HP Prime Graphical Issue
10-05-2022, 01:01 PM (This post was last modified: 10-07-2022 12:42 PM by shoman24v.)
Anyone know what would cause the graphical issues on my calculator? It was actually much worse when I put it away a month ago, now it seems better. I tried resetting it, but had no luck.
[Image: PXL-20221005-125817433.jpg]
[Image: PXL-20221007-103536726.jpg]
Join the HP 48 Facebook Group!
10-06-2022, 11:53 PM
RE: HP Prime Graphical Issue
I don't know what I'm looking for. What exactly are you referring to?
Cemetech | YouTube
10-07-2022, 03:07 AM
*If* the issue is screen flicker and *if* the unit is a G2, you could try adjusting the refresh rate. See:
https://www.hpmuseum.org/forum/thread-14...26956.html
10-07-2022, 10:36 AM (This post was last modified: 10-07-2022 12:42 PM by shoman24v.)
If you look at the top menu bar, the blue part is actually 2 colors. Same with the bottom menu bar, the black part is partly white.
It used to be much much worse. I've also recently updated the firmware. That didn't fix it either.
Here's another example:
