Terminal Command (bug?)
10-29-2022, 06:07 AM
Used: Emulator - Firmware 14596
Changing the contents of Twitter lines is fine. For instance, this code changes the 1st line of the Terminal to "{5,#0000FFh}": Code: EXPORT test2() This code, which is attempting to turn the first line blue, crashes the emulator: Code: EXPORT test2() Also, I assume object is what I want printed. I don't know what to use for flags. |
