Hardware vs. Emulator - CAS program
10-02-2022, 12:25 AM
It is me, or has the #cas/#endcas(?) disappeared in programs?
The code calculates the curvature of f(x).
EXPORT fcurve(y,x)
// curvature
// function
// radius = 1/curvature
LOCAL a,b;
a:=diff(y,x,2);
b:=diff(y,x,1);
RETURN ABS(a)/(1+b^2)^(3/2);
Hardware: 2.1.14603 (12/2/2021)
CAS works as expected
Home works as expected as long as variables and the function are quoted
Emulator: 2.1.14596 (10/1/2021 - I didn't see an update since)
Despite purging all the variables, 0 is returned
Attached File(s) Thumbnail(s)
10-02-2022, 05:29 AM (This post was last modified: 10-02-2022 05:29 AM by toml_12953.)
RE: Hardware vs. Emulator - CAS program
Checking the CAS: box when creating a new program no longer automatically creates a CAS template. You can put in the #cas and #endcas lines yourself and they continue to work properly.
Tom L
Cui bono?
10-03-2022, 06:43 PM
(10-02-2022 05:29 AM)toml_12953 Wrote:  Checking the CAS: box when creating a new program no longer automatically creates a CAS template. You can put in the #cas and #endcas lines yourself and they continue to work properly.
It would be nice if the CAS checkbox were put back. It would also be nice to have a checkbox for a Python program where it would set up a template for the necessary wrapper function.
