Derivatives
09-28-2022, 12:53 PM
Derivatives
Any best practices when dealing with numerical first and second derivatives? The diff command is iffy at best in HP Prime PPL non-CAS.
Also, I working on being more comfortable with the CAS mode and make it my primary mode when I am working with the Prime. |
09-29-2022, 12:51 PM
(This post was last modified: 09-29-2022 01:09 PM by Arno K.)
RE: Derivatives
Hello Eddie,
diff and | (where) seem not to work, doesn't matter how many brackets are used as this is translated to ', that is (diff(x^3))|x=5 provides diff(125,5). You can use '(∂(x^3,x)|(x = 5))' which then provides the numeric result. Arno edit: diff(e^(2*x)+5*x^3-x,x,2,x=2) provides 60+2*e^2, that does the trick for higher derivatives |
10-02-2022, 12:47 AM
RE: Derivatives
Trying the second derivative in a program:
Code: EXPORT DER2(f,v,n) Home: DER2(X^3,X,1) -> Error: Bad argument value ("diff(f,v,2,v=n)")] DER2('X^3','X',1) -> diff(diff(3.006003,2),0) CAS: DER2(X^3,X,1) -> Error: Bad argument value ("diff(f,v,2,v=n)")] DER2(x^3,x,1) -> diff(diff(3*x^2,2),0) I hope that the next Prime update will allow for numerical differentiation for both first and second derivatives. |
10-02-2022, 03:11 PM
RE: Derivatives
(10-02-2022 12:47 AM)Eddie W. Shore Wrote: Trying the second derivative in a program: Hello, try using this little program: Code:
Example: DER2 (function, degree of derivation, number) DER (t ^ 3,2,4) -> 24 Sincerely, robmio |
10-02-2022, 04:37 PM
RE: Derivatives
(10-02-2022 12:47 AM)Eddie W. Shore Wrote: Trying the second derivative in a program: another program uses the limits of the function: Code:
grado --> degree of derivation num --> value of the derivative ds = -1 --> left limit ds = +1 --> right limit ds = 0 --> bidirectional limit examples: DER2((t)->t^3,2,4,0) --> 24 DER2((x)->Si(x),1,0,0) --> 1 DER2((x)->ln(x),1,0,1) --> +inf DER2((x)->ln(x),1,0,-1) --> -inf DER2((x)->ln(x),1,0,) --> +/-inf DER2((t)->e^(-2*t),3,7,0) --> -8*exp(-14) |
10-04-2022, 01:47 PM
RE: Derivatives
Ma program is smaller and insists in x being used:
#cas dif2(f,gr,val):= BEGIN return diff(f,x,gr,x=val); END; #end and does the job. Arno |
10-05-2022, 09:44 AM
RE: Derivatives | |||
10-05-2022, 09:52 AM
10-05-2022, 04:21 PM
RE: Derivatives
Perhaps because dif2(Si(x),1,a) provides sin(a)/a and then 0 is used for a, without bothering with limits.
Arno |
10-06-2022, 04:55 AM
