PPC ROM in HP-41CX
09-14-2022, 06:24 PM
PPC ROM in HP-41CX
For almost two days the HP-41CX which had been dead for six months, came to life after removing the PPC ROM. But as of today the 41-CX is dead again. Removed all modules, checked batteries, nothing helped. What I thought was a restored 41-CX is now dead.
I took what I thought might be a defective PPC ROM and inserted it into a working HP-41CV where it showed up normally in the Catalog and functioned normally.
Any thoughts on how to once again resurrect my now dead HP-41CX?
Of course, the good news is that the PPC ROM is proven to be good.
09-14-2022, 07:00 PM
RE: PPC ROM in HP-41CX
It could be a few things:
Common ones:
The ribbon strip is no longer making consistent contact with the main board.
-Corrosion, broken case back (where the top screws go through the plastic gets brittle with age and can break not allowing for contact pressure).
If its a full-nut 41 it could be a lower post or zebra strip issue.
-Corrosion, lower posts.
A search of this site will bring you a wealth of suggestions.
-Bill
