it under the Y axis, though its size is the same.
    [Image: SRC-12-5-14-nvcruh.jpg]
Well, that's all for now, I hope you enjoyed it. Awesome-but-slightly-more-difficult Problem 5 will be posted next February.
    P.S.: If you want to discuss other approaches, show any mathematical analysis (math "lectures"), use any tools (Mathematica, etc.), languages (Python, etc.), calculators (HP Prime, etc.) or computers (SHARP Pocket computers, laptops, etc.) please post your comments and/or code to this parallel thread kindly created by EdS2.
V.
