go97c emulator speed switch
10-22-2022, 04:04 AM
Greetings
I'm using an android app which emulates the hp97/97+. Emulator works fine except that I can't access the emulation speed switch or select between hp97/97+ mode. The emulator is on the google play store and its written by Oliver De Smet. I have emailed Oliver about this. I'm using a Samsung Note 10. Any ideas where this switch is hidden? Thanks Rich |
