Extra set of User defined Keys?
09-27-2022, 06:57 PM
(This post was last modified: 09-27-2022 07:12 PM by matalog.)
Is there any way to create a 2nd (or indeed 3rd etc) set of user defined keys on the HP Prime?
Is there a file somewhere that stores them that could be instructed to switch the user defined keys over from a Notes file for example? |
09-27-2022, 09:55 PM
RE: Extra set of User defined Keys?
Key definitions are programs. I don’t think you can do exactly what you need, but there are solutions:
1- Elegant Use a global variable to store the “page” you want to be active. Then, for each key you need to be defined differently according to the page, create a function with a CASE statement on the global variable. Code:
Of course you can assign the change of the value of your global variable to a key 2- Lazy The key definitions are read in the last edited program containing some. So just create as many program files as you want, and when you need to change the key page you just have to open the program editor for the designed program file. Thibault - not collector but in love with the few HP models I own - Also musician : http://walruspark.co |
09-28-2022, 09:51 PM
RE: Extra set of User defined Keys? | |||
