(49G & 33s) OEIS A10785: Repdigit Numbers (in Human Readable Form)
10-11-2022, 05:20 PM (This post was last modified: 10-12-2022 04:34 PM by Gerald H.)
For natural number input N the programme returns the Nth repdigit number in human readable form, eg
for input
19531808
the programme returna
{8 2170201}
to be read as the figure eight repeated 2170201 times.
http://oeis.org/A010785
CkSum: # C8AEh
  CK1&Dispatch
  # FF
      FPTR2 ^DupQIsZero?
      case
      ZINT 0
      ZINT 9
      FPTR2 ^ZDIVext
      FPTR2 ^DupQIsZero?
      NOT?SEMI
      DROP
      ZINT 1
      FPTR2 ^RSUBext
      ZINT 9
    SWAP
    ZINT 1
    FPTR2 ^RADDext
    TWO{}N
10-12-2022, 03:52 AM
RE: (49G) OEIS A10785: Repdigit Numbers (in Human Readable Form)
The following User RPL program seems to produce the same outputs as your program, except for most inputs less than 1, which seems to me to be an acceptable limitation.
\<< 1 - 9 IDIV2 SWAP 2 \->LIST -1 - \>>
BYTES: 35.5
CRC: #3E16h
<0|ɸ|0>
-Joe-
10-12-2022, 11:41 AM
Thank you, Joe, for the clarity of your programme.
For the 33s the programme A produces a 2-level version of the repdigit & programme B takes the result of A & returns the position in the OEIS series.
Preserves stack.
1.    LBL A
2.    x<0?
3.    GTO B
4.    STO N
5.    9
6.    STO I
7.    INT/
8.    STO Q
9.    CLx
10.    RCL N
11.    RCL I
12.    RMDR
13.    STO R
14.    SGN
15.    STO+ Q
16.    x≠0?
17.    RCL* R
18.    x=0?
19.    RCL+ I
20.    RCL Q
21.    RTN
1.    LBL B
2.    +/-
3.    STO N
4.    SGN
5.    STO- N
6.    CLx
7.    9
8.    RCL* N
9.    +
10.    RTN
A: LN = 75
B: LN = 42
10-12-2022, 04:33 PM
Slightly improved 33s programme, also deals correctly with 0 as input.
1.    LBL A
2.    x<0?
3.    GTO B
4.    STO N
5.    9
6.    STO I
7.    INT/
8.    STO Q
9.    RCL* I
10.    +/-
11.    RCL+ N
12.    STO R
13.    SGN
14.    STO+ Q
15.    x≠0?
16.    RCL* R
17.    x=0?
18.    RCL+ I
19.    RCL Q
20.    x≠0?
21.    RTN
22.    x<>y
23.    SGN
24.    RTN
1.    LBL B
2.    +/-
3.    STO N
4.    SGN
5.    STO- N
6.    CLx
7.    9
8.    RCL* N
9.    +
10.    RTN
A: LN = 84
B: LN = 42
10-13-2022, 07:06 AM
RE: (49G & 33s) OEIS A10785: Repdigit Numbers (in Human Readable Form)
Joe, I have adapted your suggestion for 33s & come up with
1.    LBL C
2.    1
3.    -
4.    STO N
5.    9
6.    RMDR
7.    1
8.    +
9.    IDIV(N:9)+1
10.    RTN
which gives wrong answers, eg
8
111111111112
for input
999999999998
whereas my programme returns correct
8
111111111111
Is my implementation faulty?
10-13-2022, 07:29 AM (This post was last modified: 10-13-2022 07:29 AM by Joe Horn.)
(10-13-2022 07:06 AM)Gerald H Wrote:  ...
9.    IDIV(N:9)+1
8
111111111112
for input
999999999998
8
111111111111
No, you ran into a bug in the 33s when it evaluates "equations". If you store 999999999997 into N, then store IDIV(N:9)+1 in EQN, then execute it, the 33s returns the wrong answer (111111111112), whereas the 35s returns the correct answer (111111111111). Furthermore, the 33s returns the correct answer if you rewrite the program without using the EQN key.
I do not not know whether this bug in the 33s has been found before, or if you are its first discoverer.
<0|ɸ|0>
-Joe-
10-13-2022, 08:11 AM (This post was last modified: 10-13-2022 12:16 PM by Gerald H.)
Edit: Line 14 corrected.
Yes, now gives correct answers.
1.    LBL C
2.    1
3.    STO U
4.    -
5.    STO N
6.    9
7.    STO I
8.    INT/
9.    RCL+ U
10.    x<> N
11.    RCL I
12.    RMDR
13.    RCL+ U
14.    RCL N
15.    RTN
C: LN = 69
