Integration Problem
09-21-2022, 05:13 PM
Integration Problem
I was hoping someone could point me into the right direction here. I should be getting 0.882 as the result which is what I get with Symbolab as well. Im guessing it is parsing incorrectly, but Ive tried lots of combinations.
See attached thumbnail for the equation
Matt
09-22-2022, 12:06 AM
RE: Integration Problem
If you do it in exact mode by replacing -10.4 with -104/10 and -9.5 with -95/10
then:
∫((1/10^(-95/10))*e^(-x/10^(-95/10)),x,10^(-104/10),∞)
returns:
e^(-sqrt(10)*1/10/(10^(1/5))^2)
which is approximately:
0.881709589165
It's not that it's parsing it incorrectly. In approx mode the round off error results in zero after zero being summed up to result in zero.
-road
09-22-2022, 12:18 AM
That pretty interesting. I suppose I could use the exact() function in front of the values as a work around.
Thanks for the help.
Matt
09-22-2022, 07:53 PM (This post was last modified: 09-23-2022 03:24 AM by rawi.)
I think this is because of the function extremely located next to zero.
If you put in x=10^(-10.4) you get 2.8*10^9
x=10^(-10) --> f(x) = 2.3*10^9
x=10^(-9) --> f(x) = 1.3*10^8
x=10^(-8) --> f(x) = 0.000058
x=10^(-7) --> f(x) = 1.5*10^(-128)
So if you put in infinity as the upper limit you get zero because there is no value x evaluated in the very narrow area where x has numeric results > 0.
But if you put in 1 as the upper limit of the integral you get 0.88170959, which is the correct result for the upper limit of infinity. And if you put in 1000, 0.1, or 0.01 as the upper limit you get exactly same result.
This reminds me of the Handbook for the HP 34 C from 1979 where it was explained (p. 257ff) that for the integral of x*e^(-x) from zero to infinity with infinity replaced by 1*10^99 the integration routine of the HP 34C delivers the result 0, which is wrong (the correct value is 1). This function as well has only in a very narrow area of x near to zero values that are numerically different from zero.
09-22-2022, 10:08 PM
CAS> eval('int(1/10^-9.5*exp(-x/10^-9.5), x, 10^-10.4, inf)' (x=1/t
0.881709589165
x=1/t turned above integral limits to finite, and transformed curve to bell-shaped.
see Numerical integration over infinte intervals
09-23-2022, 01:45 AM
(09-22-2022 07:53 PM)rawi Wrote:
This reminds me of the Handbook for the HP 34 C from 1979 where it was explained (p. 257ff) that for the integral of x*e^(-x) from zero to infinity with infinity replaced by 1*10^99 the integration routine of the HP 34C delivers the result 0, which is wrong (the correct value is 1). This function as well has only in a very narrow area values near to zero values that are numerically different from zero.
Nice example.
This thread has reminded me of a recent change (my memory isn’t quite as long!) to the Prime code base — revision 14623 for ticket 51 in the bug tracker — to improve Fcn / Intersection…’s (in Function’s Plot view) handling of F1(X)=166/75^X and F2(X)=180/97^X. Here, again, functions are tapering towards zero. (What struck me while making the change is how blithely one routinely goes from F1(X)=F2(X) to F1(X)-F2(X)=0 without considering the magnitudes of F1(X) and F2(X).)
09-23-2022, 03:57 PM
How does HP Prime handle integral infinite limit?
If I use 1e308 for inf, it get the right answer.
CAS> int(1/10^−9.5*e^((-x)/10^−9.5),x, 10^−10.4, 1e308)
0.881709589165
09-23-2022, 06:00 PM
Integral reaches the quoted answer for range from 10^-10.4 to 10^10^-8. It begins to reach an answer less than the number quoted when a range of 10^-10.4 to 10^-9 is used (.839380369542)
09-25-2022, 09:22 AM
(09-23-2022 03:57 PM)Albert Chan Wrote:  How does HP Prime handle integral infinite limit?
For numerical integration, the Prime uses the substitution u=atan(x) which maps ±∞ to ±pi/2.
(The 50g used the same substitution.)
