linsolve sometimes returns incorrect answer
10-27-2022, 06:02 PM
I was solving a system of equations for physics and I came across what appears to be bug in the linsolve (and solve) function.
linsolve([t1-m3*g=m3*a3, t2-m1*g=m1*a1, t2-m2*g=m2*a2, t1-2*t2=0, a1=-(a2+a3)/2], [t1,t2,a1,a2,a3]);
xcas (and maxima) both give the results to be
[8*g*m1*m2*m3/(2*m1*m2+m1*m3+2*m2*m3),4*g*m1*m2*m3/(2*m1*m2+m1*m3+2*m2*m3),(-2*g*m1*m2-g*m1*m3+2*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3),(-2*g*m1*m2+3*g*m1*m3-2*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3),(6*g*m1*m2-g*m1*m3-2*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3)]
but the Prime CAS, HW 2.1.14603 (2021-12-02) and VC 2.1.14596 (2021-10-01), returns exactly twice the correct answers
[16*g*m1*m2*m3/(2*m1*m2+m1*m3+2*m2*m3),8*g*m1*m2*m3/(2*m1*m2+m1*m3+2*m2*m3),(-4*g*m1*m2-2*g*m1*m3+4*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3),(-4*g*m1*m2+6*g*m1*m3-4*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3),(12*g*m1*m2-2*g*m1*m3-4*g*m2*m3)/(2*m1*m2+m1*m3+2*m2*m3)]
However, if I change the last equation from a1=-(a2+a3)/2 to the equivalent 2*a1=-(a2+a3), then the answers are correct.
Also, if I plug in numeric values into the original equations, such as
linsolve([t1-30*10=30*a3, t2-10*10=10*a1, t2-20*10=20*a2, t1-2*t2=0, a1=-(a2+a3)/2], [t1,t2,a1,a2,a3]);
it produces the correct results.
[4800/19,2400/19,50/19,-70/19,-30/19]
10-30-2022, 02:43 PM (This post was last modified: 10-30-2022 02:44 PM by Wes Loewer.)
RE: linsolve sometimes returns incorrect answer
Seems that this bug was introduced back in 2017.
I can confirm the following:
firmware 11226 (2016-12-08) does not have this bug
firmware 11385 (2017-01-27) has this bug
10-30-2022, 03:57 PM
We have the same bug for XCas 1.5.0-63 (win32), returning twice the correct answer.
10-30-2022, 05:34 PM
(10-30-2022 03:57 PM)Albert Chan Wrote:  We have the same bug for XCas 1.5.0-63 (win32), returning twice the correct answer.
Since xcas 1.9.0-7 does not have the bug anymore, perhaps it's already been fixed in the Prime CAS which we'll hopefully see it in the next firmware.
05-21-2023, 11:22 AM
I'm surprised that this bug which was fixed in xcas quite some time back is still present in the recently released Prime firmware.
