HP- 67 1706A04606 - keyboard repaired weird behavior
09-25-2022, 04:12 PM
Hi everyone
trying to make an HP-67 work, we have discovered that the numeric keys had the underneath domes broken We have transplanted those from an HP-45 and it may be interesting to see how it looks now, we have followed Teenix's procedure, drilling a small hole in the donor keyboard and soldering the strips on the HP-67 Being the firs time we are quite happy, but it could have been done a little better and nicer Anyway, this unit was used last time in March 2021 and put away in working condition without batteries Now, when the batteries are put inside, it doesn't turn on at the first try, some faint numbers appear on the screen and then nothing Sometimes keeping pressed a key while turning on does the trick, but not always Some times show a list of 0 and the keyboard is not responding In the end, we have found out that if we leave it on, after a while a 0.00 appears on the display and the unit works well What could it possible be ? Put it in another unit shows the same behavior As for the card reader, it reads very rarely, it writes but it cannot read the cards written by itself, these can be read without problems in a different unit Also, it shows a behavior that has already been discussed in the forum: When a double sided card is inserted, the first side is read correctly and prompt for the second side, but the second side will always make the motor run a little after the card has gone thru and then it gives an error message Pictures and video can die found here : HP- 67 1706A04606 Thanks in advance for any help !!! Take care ! Edoardo & Alberto |
09-25-2022, 07:22 PM
RE: HP- 67 1706A04606 - keyboard repaired weird behavior
Perhaps, try replacing the 47uF tantalum power supply capacitor, shown in image. 16 - 25V type should be ok.
Maybe others might need replacing as well. cheers Tony (09-25-2022 04:12 PM)albertofenini Wrote: Hi everyone |
09-25-2022, 08:27 PM
Thanks Tony
Will give it a try That should fix the power on issues What do you think of the card reader problems ? Take care and thanks ! Edoardo & Alberto |
09-25-2022, 09:51 PM
RE: HP- 67 1706A04606 - keyboard repaired weird behavior | |||
09-27-2022, 07:30 PM
Hi Tony, Hi everyone,
we replaced the 47microF capacitor, which I believe is that connected to Vbsw old: 50,26microF, Vloss 0,6%, ESR 0,00 Ohm new: 49,10microF, Vloss 1,0%, ESR 2,3 Ohm nothing changed in the power-on behavior then we also replaced the 22microF capacitor, connected to Vss old: 24,73microF, Vloss 0,7% ESR: 0,00 Ohm new: 22,44microF, Vloss 0m6%, ESR 0,00 Ohm again nothing changed in the power-on behavior We decide to change the two transistors as well : 4-071 old: hfe 331 Vbe 630mV Ic 3,0ma new : hfe 352 Vibe 641mV Ic 3,2mA 4-668 old: hfe 433 Vbe 645mV Ic 6,2mA new: hfe 351 Vbe 643mV Ic 3,2mA after this replacements, the power-on behavior didn't change, but the reading capabilities increased a lot, almost every card can be read and also it can now write and read its own written cards it must be said the the components we used are from an old HP-67 which also had some issues where could we get some equivalent new transistors ? should we also check the six pins Motorola component 3-410 ? (what is this by the way ?) thanks for any advice, take care !! Edoardo & Alberto |
09-28-2022, 12:54 AM
(This post was last modified: 09-28-2022 12:54 AM by teenix.)
(09-27-2022 07:30 PM)albertofenini Wrote: Hi Tony, Hi everyone, Maybe also change the 2.2uF (10-16V) tantalum capacitor near the ACT. The +ve connection is closest to pin 1 of ACT (red dot). This is used for the power up reset pulse for the ACT. Listed from Jaque Laporte's site... 1854-0071 = 2N3704 1854-0668 = ?? Cannot find any info on it. Maybe 2N3904?? If you check parts suppliers like Digikey and search NPN transistor for the HFE etc that you tested, you may find equivalents. 3-410 is 2 PNP transistors in the same package used for a constant current source for the LED display segments. cheers Tony |
09-28-2022, 04:17 AM
When I replaced transistors I used
4-071 —> 2N2222 3-393 —> 2N2907 3-374 —> 2N2907 Jebem once suggested fast switching high gain transistors capable of 0.5 to 1 A of current with at least 50 V Vcb and a minimum of 0.5 W power dissipation. |
09-28-2022, 02:19 PM
(09-28-2022 12:54 AM)teenix Wrote: Hi Tony Edoardo & Alberto |
09-28-2022, 08:41 PM
(09-28-2022 02:19 PM)albertofenini Wrote: Hi Tony see image cheers Tony |
09-29-2022, 03:25 PM
Thanks for the picture, will try later today and let you know
take care ! Edoardo & Alberto |
10-17-2022, 03:13 PM
yesterday we changed that as well, but nothing changed truth to be told is that we replace old parts with other old parts, will try to get new parts and see if that change something, any other suggestion that we may try in the meantime ? thanks again and take care !! Edoardo & Alberto |
11-19-2022, 06:28 PM
Hi everyone,
this has also been fixed, following all the advices we replaced : new 2,2 microFarad capacitors (3) new 22 microFarad capacitor new 47 microFarad capacitor some old but working transistors 4-071 and 4-668 for the power supply some old but working 1818-0231 and 1818-0232 however with no improvements then we replaced the actual 1820-1596 with a known working 1820-1956 and finally it fired up immediately and worked correctly Apparently, the old ACT Chip was bad in the meaning the it needed few minutes of warming in order to work properly .... Again thanks everyone for the support and the endless suggestions take care !! Edoardo & Alberto |
