HP50G Algebraic object multiply by variable
09-21-2022, 03:38 AM
Hi all,
I am new user of HP50G from HP48SX, and now having error when transferring program to HP50G, hop anyone can help to see what's wrong with the following program.
Example :
Work on HP48SX
<< 5 'X' * >> ---> '5*X'
HP50G
<< 5 'X' * >> ---> * Error: Undefined Name
Do I need to set some flags or mode?
Thank You
Roy
09-21-2022, 12:19 PM
RE: HP50G Algebraic object multiply by variable
Hi, see if this helps:
It seems 'X' is undefined.
Try Mode, Flags, uncheck system flag 3
system flag 3 set --> "Function --> num" require that EVAL can result in a numerical value.
system flag 3 unset will allow for returning a symbolic
br Gjermund
09-22-2022, 10:03 AM
(09-21-2022 12:19 PM)Gjermund Skailand Wrote:  Hi, see if this helps:
br Gjermund
Hi Gjermund,
Thanks for your advise. It solved my problem.
