HP-41 Flex-PCB replacement: How to video.
07-30-2014, 12:35 PM
Hi all,
Although I tried my best on the Replacement guide in order to describe the replacement procedure, hope this rudimentary (and very long) video to be helpful for those users who may find the task a bit too challenging. There is no sound since it's suppossed to be used along with guide as a step by step aid. Video is available here. As a result of the production of this clip, I've got a couple of pre-assembled I/O block replacements. (Details in the ads section) Cheers from Caribbean Sea. Diego. "Do not suppose, check it twice." |
07-30-2014, 12:52 PM
RE: HP-41 Flex-PCB replacement: How to video.
Thank you very much Diego.
The day I will finally decide to use mine this will be invaluable. Already downloaded and saved. :) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
07-30-2014, 06:56 PM
(07-30-2014 12:52 PM)Massimo Gnerucci Wrote: Thank you very much Diego. Hi Massimo, Thanks for your always kind words, I'm glad you found it illustrative. :-) All the best. Diego. "Do not suppose, check it twice." |
