Machine epsilon of the HP Prime
09-17-2022, 04:28 PM
// program mach_eps HP Prime
// September 17, 2022 // machine epsilon of the HP Prime // From Wikipedia; // "Machine epsilon or machine precision is an upper bound // on the relative approximation error due to rounding in // floating point arithmetic. This value characterizes // computer arithmetic in the field of numerical analysis, // and by extension in the subject of computational science." ///////////////////////////////////////////////////////////// export mach_eps() begin local epsmach; local one := 1.0; local two := 2.0; local u := 1.0; repeat u := u / two; until ((one + u) = one); epsmach := u; print(); print("machine epsilon of the HP Prime"); print("\neps = " + epsmach); print("\n1.0 + eps = " + (1.0 + epsmach)); end; |
09-17-2022, 05:28 PM
RE: Machine epsilon of the HP Prime
I suspect Home mode and CAS mode have different epsilons...
--Bob Prosperi |
09-18-2022, 08:11 AM
I fear there might be a couple of problems with this approach...
I should say that I'm taking machine epsilon to be the same as a unit in the last place (an ULP). If that's wrong, please tell me! First, I would have thought the correct value of epsilon is not the final u, but the one before that. Second, on a binary machine with correct rounding, we can add half an ULP and find that it makes a difference, because half an ULP may round upwards. So, in the case of BBC Basic with a 32 bit mantissa, the program as written returns 2^-33 as the epsilon, whereas I think the right answer is 2^-31. (Actually, I'm thinking now that even a decimal machine with correct rounding should round up when half an ULP is added... but then again, in this sense I think I'd have to say the majority of HP machines don't tend to round this way. With a decimal machine, halving the candidate epsilon each time might be asking for trouble: at the very least, the final epsilon found will be close to a power of two, but it ought to be an exact power of ten.) |
09-18-2022, 12:20 PM
(This post was last modified: 09-18-2022 02:41 PM by Albert Chan.)
(09-18-2022 08:11 AM)EdS2 Wrote: BBC Basic with a 32 bit mantissa, the program as written returns 2^-33 as the epsilon, Your "right" answer was the variant definition, machine epsilon = ULP of 1. 1. = 2^31 ULP → ε = ULP = 2^-31 OP use formal definition, u = ε/2 = 2^-32 Round-to-nearest, halfway-to-even, 1. + u == 1., for any even base >>> from gmpy2 import * >>> get_context().precision = 32 # binary32 >>> one = mpfr(1) >>> one + 2**-31 # 1 + ε mpfr('1.0000000005',32) >>> one + 2**-32 # 1 + u mpfr('1.0',32) 10-digits decimal, correct rounding: C:\> rpn =10 1e-9 1+ 1.000000001 C:\> rpn =10 1e-9 2/ 1+ 1 |
09-19-2022, 06:31 AM
Ah, thanks, so I may not be fully compliant, but I am a recognised variant!
Quote:This alternative definition is much more widespread outside academia: machine epsilon is the difference between 1 and the next larger floating point number. This, also from the Wikipedia page, seems to me to cast doubt on this approach: Quote:The following simple algorithm can be used to approximate the machine epsilon, to within a factor of two (one order of magnitude) of its true value, using a linear search.(Emphasis added) |
09-19-2022, 01:05 PM
(09-17-2022 05:28 PM)rprosperi Wrote: I suspect Home mode and CAS mode have different epsilons... Indeed, I think they should! See for example Joe Horn's explanation: (10-23-2015 05:41 AM)Joe Horn Wrote:(10-23-2015 02:35 AM)luc4as Wrote: When I try to calculate 3.6^2-4*3.24 in CAS mode, the calculator doesn't return 0, which is the correct answer. Home mode calculates it just fine. |
09-20-2022, 11:24 AM
For HP Prime, formal definition (maximum relative error) and variant definition (ulp of 1.) are the same.
CAS round number to 53 bits double (round-to-nearest), then chop to 48 bits, u = maximum relative error = (1 ULP) / (2^47 ULP) = 2^-47 1 = 2^47 ULP, unaffected by rounding-mode. This probably made variant defintion, ε = ulp of 1., more popular. |
